12-13-2015, 09:15 AM | #1 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
Manual Trans Fluid?
Just curious what manual trans fluid you guys are using? Any advantage to using synthetic. Thanks.
12-13-2015, 09:43 AM | #2 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Save yourself the 1 -2 gear shift issues and get the Royal Purple Synchromax.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
12-13-2015, 09:49 AM | #3 |
according to Tremec, you can use Mobil 1 which is Dexron III approved. Other fluids can be debated over days here. Amsoil has a synthetic fluid rated for the Tremec manuals which I'm sure will work fine also. I wouldn't try to get "fancy" with other secondary brands.
12-13-2015, 09:58 AM | #4 |
this Amsoil supposedly works great. Weapons X motorsports recommendation
12-13-2015, 10:04 AM | #5 |
Manual Transmission,TR6060......GLS [3]
All TEMPS...... Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT) OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT) Torque-Drive Synthetic Transmission Fluid (ATD1G)
12-13-2015, 10:53 AM | #6 |
Thanks for the replies. I was hoping a fluid change would smooth out the shifting (especially when cold). Looks like I have little more research to do.
12-13-2015, 01:05 PM | #7 |
Drives: 13 ZL1 SIM, 99 Z28 Black Join Date: Feb 2013
I used Redline D4 ATF because it has a slightly lower viscosity at 40C, but pretty much the same at 100C. Try searching the transmission section of the forum.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
12-13-2015, 04:45 PM | #8 |
Drives: 2015 Camaro ZL1 (red hot) Join Date: Dec 2014
12-13-2015, 06:04 PM | #9 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
RPM transmission recommends the Royal Purple syncromax. I run it because they build my transmissions but I really don't know how it differs from the others. I've had 2 transmission rebuilds in 10,000 miles but I'm drag racing with over 1000whp on a 4200+ pound car....
I have heard the MGW shifter is a big improvement over the stock ZL1 shifter. I have not driven with one but plan to have one installed when my car goes back together this time. I think I talked to about 4 guys running the MGW and they all rave about it.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
12-13-2015, 06:46 PM | #10 |
^^^ It seems the guys who switch to the MGW shifter love it. I like the stock shifter, but I wonder if the MGW allows for quicker shifts at WOT?
12-14-2015, 06:19 PM | #11 |
Drives: bicycle Join Date: Jun 2014
AMSOIL is being used in many street and race dedicated Camaros with great sucess
