![]() ![]() ![]() Drives: 2002 Z/28,1968 Chevelle convert. Join Date: Oct 2010
2016 wheel bolt pattern ???
anyone know the bolt pattern for the 2016 Camaro ??.... sorry if it's a re-post
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
5 on 120
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: ‘22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Convertible Join Date: May 2012
Bolt pattern is the same as Gen5 but the backspacing is different. There are some threads in the forum that talk about the differences.
In case you are planning to buy new wheels the stock 20" Gen6 wheels are wider with more offset than Gen5 wheels. The Gen6 tire has a slightly smaller diameter than the Gen5 tire. You will want to make sure the wheel size is correct for Gen6. |
the 275 35 20s are about 27.7 and the 275 40 20s are about 28.6. I ran the 35 series on my 2008 g8gt. I just like a little more sidewall as in the 40 series. Roads in Missouri are littered with pot holes, little more sidewall holds up better on these shitty roads.
Drives: BLACK ON BLACK Join Date: Jul 2015
