![]() Drives: TBD Join Date: Aug 2013
C7 reliability - a heads up for the Gen 6??
Car and Driver just put up their long-term wrapup on their C7 - and to say it is scary is a gross understatement. I probably would have lemon-lawed the car it had so many issues. Everything from the HU down gave them headaches - grenading engine, leaking axle seals at 25k, crappy transmission that had no fix, failed HVAC, the list goes on. Now their car may have been an extreme example but the Vette forums suggest problems are not uncommon.
It will be very interesting to see if the same reliability issues plague the Gen 6 - it of course has basically the same engine, but the car itself is assembled at a different plant from the Vette so maybe there's hope. |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Supposedly there was a bad batch of engines that had some metal shavings from bad oil filters if I recall, theirs was one of those. I know three people with C7's, a '14, a '15 and a '16, no issues like these so far. Their transmission issues only started after the new engine was installed. If that was me, I would have demanded a resolution, as it was fine beforehand. The axle seals were from the extreme cold, guess GM thought nobody drives Vettes in snow and freezing temps LOL. But they have different axle seals now on all C7's.
#3 | |
The oil filter was not the only engine issue:
![]() ![]() ![]() ![]() Drives: '94 Z28+ '15 Z/28 Join Date: Jun 2009
All 3 car magazines, Motor Trend, Car and Driver, and Road and Track or Automobile, had issues. Big issues. Ask Randy Pobst what it's like to run a Z06 at full boogie? Oh that's right, he can't get one to do a full lap without pulling boost on the stick cars or going into limp mode on the auto.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C 1980 Z28- resto-mod project 1979 Y84 Trans Am 1986 IROC-Z |
#5 | |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
Where do you guys come up with this.
Percentage wise the c7 is among the most reliable vehicles. The 500 mile oil change resolved the gasket bleed off that was contaminating the oil at the track... The solution was to change the oil at 500 miles and remove the contaminants the gaskets were putting out in the first 500 miles. I hope that clears up the reliability aspect of the LT1. It's a hell of a mass produced engine. Remember the c7 z51 is warrantied even with track use.... Most manufacturers will void the Warranty if you take their car to the track. That's pretty cool of gm ...
2008 Blk C6 Z51 NPP M6/2008 Silver CTS AWD FE2 304hp
#7 |
![]() ![]() ![]() Drives: Want a gen 6 Join Date: Jan 2013
I suspect revisions and latest tech wise, the 2016 Camaro drivetrain is more comprable to the 2016 c7 than the 2014.
#8 |
#9 |
![]() ![]() Drives: 2013 1SS LS3 Join Date: Feb 2014
It's not just Corvettes. Check out the truck and SUV forums. Lots of issues. I wouldn't even consider a gen 6 until I see how the first year shakes out. People can pretend everything's fine, but GM QC really seems to have slipped recently.
#10 |
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
BAD news is still, news. We would be foolhearted to ignore possible issues. Dont flame the poster.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: ‘22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
#11 |
![]() Drives: 2015 Stingray & 2011 Cruze Join Date: Mar 2010
My C7 has been a dream, nothing like the problems C&D had.
#12 |
![]() ![]() ![]() ![]() Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
I have heard of little to basically no powertrain issues in the new GM trucks. Some have had vibration issues (not engine vibrations) and many complained about the slow throttle response (tuning for gas mileage) but those are irrelevant.
#13 | |
#14 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
