![]() Drives: 2016 Camaro 2SS Join Date: Jul 2015
High Flow Cats
Does anyone know if i can go to a muffler shop and get high flow cats as soon as i get my car or do i have to wait to on a company to create an aftermarket system?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
Most muffler shops won't touch cats on a brand new car due to federal law. You'll have to wait for an aftermarket option which I'm sure will be out in a matter of months.
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
Vehicle already has 4 HFC, you want more? Or are you trying to get them TAKEN OUT ? Wait till Borla/Corsa or others release their xpipe. It will remove 2 HFC mid section and you'll be fine with 2 HFC + oem mufflers.
I didnt realize it already has them. Thanks
Where do you see 4 high flow cats? Most have only two catalytic converters
#6 | |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
#7 |
The Dogfather
^ Thank you sledge
#8 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Where do you see that they are "high flow cats"??? Did I miss that? It does have 4 cats, just like the 5th gen, but I seriously doubt they are high flow by any means... Typically the cats you see from the factory are ~800 cell, and high flow cats are typically ~200 cell...
I've got a 2016 4 cylinder turbo downpipe here with the cat, and I can DEFINITELY tell you that this one IS NOT high flow by any means. To the OP, odds are you will have to wait for something bolt on to show up aftermarket unless you are handy at fabricating yourself, have a friend that is, or come across a muffler shop that doesn't mind doing something illegal (in most states) and doesn't mind doing it custom for you. And even then, no guarantee the check engine light will stay off. |
#9 |
the car has 4 cats, yes. but "high flow"? how do you figure that?
#10 |
![]() ![]() ![]() Drives: 2016 camaro ss Join Date: Oct 2010
He probably just meant high-flow because they are supporting 455hp/tq without issue.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
Just wait a short while for Solo Performance Exhaust to come out with a Hi-Flow like they had for the Gen5. http://solo-performance.com/pe-camaro-ls3-std
Great quality and great sound! Bolts right on and no CEL. |
#12 | |
Black lightning
You got the base turbo version BECAUSE YOUR ABOUT TO MOD THE HOLY CRAP OUT OF IT. I remember your 5th gen had like 7000 hp to the wheels. just saying what's up. ANd Im waiting....![]() ![]() ![]()
[ 2021 Camaro ZLE 10 speed
