Old 10-20-2015, 02:48 PM   #1
mcsoul
Drives: Want a gen 6
Does this tune only Auto c7 1/4 mile time relate to the g6 A8?
If anything? I'm thinking the A8 Camaro could be 3/10's behind after a tune, am I off base?
mcsoul is offline   Reply With Quote
Old 10-20-2015, 08:02 PM   #2
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
A good tune on an auto is worth about 3-4 tenths on average.
...also, a when I see G6 I think Pontiac. Let's stick with gen 6 or 6th gen. ;-)
Old 10-20-2015, 09:44 PM   #3
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
I think we can expect the same results. It is fairly clear GM is under pinning this car in HP and torque.
Sledgehammer70 is offline   Reply With Quote
Old 10-20-2015, 09:52 PM   #4
mcsoul
I bet top speed is around 175 or 180 without the limiter too.
Old 10-20-2015, 10:53 PM   #5
ULTRAZLS1
ULTRAZLS1's Avatar
nice mph
The bone stock on stock tire stingray record is at 11.3 I believe.
Old 10-29-2015, 03:11 PM   #6
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Dont forget this is a hero and record run. just look at some boltons C7 fast list; not so many reached this 'stock' mph.
But yeah an agressive full custom tune should yeld good result! CAI and tune with auto is gonna be an easy 11sec car I think.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 11-03-2015, 09:47 AM   #7
10mm_
Drives: 2015 Stingray (on order)
I can't see the video at work but I have a Stingray and spend a lot of time on the C7 forum and I would think 6th gens are gonna run high 11's bone stock. I ran 11.52 in my car bone stock in cool air.
What tires are they going to put on 6th gens? I know the PSS are amazing on my car, if the camaro tires aren't as sticky it may hurt them a little.
If you want to go fast in the 1/4, buy an auto.
10mm_ is offline   Reply With Quote
Old 11-11-2015, 08:36 PM   #8
matt55
matt55's Avatar
Drives: CTS-V
I've seen a stingray A8 cai tune and DR on stock wheels in +1300 da 68° = 11.4@120 with 1.7 60' Oct 15 Fayetteville.
Same car + E85 new tune ran 11.2@124mph 1.7 60' in -400 da 56°.
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
matt55 is offline   Reply With Quote
Old 12-09-2015, 09:24 AM   #9
mcsoul
Does the gen 6 SS get the same fuel pump as the stingray?
Without forced induction would the gen 6 setup benefit from a dual pump system at all?
