Old 10-19-2015, 08:13 PM   #1
captainjpc
captainjpc's Avatar
Drives: Scion FRS
Performance number for the T4
Hey, I just noticed something while reading the perfomance figures released by GM. The turbo 4 has worse numbers then the v6 in every category. But if you realise the four cylinder was tested without the RS package it was on the 18 inch all season tires. My question is with the better rubber on the RS package wouldnt the 4 cylinder out brake and out corner the V6 since it is lighter? Did GM intentionally do that to not show the T4 is a better performer?
Lemme know what you guys think. I want to order one in the spring but still hesitant whether I go with the T4 or V6.
captainjpc is offline   Reply With Quote
Old 10-19-2015, 08:20 PM   #2
newb
newb's Avatar
Drives: 2013 1LE
There may be a small gain in better rubber but the extra weight of the 20's will probably negate it. The 18's on either engine is probably the faster option.
The turbo 4 should be slower in a bone stock configuration. It does offer a wider range of tuning options however.
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 10-19-2015, 08:34 PM   #3
laborsmith
Drives: 1969 Corvair, 2018 Camaro T4 RS
The LT RS tire is also an all season.
Laborsmith
laborsmith is offline   Reply With Quote
Old 10-19-2015, 09:00 PM   #4
KMPrenger
KMPrenger's Avatar
Stock for stock, with same rubber, the V6 is going to be a tad faster than the t2.0, if not for the simple fact that it has a lot more top end power. From a drag I'm sure they are close, but as MPH climbs that V6 is going to pull away surely.
But with a tune, that 2.0 is going to be a fun machine and will easily put a stock V6 behind it....not that I don't think a modded V6 would be awesome either. It would be!
Old 10-19-2015, 10:57 PM   #5
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
It should.... The I4 is the stock motor and the V6 is an upgrade. If the V6 under performed, why would anyone upgrade?
But overall. sure some fresh good rubber might help, but with the I4, I doubt the difference could be tangible unless you boosted the turbo itself.
Sledgehammer70 is offline   Reply With Quote
Old 10-19-2015, 11:05 PM   #6
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
Where did you find the stats for the t4?
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 10-19-2015, 11:26 PM   #7
captainjpc
captainjpc's Avatar
Drives: Scion FRS
http://media.chevrolet.com/media/us/...14-camaro.html
This is the link
Old 10-20-2015, 12:24 AM   #8
kain279
Drives: 335i
I just don't see any easy performance gains with the V6. I really think it will have the least "mod potential" of all 3 engine offerings.
kain279 is offline   Reply With Quote
Old 10-20-2015, 12:53 AM   #9
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
3 words:
Power
to
Weight
Going from 275 hp to 335 hp (+22%) is going to influence performance a lot more than going from ~3435 lbs to ~3335 lbs (-3%)
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 10-20-2015, 06:52 AM   #10
NASTY99Z28
Thank you sir.
Old 10-20-2015, 06:56 AM   #11
NASTY99Z28
I'm not sure why I'm so excited about a turbo 4 in a camaro. So far we know the ecoboost can reach 500/500 before the engine starts to let go so I hope the lil boosted Duke can do the same or even better.
Old 10-20-2015, 07:40 AM   #12
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
I think the RF3s might bring the 60-0 braking and lateral G numbers up to the V6 values. The weight difference is probably not enough to make the better, though.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 10-20-2015, 08:30 AM   #13
KMPrenger
KMPrenger's Avatar
You are correct...it will. But I still think with bolt ons and a tune taking that sucker to an easy 350+ HP, it will be a hoot to drive.
The HP to weight ratio on a 350HP 3,450 pound V6 would be virtually the same as the 2015 SS automatic. That's something to think about.
Old 10-20-2015, 08:32 AM   #14
Imp
Dodges all the cones
Imp's Avatar
Drives: Soon
Originally Posted by DGthe3 View Post
3 words:
Power
to
Weight
T4 = 12.13
V6 = 10.25
V8 = 8.28
Lower = better.
That said, there are some benefits where adding lightness adds a fairly decent benefit over just looking at the ratio, especially when considering just where that power comes on, and the driving dynamics one is looking for.
--kC
Imp is offline   Reply With Quote
