dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 09-30-2015, 05:53 PM   #1
Firebreed
Got Boost?
Firebreed's Avatar
Drives: 2011 1SS/RS M6 SLP TVS 2300
A/c
So, I've been chasing down a charging problem with my camaro for months now. This past weekend I started her up. Turned on the a/c, and l started smelling like i smoked the clutch.... and then the a/c srarted blowing warm. Immediately the car was charging like it did before I was having charging problems.
Only thing I can think off that might draw enough amps to even cause the excessive draw would be the a/c compressor. Since I'm not a expert in a/c systems is there anything else in the a/c circuit that could potentially be the culprit? Also, the hvac fan is still working so I can rule that out.
Sent from my SM-N915V using Tapatalk
2011 1SS/RS M6
MOD List: SLP 2300 Supercharged, Flowmaster AT Cat back, aux 4 guage cluster, 12" kicker sub and Kicker Zx400.1 amp, PFADT Lowering springs
CAI Inc. CAI, Hurst Short throw shifter, JBA 1 7/8 Long tube headers.
Future Mods: 416ci stroker.
Firebreed is offline   Reply With Quote
Old 09-30-2015, 06:34 PM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Compressor is belt driven. Only power it uses is to engage the clutch. Not a big power drain.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 10-01-2015, 02:36 PM   #3
Firebreed
Got Boost?
Firebreed's Avatar
I know the compressor is belt driven, and that the only electrical power it uses is to engage the clutch. My biggest question is, what in the A/c system can cause a large enough drain before it burns out? With my charging system working properly now that the a/c went out my only conclusion is that something in the A/C system was causing my issue.
2011 1SS/RS M6
Old 10-01-2015, 03:19 PM   #4
orbitearl
orbitearl's Avatar
Drives: 2010 r/s switchblade metalic
My shaft broke on my 2010/RS .clutch still turned but no a/c .does your blower still work ? does your a/c clutch on front of compressor turn?
orbitearl is offline   Reply With Quote
Old 10-01-2015, 04:47 PM   #5
Firebreed
Got Boost?
Firebreed's Avatar
I did not verify the clutch operation, my blower still works. I'll verify the clutch on monday since I'm out of town for work for the rest of the week. Any other ideas?
2011 1SS/RS M6
Old 10-02-2015, 04:11 PM   #6
cajun1le
The Mechanic
cajun1le's Avatar
Drives: a sports car
What do you mean by burns out? Can you see if the compressor is engaging? Does your windshield have a oily haze on it? Is the odor present before you start the car?
It's hard to tell from the other side of the internets without a little more information.
cajun1le is offline   Reply With Quote
Old 10-06-2015, 02:39 PM   #7
Firebreed
Got Boost?
Firebreed's Avatar
Alright so was able to check the clutch today it is not engaging. Anybody have the voltages for the clutch engagement?
2011 1SS/RS M6
Old 10-09-2015, 10:28 PM   #8
cajun1le
The Mechanic
cajun1le's Avatar
Should be 12-14V or whatever the voltage regulator is allowing for. What's the resistance from the cluch lead on the compressor to ground?
Old 02-17-2016, 12:33 PM   #9
Firebreed
Got Boost?
Firebreed's Avatar
Ended up being the shaft freezing up.
Sent from my SM-G920V using Tapatalk
2011 1SS/RS M6
