Old 09-16-2015, 06:58 AM   #1
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Early LGX Information
I thought I would kick off the LGX section now that we've seen the performance numbers. Hopefully we'll start seeing some bolt-ons real soon.
  • The 3.6 liter V6 LGX engine is GM’s new high-feature V6 engine. It is a clean-sheet design and shares little with the 3.6L six-cylinder LFX engine it replaces.
  • The LGX sets benchmarks for efficiency, refinement and durability compared to the LFX it replaces. LGX highlights include:
  • Aluminum deep-skirt cylinder block from the LFX mill
  • An enlarged bore of 95 mm (compared to 94mm on the LFX)
  • Enlarged bore centers of 103mm (compared to 106mm on the LFX)
  • An all-new cylinder head design
  • A forged steel crankshaft
  • High-strength connecting rods and pistons
  • Oil-spray piston cooling
  • Active Fuel Management (cylinder deactivation) and Auto Stop-Start system generate fuel savings of 9 percent compared to the 3.6L V6 LFX
  • Improved Variable Valve Timing (VVT) with an ‘intermediate park’ feature
  • Reshaped piston tops to promote a better mix of the air and fuel during the direct injection process
  • Relocated oil pump under the cylinder block and inside the oil pan
  • Acoustic engine cover
  • Stronger, stiffer aluminum block with increased structure in the bulkheads for superior rigidity
  • Tough, refined rotating assembly with a stiff forged-steel crankshaft, friction-reducing polymer-coated pistons and strong high-copper-content, sinter-forged connecting rods
  • New four-cam phasing system with intermediate park technology that enhances efficiency by enabling late inlet valve closing in certain conditions
  • All-new, patented “targeted” cooling system that provides strategic cooling of the engine’s hottest areas while simultaneously fostering faster warm-up to enhance efficiency
  • New, higher-flow cylinder heads that enhance direct injection performance and feature integrated exhaust manifolds
  • Revised, simplified timing drive system with cushioned chain sprockets contributing to quieter engine operation
  • All-new lubrication system with a variable-displacement, two-stage oil pump that enhances efficiency. It is located inside the oil pan, which contributes to greater noise abatement
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 09-16-2015, 07:38 AM   #2
cyberbro
cyberbro's Avatar
Drives: Not a Camaro at this time
It's really the all around star if your looking for performance and MPG.
Order Status:
2000 8/27/15
3000 9/3/15
2000 9/22/15 (Order changed)
2016 2SS With Auto, NPP, MRC, Nav, Split 5 Spoke Bright Aluminum.
cyberbro is offline   Reply With Quote
Old 09-16-2015, 09:12 AM   #3
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Start stop feature is nice for fuel savings.
Old 09-18-2015, 11:02 AM   #4
KMPrenger
KMPrenger's Avatar
I'll be part of the V8 crowd this time around, but you can bet I'll be checking in on you V6 peeps!
Here's what you want:
-intakes
-tunes
-ported throttle body
-ported or filled intake manifold
-high flow cat and catless pipe
-intake manifold spacer (1/2 to 3/4")
OK....no whos going to make this stuff for the V6 crowd.
Just some of these and you guys will be giving stock 5th gen L99s a hard time.
Old 09-20-2015, 01:16 AM   #5
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
People are going to hate this auto stop feature trust me. I hate it on my Malibu so I disabled it.
Hopefully GM will allow the V6 Camaro peeps a way to disable this feature if they want.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 09-20-2015, 06:26 AM   #6
Back in blk
Back in blk's Avatar
Drives: Black 2014 1LT RS
Kaboom I agree with you that auto stop start blows.
Back in blk is offline   Reply With Quote
Old 09-20-2015, 09:35 PM   #7
KMPrenger
KMPrenger's Avatar
Just leave the car in Sport mode lol. (yes I know...not the best solution)
Old 09-21-2015, 04:15 PM   #8
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Yeah, not being able to turn that off would be a deal breaker for me.
Emoto is offline   Reply With Quote
Old 09-22-2015, 04:54 PM   #9
GTIanZ28
Drives: 2016 V6 RS Camaro 6MT
Is the auto stop/start feature on both Manual/Automatic?
Has there been any research done as to whether or not this is actually bad for the engine? Sure it must be hard on starters.
I live in a city and deal with the constant traffic issues and traffic lights. Think it would drive me insane.
GTIanZ28 is offline   Reply With Quote
Old 09-25-2015, 11:50 AM   #10
fradaj
Drives: RS
I was watching a video about a 1969 428 Super Cobra Jet Mustang the other day, it was rated at 335HP, the same as the new V6.
fradaj is offline   Reply With Quote
Old 09-26-2015, 04:37 PM   #11
Wikedwil
Co-founder of CDCNY
Wikedwil's Avatar
Drives: 2016 Camaro 2LT Hyper Blue
What exactly is that? The engine shuts off?
Wikedwil is offline   Reply With Quote
Old 09-26-2015, 06:40 PM   #12
ssrs2lt
ssrs2lt's Avatar
Drives: too many
Yes the engine shuts off at stops..some manufacturer s have it on the manual transmission as well. Its super annoying just my opinion..
Old 10-29-2015, 10:47 PM   #13
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
-intakes
-tunes
-ported or filled intake manifold (Working on it! I have an LGX intake on hand now!)
-intake manifold spacer (1/2 to 3/4") (Probably not gonna happen, due to the layout of the intake ports (angle) on the heads and the bottom of the intake, it would be expensive to manufacture, I don't see anyone tackling the project in the near future. However, the intake already appears to have quite a bit longer runners than the LFX, this thing is super tall, like GM gave a big finger to everyone that's been making spacers since 2010, so the spacer may not even be needed for it's traditional purposes, GM did something right on this intake in a big way, and a lot of ways, but I can still make it better!)
See my responses to the above in red. I'm pretty sure spacers are a no go, at least at the moment. The intake runners are quite a bit longer... Unless you just wanted an all out torque monster, I don't think the spacers are good, Unless they put the LGX in the Colorado.
I'm working on the porting/filling of the intake right now, right out of the box, it's 12% better than the stock 12-15 LFX manifold, but 10% worse than my modified LFX intake manifold.
I'm just starting to play with it, but I've got a feeling that I can get it to flow at least as good as the ported LFX intake manifold, if not 2x better. This intake manifold is built to flow, it just needs a little helping hand.
You know what's funny about this? There is speculation that the 6th gen v6 may run a 13.3ish 1/4 mile time. An old family friend had a fully restored cream puff 1970 Mach 1 w/ a 428 SCJ, bone stock. That's real close to what it would run on a good day... It made me extremely happy to beat him repeatedly with my low budget SBC 355 in a heavy 71 Chevelle that was 4 different colors.
Old 12-14-2015, 03:34 PM   #14
booger78z28
booger78z28's Avatar
Drives: Waiting on my Hyper '16
How did you do that ? tune, Range?...
1978z28 Original paint 355 solid roller 4 speed
2016 Hyper Blue 1LT RS package with all the goodies
Sold 6/20
12/10/21 bought a Silver Ice 2SS 6 speed with 40k
booger78z28 is offline   Reply With Quote
