TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 08-09-2015, 10:56 PM   #1
fradaj
Drives: RS
Has anyone replaced the serpentine belt?
Has anyone replaced the serpentine belt? Did you replace it yourself or did you have a mechanic do it? How many miles did you have on the car? What was the reason you replaced it? The belt on my car still looks good but I am just wondering how long it should last.
fradaj is offline   Reply With Quote
Old 08-10-2015, 04:43 AM   #2
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Belt should be good for 100K. I plan to replace mine at that time along with the spark plugs, hoses, coolant, and trans fluid. All general maintence. Sometime next summer, as I am at 77K right now.
rtcat600man is offline   Reply With Quote
Old 08-10-2015, 07:50 AM   #3
mhog
mhog's Avatar
Drives: 2010 V6 Camaro 2LT/RS
It's very easy to do yourself. If I remember correctly all you need is a 1/4" ratchet to release the tensioner. Remember the belt configuration to get the correct pattern.
mhog is offline   Reply With Quote
Old 08-10-2015, 09:16 AM   #4
mhog
mhog's Avatar
Picture:
Old 08-10-2015, 11:45 AM   #5
fradaj
Drives: RS
The link did not work for me.
Old 08-10-2015, 11:50 AM   #6
fradaj
Drives: RS
Thanks for the info. Probably why I am so concerned about it is because I had a 1979 5.0 Mustang with the serpentine belt and I had several belts wear out and also come off while I was driving. They have come a long way since 1979, I believe the Mustang was one of the first to have the serpentine belt, the first that I had ever seen.
Old 08-10-2015, 11:56 AM   #7
fradaj
Drives: RS
I could probably do it my self. I will take a closer look and see just how hard it will be to get at the tensioner and decide whether I want to take it to the dealership garage to have it done. But I also do not want to replace the belt if it is not necessary. My car has 39,500 miles on it.
Old 08-10-2015, 02:46 PM   #8
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
I would recommend a gator back belt.
Lil' Nasty is offline   Reply With Quote
Old 08-10-2015, 02:58 PM   #9
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
I bet if you spend ten minutes looking at your motor, you will decide to do this yourself. Doesn't get much easier than this. Only thing easier is filling it up with gas.
Old 08-10-2015, 04:06 PM   #10
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
I keep a spare Gator Back Belt in the spare tire well in the trunk,JIC it breaks while I'm away from home. I bought it on AMAZON.com for about $15. 1/4 inch ratchet is all you need to put it on.
Eddiefuzz is offline   Reply With Quote
Old 08-10-2015, 04:46 PM   #11
mhog
mhog's Avatar
That link was that picture of the belt configuration.
Old 08-10-2015, 05:26 PM   #12
7171tk
Drives: 2017 1SS I LE
With only 390 on it it should be good for a while.
7171tk is offline   Reply With Quote
Old 08-10-2015, 05:27 PM   #13
7171tk
I meant 39k
Old 08-10-2015, 07:15 PM   #14
fradaj
Drives: RS
Originally Posted by 7171tk View Post
I meant 39k
rtcat600man has 77K on his, so I should be OK for a while.
