07-29-2015, 10:03 AM | #1 |
Drives: Camaro Justice Join Date: Jun 2007
V6 Outboard Mount Rear Sway Bar Available at JPSS
When we designed our sway bars, we paid special attention to the needs of the V6 community. We tucked the ends of our rear sway bar in just enough to clear the banjo bolt on a V6 brake caliper. Our bars are 27mm adjustable front and 32mm rear solid.
This is a 1LE running with JPSS sway bars. When the 2010 5th Gen was released with the inboard bar, it understeered / pushed badly when driven hard. A smaller front bar with a big rear bar improved the performance, but nothing like the GM engineering change to relocate the sway bar closer to the wheel on the ZL1. If you have upgraded sways, you can replace your rear bar with a JPSS bar and see a huge improvement. If you are on stock V6 bars, installing a JPSS set of bars will be transformational. JPSS bars for that fit the V6 are in stock ready to ship today. You can read more about JPSS bars for your V6 here: http://www.jpssonline.com/#/jpss-black-magic-sway-bars/ |
08-05-2015, 12:55 PM | #2 |
Got mine!
Drives: 2021 LT1 RS - Orange Crush Join Date: Mar 2011
Very interested, please provide additional info for front and rear sway bar set up. I dont see pricing on your website!
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
09-26-2015, 09:40 AM | #3 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
Already having the pfadt sport setup, the adjustability is all done from the rear.
If I were to add the jpss outboard rear only bar, FIRST...would handling be so extreme as to be unmanageable? As an example, those who only upgrade the rear at first, but run a stock bar.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
09-26-2015, 09:42 AM | #4 | |
The JPSS 32mm rear with the Pfadt front would bet a really good setup. Are you square or staggered? |
09-26-2015, 02:48 PM | #5 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
09-26-2015, 05:02 PM | #6 | |
happy to see a setup where you don't have to change the rear brakes finally!
09-26-2015, 05:04 PM | #7 | |
09-26-2015, 05:42 PM | #8 | |
2x?lol, just messin, but I'm more a 4-5XL type. We usually call it a "Samoan xtra-smedium" might have to make it down to VA in the future if you all have an open house or something.
09-26-2015, 06:25 PM | #9 |
Drives: 2015 Black 2LT RS M6 Join Date: Aug 2015
I'll be buying a set before the end of the year.
09-26-2015, 09:25 PM | #10 | |
XXXXXL got it! |
