Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 07-27-2015, 11:38 PM   #1
25thanniversary
25thanniversary's Avatar
Drives: 92 Camaro Convt RS,2011 Camaro RS
Engine Cover Question
Just wanted to know if removing my engine cover would be better for my engine? Since I'm in deep South Texas the temperature has been hitting 110 or so. Should I remove it or leave it the way it is?
TEAM LLT
1992 Camaro Rs Convertible
2011 Camaro 1lt Rs
25thanniversary is offline   Reply With Quote
Old 07-28-2015, 04:49 AM   #2
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Take it off, the cover traps heat, keeping things hotter. I always took mine off when I went drag racing. Now it just stays off permanatly.
rtcat600man is offline   Reply With Quote
Old 07-28-2015, 04:59 AM   #3
Red2014SS
Red2014SS's Avatar
Drives: 2014 2SS/RS Camaro
I ditched mine the first week I owned the car. It does nothing, traps heat and gets in the way.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH
Red2014SS is offline   Reply With Quote
Old 07-28-2015, 11:48 AM   #4
SSJ455
SSJ455's Avatar
Drives: "Kara Zor-El" 2017 2SS HBM
I took mine off just recently. I haven't noticed a change in engine temp, the dial on the guage doesn't seem to be in a different location.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!!
What?
Dangerzoooooone.
SSJ455 is offline   Reply With Quote
Old 07-28-2015, 12:25 PM   #5
RubyCamaro
Jan
RubyCamaro's Avatar
I have not had mine back on since adding the Black Iceolator. Like others said, why do I need something trapping in more heat? It is now a wall décor in my garage.
Old 07-29-2015, 02:32 AM   #6
25thanniversary
Thanks for the input guess I'll be removing it.
TEAM LLT
2011 Camaro 1lt Rs
Old 07-29-2015, 03:11 AM   #7
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Are you running hot? I dont see the point, other than aesthetics. Unless you guys are seeing notable temperature changes with the cover off, then why bother? I guess we can all do as we please, and hell in the end, who cares. Thing is, I have yet to read one thread about someone changing their engine temp by removing their engine cover. Granted I have not read the whole internet, but I'm working on it.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 07-29-2015, 04:36 AM   #8
rtcat600man
Taking it off does not help alter the engine temp. as you pointed out. But it will help let the heat escape away from our aluminum intake manifold quicker. After adding my ice-olater and plenum spacer, the height started getting to the point I figrued just leave it off all the time, and paint the manifold.
Old 07-29-2015, 08:34 AM   #9
Red2014SS
Red2014SS's Avatar
Average engine temps won't change, but the engine will cool down faster without the cover. That makes a difference in hot temps and at the strip.
Old 08-14-2015, 12:49 AM   #10
fradaj
Drives: RS
I didn't like the look of the cover so I took it off. I also installed the black isolator so I would have had to modify the brackets to re-install the cover. I also removed some of the rubber strip below the cowl hood to let cool air into the engine bay, which blows directly on the top of intake manifold and the top of the engine around the intake manifold.
fradaj is offline   Reply With Quote
Old 04-12-2016, 06:52 PM   #11
NOVAK
NOVAK's Avatar
Drives: 2015 ZL1
What type of paint did you use on your intake manifold?
NOVAK is offline   Reply With Quote
Old 04-19-2016, 01:25 PM   #12
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
How about this thing? I don't even know what it's called but it's the thing the back of the engine cover plugs into, and last year at Revyfest an enterprising rodent decided it loved it enough to eat some of it. What's it called? and will it be okay without it on until I order a new one?
Tori
click the sig pic to view my build thread
heRS is offline   Reply With Quote
Old 04-19-2016, 01:41 PM   #13
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
You are fine without that.
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 04-19-2016, 06:02 PM   #14
heRS
Raised by Wolves
heRS's Avatar
Nice - that's good to know. I do show it with the engine cover though, and I still would like to find out what the darn thing's called if anybody knows.
Tori
