Old 07-27-2015, 06:45 AM   #1
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
SS performance numbers when?
When do you think we might get performance numbers on the SS?
2012 Victory Red ZL1
Lingenfelter 630 Package "Plus"
592 HP/580 TQ
BoostedX2 is offline   Reply With Quote
Old 07-27-2015, 06:58 AM   #2
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
I'd expect to see them shortly before they start hitting the dealers. They'll usually start sending production cars out to the big name reviewers (C&D, R&T, etc) So, maybe a couple more months?
Curr is offline   Reply With Quote
Old 07-27-2015, 07:53 AM   #3
mt3130
Drives: Coupeless :(
Easy, just look at the C7 numbers. The Camaro numbers should be nearly identical.
mt3130 is offline   Reply With Quote
Old 07-27-2015, 08:35 AM   #4
Jeffro19
Jeffro19's Avatar
They will different for sure. Corvette is much lighter. I'm guessing 0-60 in 4.2 and 12.3 for the 1/4 mile for the auto equipped car.
Old 07-27-2015, 08:42 AM   #5
BahamaTodd
BahamaTodd's Avatar
Drives: 08 Accord V6/M6 / 04 Canyon Z71
The Camaro is 400+ lbs heavier than the Vette.
BahamaTodd is offline   Reply With Quote
Old 07-27-2015, 08:50 AM   #6
SpeedIsLife
Drives: Current Camaro-less
Nah
Old 07-27-2015, 08:53 AM   #7
fastball
Drives: 2017 Camaro 2SS 6MT
If that were the case there would be no good reason to buy a Corvette.
The Corvette is made out of lightweight aluminum alloy and carbon fiber with advanced aerodynamics. The Camaro is mostly steel.
You are not going to have nearly identical performance numbers.
fastball is offline   Reply With Quote
Old 07-27-2015, 09:20 AM   #8
tpmotorsports
tpmotorsports's Avatar
Drives: Camaros
The old drag racers rule of thumb is for every 100 lbs. of weight you can expect 0.10 in 1/4 mile times. Obviously a lot comes into play.
If the Camaro SS is 400 lbs. heavier than the Z51 expect 0-60 times of 4.1 and 1/4 mile times of 12.4.
'17 ZO6 - Watkins Gray Metallic
'17 911 4GTS - Carmine Red
'17 Bolt - Hyper Blue
'02 SS - 35th Anniversary Ed. - 645 miles
'89 IROC Z - 2500 miles
'73 Z28 - Survivor 36k miles
'69 RS/SS 496 - 631 HP 618 TQ
'67 SS - Alum. 406 under construction
tpmotorsports is offline   Reply With Quote
Old 07-27-2015, 09:27 AM   #9
Cody6.2
Drives: 2012 Camaro 2SS
That "rule" would apply to changes made on the same vehicle.
Cody6.2 is offline   Reply With Quote
Old 07-27-2015, 09:45 AM   #10
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Typically that info gets released right around the start of production, often the same day.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 07-27-2015, 09:52 AM   #11
whiteboyblues2001
whiteboyblues2001's Avatar
MotorTrend just tested the ATS-V (actually two of them). Here are the numbers:
Manual Coupe: 0-60 4.2 sec, 1/4mile 12.6 @ 114.2 (Curb Weight 3754 lbs.)
Auto Sedan: 0-60 3.7 sec, 1/4mile 12.1 @ 116.2 (Curb Weight 3788 lbs.)
The ATS-V has the LF4 engine with 464 HP and 445 lbfttq
Your numbers seem close, but I think we might see a better 0-60 time than 4.2 for the auto. Only time will tell...
whiteboyblues2001 is offline   Reply With Quote
Old 07-27-2015, 10:16 AM   #12
mt3130
My bad guys, when I read that, I was thinking dyno numbers, which I would expect to be nearly the same.
I think the estimates you are seeing above are probably pretty close to where the final numbers will lie.
Old 07-27-2015, 10:25 AM   #13
IOMike
Drives: 2022 F150, 87 Monte Carlo
I think the Camaro will be about 300lbs heavier, option for option. Isn't a loaded stingray about 3450?
IOMike is offline   Reply With Quote
Old 07-27-2015, 10:33 AM   #14
SSport16
SSport16's Avatar
I think it will be close to the Stingray, 0-60 probably 3.9 - 4.0. Didn't Mark Reuss say the SS would be very similar to the current ZL1 in almost every aspect? The ZL1 is like 3.9 with the auto, and not especially with the newer A8, I am thinking he could be right.
