![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
6th gen V6 A8 as fast as 4th gen LS1?
Sounds a bit far fetched at first but when you start looking at the two on paper it starts looking closer to reality than fantasy. Well, that is if AL O's promise of a 300lb weight reduction holds true on the V6 model. The LS1 kills the V6 on torque but the superior gearing/shift time/shift recovery could balance that equation (maybe). Let's take a look at the known specs and compare.
1998-2000 base Formula/Z28- Curb weight-3425lbs Power-335HP/350TQ 4L60E gear ratios with the 3.23 rear gear multiplied- 1st-9.88 2nd-5.24 3rd-3.55 T56 gear ratios with the 3.42 rear gear multiplied 1st-9.09 2nd-6.08 3rd-4.44 4th-3.42 2016 Camaro V6- Curb weight-3407lbs(projected base) Power- 335HP /284TQ 8L45 gear ratios with a 2.57 rear gear ratio multiplication (the 2.57 ratio is to account for the different tire height) 1st-11.87 2nd-7.81 3rd-5.31 4th-4.26 Will the superior gearing, shift times and shift recovery be good enough to overcome a 66lbs of TQ disadvantage? We will have to find out. I don't think it will but I do think it will end up being damn close. Like only a couple tenths and mph. To give you an idea of how fast the new V6 could potentially be the hero ET runs for a 4th gen LS1 F body are in the high 12's with hero traps in the 108mph range. Most everyone into cars has read about or heard of the Evan Smith piloted bone stock 1999 Z28 that ran 12.8 and the 2001 SS that ran a 12.9 (the SS's run was in positive DA summer heat BTW) but there are many other LS1 f body cars that ran high 12's as well by private owners. Even 1 or 2 A4 cars did it although the M6 cars were faster with the right driver. If the weight holds true I think V6 hero times could be in the low 13's and that is pretty damn quick for a lower model Camaro. If I get a 6th gen it will be a SS or bust but this is meant to excite those of you who are looking at getting a V6.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
![]() Drives: 2012 Camaro 2SS Join Date: Feb 2012
It's pretty common knowledge that the BHP of the LS1 was 350 across the board. So using 335hp for comparison sake is already skewing the figures. On top of that GM can dream all they want but no 2016 is going to hit a curb weight of 3400lbs.
#3 | |
You prepared to eat those words about curb weight? Pretty sure he said the base 4 and 6s will be as much as 300lbs lighter than the comparable 5th gen models, with extra the technologies.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
#4 | |
![]() ![]() ![]() ![]() Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
More like 330 then 345hp. I highly doubt we will see 12.99 from a v6 6th gen hero run. 13.3 is my guess, for a hero run. |
![]() ![]() ![]() ![]() Drives: 99z28 with bolt-ons and a mwc fab 9 Join Date: Jul 2012
I've been saying it should run with most stock ls1 cars and even stock v8 5th gens and each time people either laugh or say Im "reaching". On paper it should be good but we won't ruly know till it puts down some real times. Really exciting to see the possibility of v6 cars running that strong. Good times indeed.
I like my woman like my milk shakes, THICK!!!!
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
#7 | |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 21 Bronco Join Date: Jun 2012
Wasnt the LS1 in the 99 Z/28 "rated" at 315HP and the SS "rated" at 325HP?
Just like the Trans Am was 315 and the WS-6 was 325? |
#9 |
As potent as the ls3 cars are they are also harder to launch so auto vs manual could make for a run with an iffy launch on the SS. I'm just glad the 6th gen gets the full power with an auto this time around. I always felt gm screwed up on that aspect with the 5th gen.
#10 | |
'01-02 - 310HP and 325HP
#11 |
![]() ![]() ![]() Drives: 2002 Z/28,1968 Chevelle convert. Join Date: Oct 2010
I'd be willing to run against anyone who buys a 6th Gen V-6 ...... I have a 4th Gen Z with LS1 4-speed Auto ....... I haven't ran my car recently at the track but when I did I was able to run consistent low 13s ( 13.12@106 was best time and did a 13.2x on numerous occasions) .......... I'm near ATCO but I live in Phila .... PM if anyone wants to test the ruggedness of the 6th Gen V-6 .......
#12 |
I will tell you, the 4th Gen cars are very light and I doubt the 6th Gen V-6 will be anywhere near the 3,400lb mark, my guess is the V-6 will be somewhere in the ballpark of around 3,605lbs ..... I had my 2002 Z28 weighed and it comes in @3,370lbs ...... granted mine has Zero options like Zero power everything .... that was the way it was ordered when new
#13 | |
#14 |
![]() ![]() Drives: Chevy Join Date: Mar 2015
