05-30-2015, 10:12 AM | #1 |
Af ATS-v get old LS7 this means no LT7 plans?
This is old news buy I really was hoping GM could still manage to make a 427 engine for the LT series, do this mean there is only going to be 2 engines for the LT line of engines?
Also, if the ATS and the camaro share the same platform, why the 7 speed manage to fit there wile It didnt fit in the camaro? Finally can some one confirm a rumor of the ZO6 was originally intended to be with a 427 (LT7) but it failed in the emissions test so they swapped to a 6.2 FI engine?
01 SOM A4 Z28 / 15 Mustang A6 50th anniversary
XXXhp 460hp |
05-30-2015, 10:35 AM | #2 |
Drives: 2021 300 Join Date: Jan 2015
They stopped the production of the LS last year and closed the plant. The only plant that builds GM's v8 is Tonawanda and the only two V8 engines they are producing are the LT1, LT4. Café' and emission's have changed in 2016 and will change in 2018. The LS motors are finished.
The rumor I read in the stock trades was there was so many Ls7's in inventory and they new several years ago that the motor was obsolete they used it for the Z/28 to deplete the stock. The catch 22 is that the sale of the Z/28 died and they are going to take a financial hit. |
05-30-2015, 10:40 AM | #3 |
Drives: 1969 Corvair, 2018 Camaro T4 RS Join Date: Mar 2009
BGAP is now or is about to assemble some engines and it is very likely each engine will have eight cylinders.
Laborsmith |
05-30-2015, 10:47 AM | #4 | |
Drives: Current Camaro-less Join Date: Jul 2014
GM is preparing to do something new with the Corvette, they just invested even more money into Bowling Green's paint shop and production lines, which would not be necessary unless something fairly huge was coming since it handles the current Stingray and Z06 just fine. Unfortunately the days of high winding N/A V8's are coming to a close. Ford has said it was "more challenging than normal" to get the 5.2 FPC motor for the GT350 to pass emissions, that's after the 5.8 Trinity in the last gen GT500 which I doubt was a walk in the park. |
05-30-2015, 11:01 AM | #5 | |
Moderator.ca
The rumor of an ATS-V+ has already been killed. No 7 speed LS7 ATS-V.
Motor Authority: Quote:
Allegedly, the problem was that they couldn't meet their performance targets and emissions with the NA engine. I doubt anyone outside of GM knows what exactly their goals were, but it probably involved 600+ hp. They then had 3 options: 1) use some expensive finagling to try and get everything to work with a NA engine (not sure if this is possible), 2) dial back the performance goals to keep the engine emissions friendly 3) go forced induction. They went with choice #3 Also, just because an engine won't meet emissions doesn't mean that it failed an actual emissions test. Computer simulations can tell you if an idea is even feasible in the first place before detailed design takes place (which can also be run through a simulation). For all we know, the idea could have been shelved or outright killed once they plugged the basics of what the engine would entail into the model. Its unlikely, given the timeline of the Z06, that there was a detailed 'LT7' engine design all ready to go that was just a bit too hot for the EPA
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
05-30-2015, 11:19 AM | #6 |
Who said anything about the M7 not fitting?
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
05-30-2015, 11:28 AM | #7 | |
Moderator.ca
You seem to be insinuating that the money at the Corvette plant is going towards something different (presumably a mid-engined car). The line at the Corvette plant is setup to build front engine, rear drive cars. It would take a massive investment (think billions, not millions) and a prolonged shutdown to allow it to build anything different. Additionally, every now and then emissions regulations tighten for manufacturing facilities (just as they do for car engines), and the main source of emissions at a car plant is the paint shop. Might even be paint-specific regs, I'm not sure. So OEMs regularly need to make a few upgrades to keep with the times. I think that has a lot to do with why GM made 3 announcements involving improved paint facilities in the span of about a week.
05-30-2015, 11:42 AM | #8 | |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
And too lazy to go find it, but it was asked at the reveal and an engineer was quoted as saying the 7 speed wouldn't fit. So Corvette exclusive I guess.
05-30-2015, 11:42 AM | #9 | |
"Maybe for painting a car where the engine is in a different location?" or something along those lines. |
05-30-2015, 12:02 PM | #10 | |
Rockcrusher
Drives: 2017 SS 1LE Join Date: May 2009
05-30-2015, 12:10 PM | #11 | |
"The new TR6070 is only 42-millimeters longer than the TR6060, and weighs only 4-kilograms more, Read more: http://www.superchevy.com/how-to/transmission/1307-first-look-tr6070-transmission/#ixzz3bdr47g48" Would it not be shorter than the A8? I can't for the life of me find a length on it. The M6 was around 30" from what I saw.
05-30-2015, 01:02 PM | #12 |
The 6070 center point distance is 85mm and the 3160 center point distance is 81mm.
I have no idea what center point distance means but it does look like the 7-speed is a bit bigger than the 6-speed. Laborsmith |
05-30-2015, 02:23 PM | #13 | |
Drives: 2019 Shock ZL1 Join Date: Jan 2007
Sure about that? LS engines are used today in Silverado/Sierra HD, Express/Savana, Commodore/SS and remaining Camaros still. LS production is far from stopped yet. Couple of years for most remaining vehicles? Maybe. Tonawanda produces more than just LT1 and LT4. They build LV3, L83 and L83 Ecotec 3 Gen V small blocks for trucks, and 2.0 and 2.5 Ecotec 4 bangers (ATS, Camaro (future), Malibu, etc). Truck Gen V small blocks are also built at Ramos Azripe Powertrain, and St. Cathrines Powertrain. L99 roll out of St. Cathrines, 6.0 (L96, L77), LS3 and LSA roll out of Silao, Mexico.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
05-30-2015, 03:29 PM | #14 | |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
