Old 04-30-2015, 12:51 PM   #1
stoopid
Drives: 4 wheels
Ford recalls, GM style
When it rains, it pours.
http://www.autoblog.com/2015/04/29/f...our-campaigns/
Ford is issuing recalls for a total of 591,177 vehicles worldwide, in four separate campaigns. The announcement comes just days after the discovery of door-latch problems in 390,000 of the automaker's cars.
The largest of these new recalls covers 518,313 examples of the Ford Fusion and Lincoln MKZ from the 2013-2015 model years, plus the 2015 Edge. Of these, 487,301 of are in the US and 31,012 are in Canada. For vehicles in cold-weather areas, the bolts that hold the steering gear motor can corrode and fracture. If this happens, it could cause the power steering to fail, but manual control would be retained. There are no reported accidents or injuries from this problem. To fix things, dealers will replace the bolts and seal them.
The next campaign covers 50,157 examples of the 2014 Focus, Edge, Escape, and Transit Connect, plus the Fiesta from 2014 and 2015. Of these, 45,505 are in the US, 4,618 in Canada, and 34 in Mexico. All of them exhibit a problem with the fuel pump where the nickel plating can cause the part to seize and the engine to stall, if this occurs. (All of which sounds like recent problems with Nissan and BMW models.) According to Ford, there is one allegation of an accident from this problem. Dealers will replace the fuel delivery module to fix the problem.
Ford is also recalling 22,616 units of the 2015 Lincoln MKZ because when the headlights are on, the parking lamps are brighter than they are allowed to be. The light could affect the vision of other drivers. This campaign includes 21,435 of them in the US, 1,066 in Canada and 115 in Mexico. There are no accidents or injuries from the issue, but Ford is updating the software to dim the lights on these sedans.
Finally, Ford has a safety campaign for 91 examples of the 2015 F-150 because an underbody heat shield might not be properly installed or not present at all, which can be a fire risk. There are no reports of any actual accidents or fires, though. The affected pickups will have the parts replaced or added, as necessary after a dealer inspection.
stoopid is offline   Reply With Quote
