Old 04-17-2015, 09:21 PM   #1
tswilie
Drives: 2006 Honda accord v6 6sp manual
2016 camaro 0-60 and 1/4 mile time
SS 7 speed manual
0-60 = 4.2
1/4 mile = 12.5
Anyone else want to predict the performance?
tswilie is offline   Reply With Quote
Old 04-17-2015, 09:40 PM   #2
RJZJR
Drives: in progress 3rd Gen BBC 4L80e fab 9
SS LT4 8SPD 10.95 120 mph ..w/DR 10.70
RJZJR is offline   Reply With Quote
Old 04-17-2015, 09:42 PM   #3
RJZJR
Old 04-18-2015, 08:24 AM   #4
xgnxs
xgnxs's Avatar
Drives: 2005 Cobalt Base - 5 speed
I'm no good at predicting quarter mile times, but I'd be so happy if the SS ran 12.5 or better all stock. I'd like to see a 3.9 0-60 time too, but that's probably unlikely.
xgnxs is offline   Reply With Quote
Old 04-18-2015, 11:14 AM   #5
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
assuming 440hp, and 3600lbs, im thinking 12.6's will be advertised, and us mere mortals will get 13.0's.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 04-18-2015, 11:17 AM   #6
ilirg
ilirg's Avatar
Drives: 2011 Camaro 2ss
Most mere mortals are getting 13s with the current ss. I think high mid 12s will be common with the a8 transmission.
ilirg is offline   Reply With Quote
Old 04-18-2015, 11:56 AM   #7
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
If the scat pack challengers can do mid 12s with an a average driver with their weight, a 460hp lighter camaro with the a8 should best that with an average driver too.
Old 04-18-2015, 07:46 PM   #8
obzidian
obzidian's Avatar
Drives: 98 camaro turbo
Faster than the stang!
obzidian is offline   Reply With Quote
Old 04-18-2015, 08:59 PM   #9
KMPrenger
KMPrenger's Avatar
V8: 4.2 and 12.5 (average driver upper 4s or low 5s, and mid to high 12s)
V6 5.2 and 13.5 (average driver mid to upper 5s and high 13s/very low 14s)
Old 04-19-2015, 09:42 AM   #10
tswilie
Here's my thumbnail analysis
1) Compare the Vette and Camaro performance with the LS3 mill as a baseline.
2) Assume the same jump in performance the Vette when LT1 installed.
3) Adjust for 200 lb weight reduction.
1) Baseline C6 Vette, G5 Camaro SS
Vette = 3300 lbs,436 hp, 430 tq
0-60 = 4.0, 1/4 =12.4
Camaro SS = 3900 lbs,426 hp, 420 tq
0-60 = 4.7, 1/4 =13,1
Delta 0-60 = .7 , 1/4 = .7
2) LT1 jump in performance
C7 vette 460 hp, 465 tq
0-60 = 3.8. 1/4 =12.0
LT1 Delta 0-60 = .2, 1/4 = .4
3) Weight performance bonus
Looking at the difference between the Vette and Camaro.
600 lbs and 0-60 = .7, 1/4 = .7
Let's assume the world is basically linear so it's approximately .1 sec per 100 lbs. so it's an additional . 2
So the numbers we have all been waiting for are......
Camaro SS (LT1) 0-60 = 4.3, 1/4 = 12.5
Old 04-19-2015, 10:08 AM   #11
mt3130
Drives: Coupeless :(
You factored in the weight loss for the Camaro, but not the 100 pound weight gain for the Corvette (base to base). We also already know that LT1 that the Camaro gets will be different from the one the Corvette currently has. At a minimum, it will get a tri-Y headers, which the Corvette's LT1 does not have (yet).
I'm going to guess 4.2 and 12.3
mt3130 is offline   Reply With Quote
Old 04-19-2015, 10:18 AM   #12
ChocoTaco369
145lb Powerlifter
ChocoTaco369's Avatar
Drives: 2013 Camaro 2SS RS LS3
I like this analysis.
I wonder how the gearing with factor in? With an 8-speed auto and 7-speed manual, the rear pinion gear should be a little more aggressive, but there will also be more shifting to take into play. I wonder if this would actually hurt times for manuals...more shifting and all...
The weight reduction seems to be largely unsprung as well. I wonder how that will impact times. If the wheel size is reduced from 20" to 19" that could be worth a tenth or two. I am really hoping the smaller chassis will roll out with 19" rims but it'll LOOK LIKE 20" rims on the current Gen 5 in terms of proportions.
ChocoTaco369 is offline   Reply With Quote
Old 04-19-2015, 11:18 AM   #13
tswilie
Thanks for the Vette weight gain miss,
I'm buying at 4.2 and 12.5
So we are basically better than an LS2 powered vette and a little slower off the line than an LS3 powered C6, not bad and we get sort of a back seat
Old 04-19-2015, 11:22 AM   #14
SPCBA
Drives: pleather and Chiclets
Lol sort of a shelf
SPCBA is offline   Reply With Quote
