dave@hennessey
Old 02-08-2015, 09:21 AM   #1
2012 ZL1#1658
2012 ZL1#1658's Avatar
Drives: 2012 Camaro ZL1 #1658
Scratch help
I have one decent size scratch that went through the paint. I have smaller ones that I think I can buff out but need help with the 1 deeper one. I don't think I have to paint the whole door right? Any help would be greatly appreciated.
2012 ZL1 (BLACK on BLACK)
Roto-Fab CAI
RX Catch Can
3M Paint Protection
2011 1SS/RS (BLACK on BLACK) <SOLD>
2012 ZL1#1658 is offline   Reply With Quote
Old 02-08-2015, 05:20 PM   #2
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
If it's through the clear you can touch up, but it will still be visible, so you may want to repaint the door.
If it's not through the clear you can wetsand and polish.
Joe M 2012 2SS is offline   Reply With Quote
Old 02-08-2015, 05:31 PM   #3
JTruck
JTruck's Avatar
Drives: 2014 Camaro 1LT/RS
Pictures go a long way here.
Detailing is an involuntary obsession.
JTruck is offline   Reply With Quote
Old 02-09-2015, 06:00 AM   #4
2012 ZL1#1658
Roto-Fab CAI
RX Catch Can
3M Paint Protection
Old 02-09-2015, 08:07 AM   #5
Nor Cal ZL1
Nor Cal ZL1's Avatar
Drives: 2013 ZL1 M6
Polish it as best you can with Menzerna FG400.
http://www.autogeek.net/menzerna-fast-gloss-fg400.html
If that is not satisfactory use this.
http://www.autogeek.net/dr-colorchip...ip-repair.html
Nor Cal ZL1 is offline   Reply With Quote
Old 02-09-2015, 03:00 PM   #6
Rick's Camaro
Drives: 1967-2014 Camaro's
I'd use Dr. Colorchip i will link below the part. Also check out this thread
http://www.camaro5.com/forums/showthread.php?t=392680
LINK FOR MORE INFO
Rick's Camaro is offline   Reply With Quote
Old 02-09-2015, 04:00 PM   #7
Joe M 2012 2SS
Drives: 2012 2SS
Dr. Colorchip is not designed for deep scratches, it is designed for small chips and "road rash". It works great on darker colors.
To remove a deep scratch you have to use an abrasive product. Since you own a DA, I'm sure you have cutting pads and compound. Go over them first after properly prepping the area of the scratches. I would think based on the pic, you would lessen it some, but it would still be there. To further remove it wetsand and polish. Again, if it's through the clear this won't remove it. Your options are touch up and live with it, or repaint.
If you haven't wetsanded before this is a good demonstration of it for a deeper scratch. The only thing I do different is use a sanding block with 2000 grit.
Old 02-09-2015, 04:11 PM   #8
2012 ZL1#1658
Thanks for the help everyone. I'm going to try this touch up product and let you know how it worked. I ordered a set from paintscratch.com.
Roto-Fab CAI
RX Catch Can
3M Paint Protection
Old 02-09-2015, 04:54 PM   #9
Joe M 2012 2SS
Drives: 2012 2SS
Based on my use of Dr Colorchip, I would recommend you wait at least 20 minutes before using the sealact to remove excess paint. Do not use any pressure as you will pull the paint from the scratch. What you'll end up with is paint in the scratch, not leveling it, but diminishing it's appearance.
Do not use the buffing towel that comes with the kit. Use a quality microfiber to buff.
Old 02-10-2015, 07:54 AM   #10
2012 ZL1#1658
Thanks.
Roto-Fab CAI
RX Catch Can
3M Paint Protection
