Old 12-31-2014, 08:13 PM   #1
dekee
Drives: none
Protect Corvette Or Pass on Engine
Do you believe that the new Camaro 6 will get the same engine as the Corvette 15 Z06?
The reason I stated this is that I was reading a good article from CarandDriver that states that CTS-V, which the new Camaro 6 chassis will be based, will use the "mighty 2015 Corvette Z06, which donates its supercharged 6.2 liter LTV4 V-8 engine."
The article can be read here http://www.caranddriver.com/news/201...-and-info-news.
dekee is offline   Reply With Quote
Old 12-31-2014, 10:02 PM   #2
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
The new Camaro is based off the ATS platform, not the CTS. The LT4 engine from the Z06 should make it into the ZL1 when Chevy decides to make a ZL1 version of the Camaro.
ssmike is offline   Reply With Quote
Old 12-31-2014, 10:19 PM   #3
Bhobbs
Bhobbs's Avatar
The Camaro is based on the Alpha platform, same as the ATS and CTS. The Camaro doesn't have to be the same size as the ATS or CTS.
I expect the 6th gen supercharged car, which sounds like it will be the Z/28 based on rumors I've seen, will get the LT4 with a similar output as the CTS-V.
Old 01-01-2015, 10:12 AM   #4
Number 3
Hail to the King baby!
Number 3's Avatar
No reason to suspect GM will "protect" the Corvette.
Arguably in the Gen 6 Corvette and Gen 5 Camaro they shared the base LS3.
The LSA in the ZL1 was nothing available in a Corvette unless you got the LS9 in the $100,000 plus ZR1. So in effect the Camaro had a "readily" available higher HP engine than the Corvette.
And the LS7, although never overlapped between the 2 cars was the Corvette Z06 engine put in the Z/28.
So, no, I don't think the engines will be blocked from the Camaro. The size and weight will automatically make the two cars different in performance.
And Bhobbs is correct. Alpha is the architecture that spawns both ATS and CTS. A good bit of the structure underneath like the floor pan and FOD are common between the two. But slight variations allow for 2 distinct sizes.
Old 01-01-2015, 10:32 AM   #5
hotlap
hotlap's Avatar
We can finally end the Chevy protects Corvette debate now that the LT4 is in CTS-V.
Interesting to note the use of the high rev, 1.7L blower in the CTS-V. The Vette's low hood forced its use but they could have used a lager, slower unit in the V. Obvious that they were satisfied with it during testing.
Ronald Reagan -
Old 01-01-2015, 02:31 PM   #6
Bhobbs
Bhobbs's Avatar
Or GM is reducing the number of engines to the bare minimum. That's probablu why the LT4 is in the Z06, CTS-V and likely Z Camaro. GM can't protect the Corvette because they don't have enough engines to do it.
Old 01-01-2015, 02:34 PM   #7
Snakedriver
Snakedriver's Avatar
Drives: ZL1
The Camaro will get a detuned LT4.
Snakedriver is offline   Reply With Quote
Old 01-01-2015, 05:23 PM   #8
alcal1084
Drives: 2012 45TH AE SS
Why would it be detuned? The Cadillac version is right there with the corvette and actually has a higher top speed.
alcal1084 is offline   Reply With Quote
Old 01-01-2015, 05:52 PM   #9
Number 3
Number 3's Avatar
The LSA got a 25 HP bump when it went in the Camaro. No reason to protect for a HP number when there is a GT500 coming.
Old 01-01-2015, 08:48 PM   #10
Bhobbs
Bhobbs's Avatar
Wasn't that due to the less efficient packaging in the old CTS-V engine bay? I thought I read the ZL1 had more room for a better airflow path, or something along those lines, and that accounts for the greater output.
Either way, I highly doubt the 6th gen Z/28 will make more power than the Z06, GT500 or not. All Ford has to do is make more than the Z06 and be safely ahead of the Camaro.
Old 01-01-2015, 09:34 PM   #11
alcal1084
I asked a Camaro engineer one time what's the fastest he's ever been on a track doing top speed testing. He told me 205 mph. So the next question was what car. His answer ZL1!!! I was confused how did he go 200+mph in a car that can only go 186... His answer, "all parts of the car have to work at those speeds for us to allow the car to be able to go those speeds". So that ment something on the Camaro wasn't working at 200+ but did in fact work at 186. So they went back into the tune and pulled the car back a little bit so that it would safely run at those speeds. It had nothing to do with the corvette or the mustang just safety.
If you are interested in what part of the car didn't work, it was the windshield wipers.
Old 01-01-2015, 09:47 PM   #12
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
Ha. People are always surprised when I tell them my 1LE has the same top speed as a V6 Camaro.
Old 01-01-2015, 10:52 PM   #13
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
...I thought top speed was determined by the rating for the stock tires....Nothing to do with the type of engine....
Old 01-02-2015, 12:17 AM   #14
dekee
Drives: none
It would be a kick ass engine in the Camaro as the CTS-V engine "is so powerful that it’s almost unsurprising that the new V sedan can hit 60 mph in a claimed 3.7 seconds."
corvette c06, cts-v
