Old 10-03-2014, 07:57 AM   #1
slakjak1215
slakjak1215's Avatar
Drives: 2014 1LS
Quick Engine Question
So, from an engineering stand point, what decided how fast an engine will rev down after being revved up? I noticed that if I rev my engine past 5k RPM it takes a bit for it to come back down. I only ask because if i'm driving and i punch it in second past 5 close to 6 and I don't wanna punch it in 3rd, I gotta wait a bit for it to come back down before letting the clutch back in so it doesn't jerk. Just curious thanks.
slakjak1215 is offline   Reply With Quote
Old 10-03-2014, 08:11 AM   #2
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
A lot of things. Mainly mass, compression, cam overlap...
A heavy rotating assembly, heavy flywheel, heavy clutch... takes a bit to slow back down. It's inertia from spinning mass.
Really high compression and a light rotating assembly... will be a quick revver and de revver.
Snap the throttle on a Pro Stock motor.
Russell James is offline   Reply With Quote
Old 10-03-2014, 08:13 AM   #3
slakjak1215
Drives: 2014 1LS
Awesome thank you!
Old 10-03-2014, 08:26 AM   #4
DivineStrike
Drives: 05 Ranger Fx4, VW GTI, CBR600RR
Agreed of things outside the motor the largest contributor would be the flywheel. Pretty sure most clutches/pressure plate assemblies are made of pretty light materials already. Not familiar with what you could change inside the motor that would be worth your time without compromising strength and reliability.
Definitely both pro's and cons of a lightweight vs heavier flywheel. This is purely an assumption since I don't know much about drag racing but I would assume a heavier flywheel would help get you a harder launch. Or are the advantages there pretty negligible?
DivineStrike is offline   Reply With Quote
Old 10-03-2014, 11:06 AM   #5
kevint
Drives: 2013 1SS
Pro Stock motors also have very short strokes, but that is tied into the reduced inertia.
They sell heavier flywheels for this purpose.
kevint is offline   Reply With Quote
