Old 10-01-2014, 10:14 PM   #1
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
2015 Mustang dyno 380rwhp
Magnaflow claim 30hp with their xpipe/catback setup. Seems the new mustang exhaust is smaller and more silent thats why they got that much.
30hp seems extreme. Either the stock exhaust is shit with a way better engine that needs to breathe or this is just BS.
After all maybe this improved 5.0 engine will be close to 450hp with some factory SVT upgraded exhaust(like NPP).
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 10-01-2014, 10:18 PM   #2
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
Old 10-01-2014, 10:22 PM   #3
GoldCartridgeGamer
GoldCartridgeGamer's Avatar
Drives: 2014 Ford SVT Raptor SuperCrew
No exhaust does that. Maybe headers but no catback or axle-back exhaust.
Phoenix (sold)
How to hug your camaro
Buy the car that you would most like to get beat in. The other guy will always be faster.
GoldCartridgeGamer is offline   Reply With Quote
Old 10-01-2014, 10:30 PM   #4
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
QUOTE:
'' Car was 100% stock, with 30 miles on it, Gas in the tank was original from Ford.
No tune was made, zero modifications aside from a cat back exhaust. No headers, OEM cats remained.
Gear dynoed in was 5th with 1:1 drive ratio.
Dyno used was a dynojet.
Multiple factors apply to the restriction, the piping size off the manifolds and for the whole exhaust is actually smaller than 2014, the cars have a super restrictive mufflers that are likely in place to keep it quiet for global standards, as well as the 3 muffler/resonator set up as opposed to the 2 muffler set up we are used to seeing on Mustangs.
Originally Posted by Red_Devil View Post
baselines were done roughly at noon time, dyno on our comp system was done same day around 2pm. 80s weather low humidity.
we did not cut open the stock exhaust.
The sound suppression within the car is impressive. Generally speaking I tell people you will get some level of drone or resonance with ANY aftermarket exhaust system (if we are really being honest with each other), but I didn't hear any with our street series kit, it was very quiet inside. I attribute that to Ford really stepping it up for global comforts.
Ford Racing advertised 30 lbs weight savings, we got the same savings.
Everyone is free to be a skeptic until they see the gains themselves. However we only released the dyno sheets with Ford's blessings. Not sure what sort of backing anyone else requires. Magnaflow's reputation speaks for itself, we don't exactly make a habit of making up power gains on our products.
'' END OF QUOTE.
Just a quote, I do not believe it. Seems like a big stretch for a catback/xpipe WITH CATS. 14' 5.0 XPIPE gains where awesome because of the cats removal or high flow cats replacing stock ones. Like when you replace your stock cats on a LS3..hello 15-20rwhp.
13' 1LE
Old 10-01-2014, 10:38 PM   #5
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
A stock GT should make about 380 RWHP. Stock LS3's make ~370 and they have 9 less horsepower compared to the 2015 5.0's.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 10-02-2014, 12:55 AM   #6
BobDigi5060
Drives: 97' A4, 08' Mustang, 15' Legacy
375whp/355wtq, stock.
BobDigi5060 is offline   Reply With Quote
Old 10-02-2014, 12:23 PM   #7
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Most 13'+ LS3 dyno 380-390+rwhp. Dyno numbers vary a lot though.
13' 1LE
Old 10-02-2014, 12:27 PM   #8
SpeedIsLife
Drives: Current Camaro-less
From reading the posts on Mustang6g from both Gibson and Magnaflow..
Both are showing unturned 30rwhp gains, and both are showing 30lbs lighter than stock.
If a few more come back with gains of 20-30whp, I'll be willing to view it was legit.
We'll see
Edit: This quote was interesting..FordService has an active presence on that forum and likely would have disputed this..
"However we only released the dyno sheets with Ford's blessings."
Old 10-02-2014, 03:30 PM   #9
KMPrenger
KMPrenger's Avatar
The magazines all complained that the GT exhaust was a bit on the quiet side. That said, it seems that on modern sport cars, an exhaust does little for power and is more about sound these days.
I'd be shocked if Ford plugged that car up so much that a simple exhaust change nets 30rwhp. That would be a huge win for 2015 Mustang owners.
Maybe thats Ford's plan for an easy change to match the LT1 Camaro when it debuts, or perhaps they are going to offer a performance mode exhaust option like GM does on Camaro and Corvette, but it will add much more than just 4 or 6 HP like the GMPP does.
Old 10-02-2014, 03:41 PM   #10
snizzle
Recalled user
snizzle's Avatar
Drives: '12 Camaro SS, '18 Colorado Z71
THIS. I think they want the headroom for an easy refresh.
2012 2SS 45th AE LS3 M6
Borla ATAK Catback
Kooks Stepped LT Headers
CAI Intake
Hexvents
VMAX CNC Ported Throttle Body
RX Catch Can
Hurst Short Throw Shifter
Pfadt ZL-Spec Stage 3 Suspension
Forgestar F14
Tuned by Frost
snizzle is offline   Reply With Quote
Old 10-11-2014, 02:38 PM   #11
crysalis_01
Iron fist, lead foot
crysalis_01's Avatar
Drives: 2003 Mustang Cobra
It may be the case that Ford it choking the revised 5.0 from both ends in preperations for the LT1.
http://www.svtperformance.com/?p=7318
crysalis_01 is offline   Reply With Quote
Old 10-11-2014, 03:14 PM   #12
SpeedIsLife
Hmmm...
If the exhaust does indeed pick up 30 hp and 25 tq, combine this with a CAI and tune and that would be 430 whp and 400 wtq for less than 1,800 bucks in parts
Old 10-11-2014, 07:32 PM   #13
Bhobbs
Bhobbs's Avatar
I would be surprised if Ford purposely choked off the 5.0 that much. The 5.0 seems to gain a lot from a tune due to the TiVCT.
Old 10-11-2014, 09:14 PM   #14
87GNX
87GNX's Avatar
Drives: Alot
This...that catback 30 whp is bullshit.
IF YOU AIN'T FIRST, YOU'RE LAST
87GNX is offline   Reply With Quote
