05-09-2014, 10:18 PM | #1 |
Help with Bolt/Stud
05-10-2014, 08:09 AM | #2 |
Wonderfully Awful Idea
What did they come off of?
05-10-2014, 01:13 PM | #3 |
Drives: 12 Boss 302 Join Date: Sep 2009
Depending on the application, you could probably use a "T"bolt, look it up under anchors in a fastener supply company. We call those a captured bolt around here, but I don't know if that is the proper name.
The biggest mistakes in life come when you know exactly what you are doing.
05-10-2014, 01:22 PM | #4 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
Looks like it was from an old water valve. You sure it didn't have two arms at one time? Or that's it's not something like a machine table screw with a handle welded onto it? Looks a bit like acme-type threads too, regular bolt or screw won't work
05-10-2014, 05:16 PM | #5 |
Application was for in a rail so you could put it in a round hole and it would wedge against the rail so you could tighten/loosen. I may make them. Someone told me it's a flag bolt.
05-10-2014, 07:37 PM | #6 |
Drives: the 2nd amendment home Join Date: May 2008
Try Fastenal if you have a local store
-- Benjamin Franklin |
05-10-2014, 08:39 PM | #7 |
Drives: 2012 IBM 2SS Vert. Join Date: Dec 2011
Was that on the jeep you are working on? If so where on the jeep?
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
05-10-2014, 10:59 PM | #8 |
That's what I'm thinking, thanks!
Yeah, where the frame mounts to the body. The two rails under the doors. They went in some of the unused holes and that's where my rocker guards mount. |
05-10-2014, 11:33 PM | #9 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
Mc master - Carr
