Roto-Fab
Old 05-07-2014, 09:16 AM   #1
lbheat
Echale Gas [COTW 3/10/14]
lbheat's Avatar
Drives: 2010 Camaro SS/RS Supercharged
ACS Camaro Upper Rear Quarter Ports
Item: ACS Camaro Upper Rear Quarter Ports
Link: http://www.camaro5.com/forums/showth...+Quarter+Ports
Has anyone seen these in person? Anyone actually install it themselves? If so how hard was install?
Thanks,
Pascual
Kenne Bell
502 rwhp/ 471 rwtq at 9psi (daily driver...for now)
Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated
Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers
lbheat is offline   Reply With Quote
Old 07-11-2014, 06:29 AM   #2
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
Thanks,
Pascual
Here you go..just picked up the car yesterday. The install was not hard according to ACS
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty
CAI - Cold Air Inductions / VMAX TB / Trifecta Tune
Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can
ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit
ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports
ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller
Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels /
Oracle Afterburners / Oracle Concept SMD Side markers
Complete SS Brembo Brakes Set
RickRay is offline   Reply With Quote
Old 07-11-2014, 06:51 AM   #3
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Pretty nice. Is there any supposed functionality to these? I mean...
Do they allow air in?
Do they allow water (rain) in?
Where does the air (and water, if any) go?
What does the incoming air do - functionally, i.e. help cool brakes?
Thanks.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 07-11-2014, 07:32 AM   #4
RickRay
INJACC
RickRay's Avatar
Do they allow air in? = YES
Do they allow water (rain) in? = YES
Where does the air (and water, if any) go? = Behind tire
What does the incoming air do - functionally, = cool brakes?
Thanks.
Upper Rear Ports installed by ACS...They will soon put up the instalation video and pictures once everything is edited. Now these are to cool off the brakes but for now cause of the fuel line on the passenger side they are redoing the symatics...so for now they drain the water away and they will be able later on to add the hoses to cool off the brakes.
Old 07-11-2014, 12:10 PM   #5
Libertypilot
Libertypilot's Avatar
Drives: 2013 Silver Ice Metallic
No thread jacking intended but did you put your rims on? What are they called and where did you get them?
Libertypilot is offline   Reply With Quote
Old 07-13-2014, 11:12 PM   #6
lawdog
Drives: 2010 SSII w RS & Sunroof Yellow
Location: West Suburbs of Chicago, in a Courthouse Somewhere
those look cool, would be great idea to help cool off brakes !
lawdog is offline   Reply With Quote
Old 07-14-2014, 05:42 PM   #7
CamaroI
Drives: 2010 IOM Camaro
Looks nice but nothing but issues with Glued in parts...
CamaroI is offline   Reply With Quote
Old 07-14-2014, 09:55 PM   #8
elarson5757
Obsessed and Loving It...
Drives: 2013 1LE-SS
Installed correctly there are no issues with glued in parts...
It's all in the prep and using the right adhesive. The trays are epoxied in from inside and the tops use the same adhesive holding your windshield in. Haven't seen to many windshields leak or fall off lately..
elarson5757 is offline   Reply With Quote
Old 07-14-2014, 10:03 PM   #9
CamaroI
No but I have seen plenty of hood vents along with other glued in parts failing even when prepped correctly. Heat plays a big part in these items. I attempt to steer clear of parts that glue in if at all possible.
Old 07-14-2014, 10:12 PM   #10
elarson5757
Drives: 2013 1LE-SS
Umm...never had an issue myself. Hood vents, inserts, quarter ports, bumper ports, fender inserts, etc. pretty much done them all on my cars over the years. Hope my lucky streak holds I guess!
Old 07-14-2014, 10:27 PM   #11
CamaroI
Hope so. Several guys I know including myself have either abandon the hood vents or using rivets now to hold hood vents in securely. Ask TRC-SS his hood vent on passenger side just feel out couple weeks ago. He used my advice to rivet in place and now stronger than ever. No chance of hood crashing down since hood brace located in hood vent.
As for installation I had Lupe reinstall mine after falling out the first time. He did a great job using sealant on airplanes. Long story short my vents still became loose and fell out. I ended up having a custom hood made without glued in pieces to match my old hood design. Zero worries now.
Old 07-16-2014, 07:20 AM   #12
ELIC1
Drives: black and silver
i have them also. people really like them at the shows
ELIC1 is offline   Reply With Quote
Old 07-16-2014, 08:16 AM   #13
RickRay
INJACC
RickRay's Avatar
http://www.camaro5.com/forums/showth...t=reproduction
Yes they will be for cooling off the brakes but they are redesigning the cooling ducts system...
Old 07-18-2014, 01:21 PM   #14
Libertypilot
^ Thanks man!
