03-19-2014, 08:19 PM | #1 |
Drives: 2014 ZL1 White Convertible Join Date: Aug 2013
intercooler reservoir
Ok I have read and listened to ideas about the best ways to battle heatsoak. I now have my strategy on how to combat it. I plan to use
a 3 combination approach, using the stock Hx, an aftermarket Superchiller, and a high capacity intercooler reservoir. Which brings me to my question, What is the best intercooler reservoir available that will fit a stock configuration ?. I found the lingerfelter one, but it requires you get their aftermarket Cai system. I also found this one from D3 Performance Engineering - High Capacity Supercharger Reservoir. 5 gallon capacity if I understood it correctly!. lastly I found one from Kd innovations, they did not provide much details about their product at all. Well if anyone has a better suggestion I would appreciate learning about it. Thanks all |
03-19-2014, 08:34 PM | #2 |
Adding a reservoir will not help anything. You just have to cool more water. Now if you fill with ice that will work. Adding more water does nothing for the inter cooler. Just check out JRE. There is no data to support adding a tank will help the LSA unless you cool it with something other than air. The heat exchanger is so small in the LSA.
03-19-2014, 08:51 PM | #3 | |
Drives: 2008 Pontiac G8 GT, Shelby GT500 Join Date: Mar 2011
The example used was trying to boil water in a pot. Put a little bit of water in the pot, it boils fast. Fill the pot and it takes much longer to boil. It does make perfect sense. So I would imagine a reservoir would certainly help. |
03-19-2014, 09:36 PM | #4 | |
Drives: none Join Date: Oct 2012
From what jessyrayo said about his system for road racing i would avoid the plastic reservoirs since if you go hard enough on the car for long enough the coolant will get so hot it will blow the plastic up like a balloon. Also any metal fab shop would be able to make a custom reservoir for you, probably near the same cost as some of these shops, being custom you can figure out where you want to mount it and how much you want it to hold. In my opinion you should upgrade the pump to a much bigger one and if doing so this opens up the option to make a system like jessyrayo and run a big take in the spare tire area. And yeah exactly like i said before with the kitchen kettle put a small amount of water in it turn it on it boils fast, fill it right up, plumb in a reservoir and a pump to cycle the water through it, it's not going to boil anywhere near as fast. The temps in the long run over sustained high speeds might reach the same temperatures but it certainly wont get to that temp at the same rate of time. And that would be beating up on the car on a road course. |
03-19-2014, 09:40 PM | #5 | |
03-20-2014, 05:27 AM | #6 |
Yes, but you have to heat it first to cool it. It'll take longer to heat up, but yes, it will also take longer to cool off.
And yes, the intercooler is too small. Exactly why I plan on going with a heart beat blower down the road. |
03-20-2014, 06:07 AM | #7 | |
With ice in the tank it definitely helps. With more capacity it is a help as well because a greater quantity of water does take longer to heat up compared to a smaller quantity of water. This is a thermodynamic basic principle called "heat capacity".
03-20-2014, 09:39 AM | #8 |
Drives: 2013 ZL1 Camaro Join Date: Jul 2013
I agree with skylane 765. If you still have the small brick as the choke point in the system, making the rest of the system more efficient is moot. Starting with lower temps will help with drag racing, but won't help just driving down the road and having a little freeway on ramp fun.
03-20-2014, 10:35 AM | #9 |
Drives: 19 Z06 Join Date: Nov 2011
Is there any company that makes a better inter cooler for our LSA? Or is the factory one the biggest that can fit in there?
Gone but not forgotten:
1974 Corvette Stingray 454 1986 Z28 2009 Mustang GT convertible 2012 45th 2SS Vert 2013 ZL1 M6 2014 Zl1 M6 2014 GT500 2016 Challenger Hellcat M6 www.youtube.com/c/garageking |
03-20-2014, 11:18 AM | #10 | |
2013 ZL1
Drives: 2013 ZL1 m6 Join Date: Oct 2010
I have a question or theory, if the system is plumbed to have a hx directly before and after the intercooler (2 hx), would that help to keep the fluid from getting as hot as fast? Dont know if anyone has tried it or not. |
03-20-2014, 08:53 PM | #11 | |
03-20-2014, 09:23 PM | #12 |
Best and easiest solution I think would be to swap the blower for a better, more efficient one (LS9 blower or Heartbeat etc.) Only problem is the price, but I think the results would be pretty good.
03-20-2014, 09:57 PM | #13 |
This may sound stupid, but when we're talking about putting ice in it do we mean in with the coolant in the tank?
Could you hypothetically fabricate a tank inside a tank made out of aluminum with two caps, one of them being a bigmouth cap to put ice in with coolant in the center where it could be surrounded by ice, with a pitcock in the ice side to Drain the water off between runs. Would dry ice work, last longer, be colder? Or possibly a coil inside to transport coolant thru a say ice chest. |
03-20-2014, 10:24 PM | #14 | |||
Drives: none Join Date: Aug 2011
Based on what? I haven't seen a single thread with any data about IAT2 temps with the Heartbeat blower? |
