03-05-2014, 01:25 PM | #1 |
Mace LFX 12mm and 6mm Manifold Spacers Install
I just got a package in the post today from MACE ENGINEERING. It contained a 12mm manifold spacer and a 6mm manifold spacer. They were sent to me to do a write up on the install process and the performance increase. I plan on installing the 12mm spacer first doing some logs and driving around to get a feel for how it reacts to my set up, after I have collected enough data I'll give my impression on 12mm spacer. I plan on removing the 12mm and replacing it with the 6mm spacer when I install the cams. The 6mm spacers are better suited to the cams.
Nytrex 100 hp nitrous triple threat system, NytrexAccu-pressure bottle heater, HP tuners, K&N Typhoon CAI, MACE 6mm MI, Solo Performance high flow cats, Flowmaster American Thunder cat back exhaust system, BMR subframe connectors, BMR tunnel brace, BMR lowering springs, BMR Xtreme Anti-roll bar rear, Hotchkins Strut brace, SS/LS3 3.45 LSD, Axles, and hubs, Elite Engineering catch can, B&M Supercooler transmission cooler, FTI 3200 Stall.
03-05-2014, 01:31 PM | #2 | |
Team LFX
Drives: Fast Join Date: Mar 2012
03-05-2014, 03:09 PM | #3 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Looks familiar...
03-05-2014, 03:26 PM | #4 |
yes but i like your design using the o-rings much better then using RTV...
03-05-2014, 03:29 PM | #5 |
You guys are brave for testing all this stuff out
Instagram @Tavo_32
03-05-2014, 03:54 PM | #6 |
It's already been tested multiple times. Nothing new about it... It's essentially the same product as the one I've been working on here: http://www.camaro5.com/forums/showthread.php?t=307431
As mentioned above, mine uses the factory orings so you don't have to deal with the mess of RTV, and the wait time for it to seal. |
03-05-2014, 04:15 PM | #7 |
03-05-2014, 04:15 PM | #8 |
FREE STUFF!!!!!
03-05-2014, 04:18 PM | #9 | |
03-05-2014, 07:46 PM | #10 | |
I'm very curious to see your thoughts once you get it installed, regardless of whos product it is... Just one less one I have to give away |
03-05-2014, 09:06 PM | #11 |
Go Gators!
Drives: Camaro Jeep Abarth 944 325i Join Date: Jan 2013
This is funny
'13 Camaro, '97 Wrangler, '12 500 Abarth, '85.5 944, '06 325i
Suspension Mods: BMR and JPSS Sways, BMR Poly Bushings, BMR strut tower brace, BMR control arms, BMR toe arms, stock springs and struts Engine Mods: All bolt ons (haha) Brake Mods: Brembo SS caliper swap front and rear |
03-05-2014, 09:20 PM | #12 |
Black lightning
LOL YES IT IS...CANT WAIT TO SEE THE RESULTS BLACKOUT
[ 2021 Camaro ZLE 10 speed
03-05-2014, 11:15 PM | #13 | |
haha I see you have that "If it's free, its me" mentality just like me
Instagram @Tavo_32
03-05-2014, 11:32 PM | #14 |
Drives: 2016 1SS SW Join Date: Jun 2013
