Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 09-27-2013, 12:12 PM   #1
Tran
Administrator
Tran's Avatar
Drives: 2010 Camaro of course....
No-lift Shifting in the Camaro ZL1 (Automobile)
Per Automobile feature:
No-lift shift isn’t new to GM. The Chevrolet Cobalt SS and HHR SS had it, the Buick Regal GS and the Cadillac CTS-V have it, but the 2014 Chevrolet Camaro ZL1 wears it best.
Imagine you’re at a drag strip. You put the 2014 Chevrolet Camaro ZL1 stability system into Race mode, inch up to the starting line until you fully stage, then put your right foot flat onto the accelerator pedal to turn on launch control. After the engine figures out what rpm to launch at, you ease your foot off of the clutch to go. The 2014 Chevrolet Camaro ZL1 charges forward, the tachometer’s needle approaches redline, and it’s time to shift. This is usually when you’d take your right foot off of the accelerator pedal, push the clutch pedal in with your left foot, shift into second gear, raise your left off of the clutch, and slam your right foot down onto the accelerator pedal again—but that’s not what’s going to happen this time.
With your right foot firmly planted on the accelerator pedal, your left foot hovers just above the clutch pedal. Then you start to push down it. For a second, every muscle in your body tenses off as you imagine obliterating the supercharged V-8 engine or the 6-speed manual transmission by doing what you’re about to do. Then you remind yourself that this engine is tuned for no-lift shifts. If you don’t use the feature, the supercharger won’t maintain boost between gears. So you ram your left foot down onto the clutch pedal, there’s a loud blat from the exhaust, your right hand yanks the transmission into second gear, and you get your left foot off of the accelerator as fast as you can. The 2014 Chevrolet Camaro ZL1 surges forward, completely unscathed. Ditto for the next two shifts. As you cross the finish line in just over twelve seconds, you realize that the accelerator pedal has been on the floor since the start of your quarter-mile run.
Cool, right? Check out the video to see what no-lift shifting in a 2014 Chevrolet Camaro ZL1 looks like.
Tran is offline   Reply With Quote
Old 09-27-2013, 12:37 PM   #2
Ace1USMC
Drives: 2011 Camaro SS LS3
Man, that guy still shifts like a granny...
By His wounds...
Ace1USMC is offline   Reply With Quote
Old 09-27-2013, 12:41 PM   #3
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
Who's gonna be the first one to get that wrong!!
its a syn is offline   Reply With Quote
Old 09-27-2013, 12:44 PM   #4
Edwin320
Drives: 2018 Camaro ZL1 Convertible A10
How is this different than powershifting any other car?
Ed 2018 ZL1 A10 'Vert
Edwin320 is offline   Reply With Quote
Old 09-27-2013, 12:51 PM   #5
camaro500
camaro500's Avatar
Drives: 2017 Jaguar F Type R Tuned 498awhp
zl1 is da bomb
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller
camaro500 is offline   Reply With Quote
Old 09-27-2013, 12:56 PM   #6
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
"...left foot off the accelerator as fast as you can." Don't you mean clutch?
FrankT is offline   Reply With Quote
Old 09-27-2013, 01:14 PM   #7
DrkPhx
DrkPhx's Avatar
Drives: 2013 Triple Black ZL1 / 2006 TB SS
Yes he does. I can rip a mean second gear chirp with DR's.
The factory rev limiter still works with no lift shift.
You don't lift off the gas pedal; just stab the clutch. It keeps the car in boost during the shift.
He meant clutch.
DrkPhx is offline   Reply With Quote
Old 09-27-2013, 01:24 PM   #8
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
Why does the back of the car have the 2014 ass and 2013 front end?
Jenner is offline   Reply With Quote
Old 09-27-2013, 01:27 PM   #9
Jeff65SS
Jeff65SS's Avatar
Drives: 1965 Chevelle Malibu SS
The ZL1 front end is still the same for 2014
Jeff65SS is offline   Reply With Quote
Old 09-27-2013, 01:46 PM   #10
Edwin320
I use that technique all the time (keep the gas pedal on the floor, stab the clutch, and shift quickly), and have been doing so for decades, when I want to get the best times out of a car. What did they do to the ZL1 that's different?
Old 09-27-2013, 01:53 PM   #11
Mean Green Z28
Drives: 2010 2SS
If you're quick, power shifting is something all M6 guys are used to at the track; I guess you have a bit more time to do that without it hitting the rev limiter with this system. Does it use the same setup of dropping fuel to cylinders to keep the rev's from rising as in the launch control?
Mean Green Z28 is offline   Reply With Quote
Old 09-27-2013, 02:00 PM   #12
karnov
Drives: 2014 Camaro 1SS 1LE
Is this only in the ZL1, or is this in the SS as well. My previous car had this feature and my 1LE SS won't be ready for delivery until the end of next month. I have been wondering if this works on the SS?
**EDIT**
I saw the previous post so I assume this is something specific with the M6 transmission which would mean it will work in the SS model???
karnov is offline   Reply With Quote
Old 09-27-2013, 02:12 PM   #13
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
They should have 2014 front end and 2013 rear
Old 09-27-2013, 02:20 PM   #14
HDRDTD
With the no-lift shifting , the engine maintains it's rpms when you push in the clutch, preventing it from just climbing right up and hitting the rev limiter no matter how long it takes you to complete the shift.
With the conventional method of power-shifting, if you shift fast enough, all is good. If you miss a gear, the engine will continue to rev right on up.
