Old 07-01-2009, 11:42 AM   #1
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
I got a hommework question, need help
Could someone tell me 5 reasons a car would shimmy and vibrate, my instructor give us questions like these every night
and I'm stumped
Where the hell is spike when you need em, lol
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline   Reply With Quote
Old 07-01-2009, 11:47 AM   #2
Paperer
Ragin' Cajun
Paperer's Avatar
Drives: '02 Camaro SS - '10 CGM 2SS/RS
You mean while driving? Unbalanced wheels, bent rims, etc, cause vibrations in the steering wheel.
http://img.photobucket.com/albums/v202/paper2302/Siggy.jpg
Paperer is offline   Reply With Quote
Old 07-01-2009, 11:53 AM   #3
Muscle Master
SS Lightning
Drives: An SRT8
well, that's 2
Old 07-01-2009, 11:55 AM   #4
BigRigMike
BigRigMike's Avatar
Drives: 2010 Ford Fusion
Do all they have to be driving? If not then a misfiring cylinder can cause a vibration at idle. Or a big cam can always cause a little shaking
Warped brake rotors will cause shaking when braking.
Rough Road
BigRigMike is offline   Reply With Quote
Old 07-01-2009, 11:58 AM   #5
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
A car with screwy cylinder deactivation will shudder a bit.
Same with cars with engine start/stop hybrid tech.
2023 GMC Canyon Elevation
Old 07-01-2009, 11:59 AM   #6
Paperer
Ragin' Cajun
Paperer's Avatar
Vibration when slowing down is the rotors and if the lugnuts aren't tight and good, it'll shake as well.
Those are the only experiences I've had with a shaky wheel.
Old 07-01-2009, 12:05 PM   #7
MRK III Z28
SoCal C5 Family Member
MRK III Z28's Avatar
Drives: 1968 Mustang
Send a message via AIM to MRK III Z28
Hmm I would say clogged fuel filter and bad fuel pump
My baby Jane!
I still love the Camaro
MRK III Z28 is offline   Reply With Quote
Old 07-01-2009, 12:09 PM   #8
Muscle Master
SS Lightning
Drives: An SRT8
yeah while driving, and thanks for a the good answer
Old 07-01-2009, 12:19 PM   #9
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
and I'm stumped
If you mean general drivetrain, here are a few:
Front End -
Out of balance tire
Cupped tire
Tire that is overworn/belts showing
Tire with a "bubble"
Bent rim
Loose lug nut(s)
Warped Rotors
Bad Wheel Bearings or bearings with little grease
Front End misalignment, bad caster/camber/toe-in
Sticking brake
Bad brake hose
Malfunctioning ABS
Bad Ball Joint (cars without struts)
Broken/Bad/Leaking Shock
Rearend -
Many of the above, plus
Bent axle
Sticking Locker and/or Posi differential
Hanging emergency brake
Damaged Ring & Pinion
Damaged Spider Gears
Mid Area -
Worn U-Joints
Bent Driveshaft
Worn Transmission Bearings
General Transmission Problems
Flywheel/Clutch/Pressure plate and/or flexplate weight missing
And then about a million things that the engine could contribute...
Hope this gives you a couple of ideas.
speedster is offline   Reply With Quote
Old 07-01-2009, 12:41 PM   #10
big_dog
Future Z28 Owner.
Drives: Future Camaro Owner
How about a very bumpy road.
big_dog is offline   Reply With Quote
Old 07-01-2009, 01:31 PM   #11
shank0668
shank0668's Avatar
Drives: '14 LML/'06 LJ/'76 Trans Am
Broken motor mounts?
shank0668 is offline   Reply With Quote
Old 07-01-2009, 02:16 PM   #12
GatorBlue371
GatorBlue371's Avatar
Drives: vrooooom vrooooom
bad alignment
"With a light touch on the brakes, run the revs up a bit. Slip off the brake and bury the throttle. There's a light chirp as tires scratch for bite. Then comes a sub-5.0-second sled ride to 60 mph. A tick over 13.0 sec. and you're through the quarter-mile. It's a rush, of course, but not overly dramatic. Try the same thing with this pair's predecessors of 1970 or so and you'll find yourself in a bit of a wrestling match. Ain't progress wonderful? Maybe yes, and maybe sometimes it's fun to wrestle."
GatorBlue371 is offline   Reply With Quote
Old 07-01-2009, 02:30 PM   #13
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
All very good answers. That's more than 5.
Old 07-01-2009, 02:31 PM   #14
PQ
Booooosted.
PQ's Avatar
Earthquake.
LS3 Transmission Question Seawolf 5th Gen Camaro SS LS LT General Discussions 13 06-12-2009 02:16 PM
Ridiculously Stupid Question Ferrarimk13 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 19 05-28-2009 08:53 PM
Question about Order # VS. Workbench Number TJTKSDMJ8 Camaro Price | Ordering | Tracking | Dealers Discussions 27 05-06-2009 12:05 PM
Question about the After.... Tecca Camaro Price | Ordering | Tracking | Dealers Discussions 1 04-15-2009 04:05 PM
OK WILL SOMEONE PLEASE ANSWER THIS QUESTION OM FINANCING leatherneck Camaro Price | Ordering | Tracking | Dealers Discussions 22 03-26-2009 03:53 PM
