Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 01-03-2013, 07:31 PM   #1
FINALLYSATISFIED
Est.1775
FINALLYSATISFIED's Avatar
Drives: '15 Challenger Hellcat (sold)
DIY/How-to: How/What fuse to pull for NPP (Dual mode exhaust)
Ok there seems to be some slight confusion as to what fuse to pull for the NPP exhaust modification. My intention is to clear up any confusion. I didn't take alot of pictures but I will take some more tomorrow and update certain areas to make this as painful as possible for those that will be attempting to do this. Install literally took 15mins and thats including fastening the cargo net plastic pieces. The vehicle used was a 2013 2SS/RS 1LE. For those wondering about pulling an engine code, you should not worry. I have not pulled a code thus far and haven't heard of anyone doing so. You only have to pull the fuse, do not pull the relay. This is only for the 2013 Camaro equipped with the NPP (Dual-mode exhaust) and or the 2012+ Chevrolet Camaro ZL1 which are equipped with NPP.
Install/Uninstall Estimate:
10-15mins or less
Tools
Flashlight (if neccessary)
Fuse puller (if neccessary)
Trim tool (if neccessary)
Fuse box is located in the trunk on the right side (passenger) behind the carpet panel. The fuse box is located behind the red square.
If needed there is a fuse puller located in the fuse box which is located underneath the hood. The fuse box is outlined in red.
1. Unfasten (1) flat black plastic revit
2. Unfasten (6) black plastic cargo net screws
3. Simply pull back the carpet to access the fuse box located in the trunk on the passenger side. Use a flash light if too dark.
4. Open the fuse box and locate F8. It should read "EXH FLAP" 10a. Pull the fuse with the fuse puller(located underneath the hood on the left side) if needed.
5. Now simply repeat steps 1-4 in reverse order to put everything back together. If you want to go back to stock, simply put the F8 fuse back in.
6. With the F8 fuse being pulled now the exhaust flaps will stay open, at any RPM and/or gear. You'll now witness the sound of god at any given time.
I hope this clears up some confusion on what to do and which fuse to pull. Any questions please feel free to ask, I can try and help the best way I can. Keep in mind also your stock 2013 Camaro with NPP, the exhaust flaps will stay open at idle/start up. This mod is only makes the flaps stay open all the time.
FINALLYSATISFIED is offline   Reply With Quote
Old 01-03-2013, 07:42 PM   #2
SS2-1LE
Drives: 08 G6 GXP
Any vids of the exhaust note!!
SS2-1LE is offline   Reply With Quote
Old 01-03-2013, 07:45 PM   #3
FINALLYSATISFIED
Est.1775
I do not have any unfortunately. I just did this mod after work, then went to the gym. I will record a clip tomorrow!
Old 01-03-2013, 09:24 PM   #4
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Will you notice a sound difference at start up without the fuse? I thought the valves/flaps were already open during startup with the fuse in.
slick rick is offline   Reply With Quote
Old 01-03-2013, 09:32 PM   #5
FINALLYSATISFIED
Est.1775
To be honest I did not notice it at start up. I do notice it everytime my foot hits the pedal. Accelerating and deaceleration is when I also hear it. You'll have no regrets if you decide to do it. And if you want the values to have normal operation all you have to do is put the fuse back in.
Old 01-04-2013, 05:55 PM   #6
FINALLYSATISFIED
Est.1775
Added some addtional pictures to clear up some confusion! Hope this helps out anyone in question.
Old 01-05-2013, 11:59 AM   #7
Iroc2430
Smoke'm if you can
Iroc2430's Avatar
Drives: 2010 Camaro 2SS/RS/LS3/M6
I'm trying this today!
Texas Speed LT Headers with HF Cats, Borla ATAK Exhaust, MGW Short Throw Shifter, ADM CAI with Scoop, Elite Oil Catch Can, Mishimoto Aluminum Radiator, Pedders XA Coilovers, Mantic Twin 9000 Clutch, PFADT Solid Subframe Bushings, PFADT Front & Rear Sways, PFADT Upper Control Arm Bushing, PFADT Trailing Arms/Tie Rods, Whiteline Adjustable End Links, Whiteline Adjustable Lower Control Arms, Pedders Diff Bushings, Line Lock, ACC Side Markers, ACC Reverse Lights, Custom Tune from Nitrous Express.
Iroc2430 is offline   Reply With Quote
Old 01-05-2013, 12:58 PM   #8
Iroc2430
Smoke'm if you can
Iroc2430's Avatar
The 2010 2SS/RS/M6 does not have that fuse. Opened up the compartment and F8 is blank and reads spare. Might just be for the 2013.
Old 01-05-2013, 01:11 PM   #9
You might want to edit #5. Pulling the fuse does not change the tone after you start your car.
The flap is always open at startup at idle so the fuse pull makes no difference.
Old 01-05-2013, 01:43 PM   #10
NEVRL8
NEVRL8's Avatar
Drives: 2013 Victory Red 2SS/RS
Yes only for the 2013 with NPP exhaust.
NEVRL8 is offline   Reply With Quote
Old 01-05-2013, 02:17 PM   #11
FINALLYSATISFIED
Est.1775
Fixed.
Yes.
Old 01-05-2013, 03:59 PM   #12
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
Just did this mod after I read youe thread.
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 01-05-2013, 04:19 PM   #13
ROD_SS
ROD_SS's Avatar
Acceleration seem to be a lot better. I would like someome else to chime in. The butt dyno feels good!
Old 01-05-2013, 04:23 PM   #14
FINALLYSATISFIED
Est.1775
