Old 10-29-2012, 09:53 AM   #1
JasonK
JasonK's Avatar
Drives: 2010 Camaro
Any old school hotrodders on here?
I'm building a hotrod '66 Mustang. Planned to restore it but not with all the rot, plans have changed. I've already built a pretty healthy 347. Now I'm onto the tranny. I need to keep it an automatic. Want to either use a c4 or c6 tranny.
I'm looking at options online. Anyone familur with reverse shift patterns? Manual only valve bodies? I'm totally fine manually shifting the auto.
I drove the car for the first time last week. 30-35 mph I nailed it and put the rear tire in smoke til I let off. Granted this was only one tire, but no downshifting since I was manually shifting the car because I didn't have the kickdown hooked up.
What have your run and any regrets? No Ford bashing please, I do have a Camaro also....
2015 Sentra / 2015 Murano / 2012 HD Ultra Classic / 1995 Z71 / 1966 Mustang
JasonK is offline   Reply With Quote
Old 10-29-2012, 12:49 PM   #2
LOWDOWN
Downright Upright
Drives: Daily
C4 is the way to go, as that was the original trans for a '66 289. It also takes less power to run than a C6, which was their Big Block/truck automatic back then.
Reverse Pattern/Manual Valve Body speaks to a race-oriented trans, not necessarily (or necessary) for street use. Having a fully automatic trans, with kickdown, that has a "street-'n-strip" valvebody and appropriate-to-engine power/car weight/gearing/usage converter will have you AND your Stang smilin'. A reputable company like TCI can spec the proper parts.
LOWDOWN is offline   Reply With Quote
Old 10-29-2012, 05:54 PM   #3
bada
Drives: 1932 pro street truck ZO6 LS7 power
I run a manual reverse valve body in mine. I drive it on the street, about 5000 miles per year. And its been in the truck, for 15 years now. I love it.
bada is offline   Reply With Quote
Old 10-29-2012, 09:53 PM   #4
JasonK
JasonK's Avatar
Drives: 2010 Camaro
Bada - So you have to bring it down to first each time you are at a stop sign? I'd be okay with that way also I think.
Old 10-30-2012, 05:01 AM   #5
McBeevee
220/221 whatever it takes
McBeevee's Avatar
Drives: See sig....
Yes, the trans acts just as described.....the operator controls what gear the trans is in at all times. The transmission does not shift itself ever in a manual valve body.
Like Bada, I too have run them on the street over the years and really liked them. I had a th400 in my '70 Chevelle and a c4 in my '93 Mustang. Both were full manual/reverse valve body transmissions. I never had any issues and wouldn't hesitate to run one again.
Brent
2022 BMW X5 M50i
2022 Ram TRX
2021 GT500 CFHP
2016 Challenger Hellcat A8 1058whp/898wtq
1970 Chevelle SS396 4spd
McBeevee is offline   Reply With Quote
Old 10-30-2012, 06:18 AM   #6
bada
Yes it works just like, a manual tranny. But just doesn't, have a clutch. Look at it like this, it's a clutchless manual. You shift it all the time.
