Old 10-14-2012, 11:38 PM   #1
ceyl
ceyl's Avatar
Drives: 2012 2SS/RS M6
Check Engine Light
Need some help. I've got a 2004 Yukon, 5.3 that I get a check engine light during cold weather. I've replaced the MAF, both O2's and the fuel filter. During warm weather I have no issues. As soon as it gets to 30-40 degrees the light comes on. The codes are left and right bank lean, and MAF failure. Any ideas?
SLP TVS 2300, Kooks Long Tubes, Magnaflow 3" comp, BAP, Rotofab CAI, RX catch can, valve cover breather and 3.4" SC Pulley.
ceyl is offline   Reply With Quote
Old 10-14-2012, 11:42 PM   #2
fielderLS3
fielderLS3's Avatar
Drives: 2016 Mazda6, 2011 Mustang 5.0
How does it actually run (any misfires)? Have you checked for vacuum leaks?
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive."
. 2022 1SS 1LE (Coming Soon)
fielderLS3 is offline   Reply With Quote
Old 10-15-2012, 11:49 AM   #3
ceyl
ceyl's Avatar
Initial start-up, if near 30 degrees it runs rough, after a couple min it runs good. Has not registered any misfire codes.
Haven't checked for vacuum leaks. Even a vacuum leak doesn't make sense to me that it only occurs when cold. This has been going on for a couple of years. It passes emissions in the summer time.
I will look for a vacuum leak.
Thanks
Old 10-15-2012, 12:19 PM   #4
DaBears
Drives: 2014 Subaru Forester, 2010 Equinox
might be a gasket?
DaBears is offline   Reply With Quote
Old 10-15-2012, 02:05 PM   #5
ceyl
ceyl's Avatar
Intake gasket? I was saving that for last. Not in a big hurry to dig in that far if it's not needed.
Old 10-15-2012, 02:11 PM   #6
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
Are you able to read the check engine light code with a handheld scanner or OBDII reader?
My VIN = 2G1FK1EJ9A9105017
Build Date: 04-23-2009 according to:
http://www.compnine.com/vid.php
CamaroSkooter is offline   Reply With Quote
Old 10-15-2012, 02:45 PM   #7
ceyl
ceyl's Avatar
I have. Don't recall all 3 codes but 2 0f them were P0171 and P0172. I can hook up the reader again tonight and list what they were.
Old 10-15-2012, 04:03 PM   #8
CamaroSkooter
P0171 and P0172
To have both of those pop up at the same time usually indicates that something's goofy with the MAF sensor or there's a vacuum issue somewhere in the system.
I'm curious, what kind of air filter are you using?
Old 10-15-2012, 04:26 PM   #9
ceyl
ceyl's Avatar
Paper filter. I've cleaned and replaced the MAF.
Old 10-15-2012, 04:30 PM   #10
CamaroSkooter
Which is strange. Have you checked for vacuum leaks in colder weather?
It could be there's a crack somewhere that only exposes in colder weather because, as you know, when stuff is cold it "shrinks" and maybe when whatever gets warm in the warmer weather, it's expanded enough to plug the vacuum leak.
But diagnosing where that leak is could become quite a hassle
Old 10-15-2012, 11:22 PM   #11
derklug
derklug's Avatar
Drives: 12 Boss 302
Find a shop with a smoke machine that will work with you, explain the problem and see if they will check the system with the smoke machine while the engine is cold. Vac leak is the most likely cause, and I would guess the intake gasket. We have had to drag our machine out into the parking lot on cold mornings a few times, usually on Windstar 3.8's, for this issue.
The biggest mistakes in life come when you know exactly what you are doing.
derklug is offline   Reply With Quote
Old 10-16-2012, 12:20 PM   #12
ceyl
ceyl's Avatar
Thanks Guys for your help. I'll start chasing a vacuum leak this weekend, maybe get an intake gasket ordered just in case I can't find anything else.
Again Thanks.
