Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 09-25-2012, 12:03 PM   #1
wabibito
wabibito's Avatar
Drives: 2013 2SS RS
DIY side camera
Hi guys,
I am not sure if this particular setup has been done before. I tried to search but couldn't see this variance.
Here is a quick write up on my camera setup. I only prototype one side for now. It works great for what i need for somewhat little money. I will add one more on the other side and the front. The camera view can be switch easily using a remote control switch.
Goal:
I would like a camera system to park in tight space and next to high front or side curve. It will also serve the purpose for blind spots while driving on the right side.
Parts"
I don't want something that too obstructing while not use. This will not draw much attention when it in the folded down state.
As for the cameras, I want something small with metal casing. This will prevent damaging from gravel etc.
1 x 3.5" LCD folding screen - 28 dollars
2 x backup camera (left side and right side) 12 dollars each
1 x front facing camera 19 dollars each
Parts pictures:
I ran the camera cable above the wheel well cover across the hood and into through the firewall. There is a hole on the driver side so you don't need to drill (Thanks to the posts in this forum). Since i want this to be on all the time when i drive, tabbed into the lighter outlet.
Here is the working pictures:
wabibito is offline   Reply With Quote
Old 09-25-2012, 03:37 PM   #2
SLO-POKE
SLO-POKE's Avatar
Drives: 2010 Camaro SS/RS Black
Where did you buy this setup?
2010 SS/RS
Corsa Cat Back Exhaust
Injen Cold Ait Intake
All Black Scarallos DriftR Wheels
Front 20X10 275/40ZR20 - Rear 20x11 315/35ZR20
SLO-POKE is offline   Reply With Quote
Old 09-25-2012, 04:01 PM   #3
gr8daneh
460 RWHP 420 RWTQ
gr8daneh's Avatar
Drives: 2SS/RS - IBM LS3 M6
great job...
gr8daneh is offline   Reply With Quote
Old 09-25-2012, 04:15 PM   #4
wabibito
wabibito's Avatar
Drives: 2013 2SS RS
I bought everything from ebay.
Old 09-25-2012, 04:32 PM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
The lighter outlet (12V outlet - whatever you want to call it) isn't on all the time. It turns on when the accessories are turned on. At least that how it was on my and 2010 and now with my 2011.
This is really cool though. Have any pics of how you set up the screen?
Edit - should have waited for it to finish loading. Looks good
Click to view my build thread
The Stig is offline   Reply With Quote
Old 09-25-2012, 04:41 PM   #6
wabibito
wabibito's Avatar
Drives: 2013 2SS RS
Most of the time when i need the camera to work, the car is on. I saw that mistake in my post and fixed it. I want to cut off the power when i leave the car.
Old 09-25-2012, 04:42 PM   #7
parkerss
parkerss's Avatar
Drives: 2011 SS/RS
off the subjet...but how do I start a new thread??? UGH!!!
parkerss is offline   Reply With Quote
Old 09-25-2012, 04:43 PM   #8
wabibito
wabibito's Avatar
Drives: 2013 2SS RS
new thread button on upper left in each of the sub forum.
Old 09-25-2012, 04:44 PM   #9
parkerss
parkerss's Avatar
Drives: 2011 SS/RS
the only place i see that is in the vendor area...hmmm Ill go check some more thanks
Old 09-25-2012, 04:49 PM   #10
babytiger
it's hers...
babytiger's Avatar
Drives: 2011 Camaro 2SS/RS Convertible
very cool. this will start the DIY wheels for many.
babytiger is offline   Reply With Quote
Old 09-25-2012, 05:12 PM   #11
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
slick rick is offline   Reply With Quote
Old 09-25-2012, 05:18 PM   #12
The Stig
The Stig's Avatar
Gotcha
Old 09-25-2012, 05:52 PM   #13
Khmero215
Khmero215's Avatar
Drives: Victory Red 2SS
not worried about the camera getting damage by debris or water?
Khmero215 is offline   Reply With Quote
Old 09-25-2012, 05:56 PM   #14
wabibito
wabibito's Avatar
Drives: 2013 2SS RS
The camera suppose to we weather proof and metal casing. If it last more than one year, I am happy since it is only 12 dollars.
Life is twisted... Everyone should have a sport car...
camera, lcd
