![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
What do you shave with?
Razor and lube, what do ya use?
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
Master of All Things
Drives: '26 Corvette Stingray Join Date: Jul 2009
depends.....normally a razor and soap (I shave in the shower) or my Norelco Electric
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
I have a Trac II razor and use the store brand shave cream from wal-mart, been using that combo for over 20 years.
The Bird is the word! |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 2LT Torch Red C7 Stingray Join Date: Jul 2012
Couldn't tell ya, I don't shave.
Stop writing "vert", ffs!
Drives: 2011 2LT Convertible Join Date: Feb 2012
Cheapest disosable two-blade razors I can find. A 12-pack lasts me well over a year. I don't buy the hype - tried a few "high-tech" shaving "systems" and was never impressed. I shave in the shower with no mirror.
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator |
![]() Drives: Public Transportation Join Date: Dec 2010
Gillette Fusion for Face
Gillette Fusion for undercarridge 2 different ones of course
"30 psi is like bangin a really hot chick with an STD... you want to hit it but are affraid of the consequences"
#7 |
Commits weekly crime
I just realized that having the women of Camaro5 would make these answers far more interesting...
2017 Camaro 1LT - Blue Barchetta IV
I fire up the willing engine, responding with a roar. Tires spitting gravel I commit my weekly crime. |
#8 |
![]() ![]() ![]() ![]() Drives: 11 IOM 2SS/RS M6 w/Hurst Join Date: Nov 2009
Badger hair brush and a Gillete Super 7 razor.
-K |
#9 |
Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
I use a Gillette Mach 5 razor, and I shave dry
#10 | |
#11 |
MAGA
well, any 'professional' shaver/barber will tell you a 'wet shave' is the best shave. in theory, what they say is the best method to shave (in it's somewhat basic form):
Equipment: Safety razor/blades, shaving soap/cream, shaving brush, miscellaneous products (pre-shave creams, scented stuff, etc.) 1.) Shave after a warm/warm-to-hot shower, as this opens up your pores and makes it an easier job for the blade essentially. Or, heat the area with a hot wet washcloth pre-shave. 2.) Some people prefer this, some don't. There are certain 'pre-shave' products you can apply that, in theory, 'stand your hairs up' to allow for a smoother, cleaner-cut shave. I tried some of this stuff, I forget the brand but it's a menthol-type smell and you just rub it on, give it some time, then apply the shaving cream/soap and continue. 3.) Apply your lather and keep your face wet while shaving, you want a nice coat of water on your face so the blade slides, not drags. follow the direction of the follicle, don't 'back shave' where you're going against the grain so to speak. 4.) Rinse and then clean your face. Roll with that, and you'll have a perfect shave every time no irritation. And if you do have a problem with that, bust out the Hibiclens. You'd be surprised how many guys have no clue about shaving and think that those disposable blades are good or do the same job...listen, a sharp edge is a sharp edge, the disposable blades are cheap, yes, but they are cheaply made, of inferior steel, frequently cause unnecessary irritation and a plethora of other things barbers will tell you about. That's cool, if it's your method it's your method but I'm just saying there are less irritating ways to rid your face of hair, and you get to do it with style...plus, it really depends on how often you shave your face. In a month I generally shave 4-10 times, depending. Not often. That means 1 blade will last me 1, 2, 3 months. You can tell when it's dull...just switch it out. You can get a pack of 10 for a few dollars, you just spend the money on the safety razor and other stuff. Guy in Camaro: I buy the disposable blades because they're a good price and last me a long time. If you don't see the irony in the above sentence there's no hope for you
#12 | |
I with ya there.....its worked for me ever since cheap disposables have been exsistance.
#13 | |
![]() Drives: '11 2SS IOM/IO A6, '06 Outback Ltd Join Date: Jun 2012
Not really all that exciting.
My other car is a blue station wagon... no, really!
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS Convertible Join Date: Aug 2012
ivory handle french tip hollow ground straight razor (that my grand father passed down to me and is near 100 years old) and shaving soap
"Bismarck" by Malteserstrasse , Solingen Germany. Circa 1912.
