Old 08-21-2012, 03:30 AM   #1
Jas29
Jas29's Avatar
Drives: 2017 Camaro SS
Car help 01 honda accord has no power
Hey guys my 01 honda accord died today i parked the car at a restaurant and tried using the power locks and it didn't work thinking it wasn't a big deal went inside and ate and came back and it wouldn't start
it wont start, nothing happens when the key is turned no gauges no lights, their is also no light where the key goes. My horn and rear brake lights work so i do have power
the battery is about a 1 1/2 years old and the alternator was changed around 6months ago
tried jump starting the car and checked the fuses
any help will be appreciated had to get the car towed home:(
Jas29 is offline   Reply With Quote
Old 08-21-2012, 07:48 AM   #2
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
Its a HONDA.........
sorry, couldn't resist......but if EVERYTHING is dead but the horn and brake lights, this has got to be major ECM issue. your computer may have just fried. Someone with a diagnostic reader of some sort will most likely need to be hooked up to READ the system.
Old 08-21-2012, 08:05 AM   #3
MLL67RSSS
Drives: car
Battery could have shorted a cell or two. Shorted cell(s) saps most of the power and keeps you from being able to jump it. Heat in Phoenix would take them out pretty regularly. Be fine and all of a sudden, bang...dead. Six cells just over 2 volts each. If you can measure the battery voltage with a digital volt meter, if you read 10 volts you have one cell shorted, 8 volts would be two cells.
MLL67RSSS is offline   Reply With Quote
Old 08-21-2012, 08:43 AM   #4
garcmol
garcmol's Avatar
Drives: 10 1LT SIM; 91 B4C sleeper Z
Check the negative battery cable. Both at the battery and where it's grounded. Make sure it's tight. You have some voltage obviously but not enough to turn the starter.
Happened on my '91 Camaro. I guess this could happen on a Honda as well. (Couldn't resist)
Pedders Pace Car Package, Injen CAI, Flowmaster AT, AAC Lighting, ZL1 fascia/skirts, RKSport Ram Air hood, vented fenders, painted stripes (Gary's Customz), Honor and Valor badged (Thank you, John)
garcmol is offline   Reply With Quote
Old 08-21-2012, 09:04 AM   #5
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
Put an LS3 in it?
Sorry. Couldn't resist. Maybe the squirrel got loose under the hood and chewed through some wires?
chef-beavis is offline   Reply With Quote
Old 08-21-2012, 09:05 AM   #6
chef-beavis
Best of luck BTW
Electrical problems suck. Good luck with the repairs. I have nothing to help but this does bump the post for you.
Old 08-21-2012, 12:15 PM   #7
C5RocksC5
C5RocksC5's Avatar
Drives: 2010 Camaro 2SS/RS
I would check the fuse box for blown fuses...ignition, door locks, etc.
C5RocksC5 is offline   Reply With Quote
Old 08-21-2012, 01:42 PM   #8
Jas29
Jas29's Avatar
Thanks for all the post guys I'll take a look when I get home and report back with what I find
Old 08-21-2012, 08:32 PM   #9
Jas29
Jas29's Avatar
cheap fix main fuse was blown just couldn't see it in the dark
Old 08-22-2012, 12:16 PM   #10
C5RocksC5
C5RocksC5's Avatar
I knew it. It happened to me a few years ago....was a Honda Civic.
