08-13-2012, 04:35 AM | #1 |
Drives: 2019 Camaro 2SS 1LE Join Date: Aug 2011
Why Park In Reverse?
For reasons unknown to me, the driver's manual specifically says to park in reverse, which I have been doing because the driver's manual says so, but in my former manual cars I always used to park in 1st.
Does it really make a difference? I'm guessing it does (somehow) since GM decided to be specific about it. Why does GM say park in reverse as opposed to 1st gear? What gear do you park in and why?
Last edited by Brutal SS; 09-16-2012 at 07:22 AM. Reason: Refining the question. |
08-13-2012, 04:44 AM | #2 |
nuetral they gave me an ebrake so i only use it while parking. besides i tried the whole leave it in gear back when i had a 4th gen and kept letting off the clutch while trying to grab something in the car and bam stall.
08-13-2012, 04:50 AM | #3 |
Drives: 2017 Camaro 1SS Join Date: May 2011
I leave it in first as well I don't know why it calls for reverse
08-13-2012, 04:51 AM | #4 |
Drives: Eve - 2011 Camaro 2SS/RS Join Date: Apr 2012
Yea like he said I leave it in neutral with the ebrake on unless I am parking on a hill. I forget it's in gear and stall it. BUT if you want to leave it in gear it doesn't matter which.
08-13-2012, 04:51 AM | #5 |
I've always left it in first, just habit cause that's what I've done in my other cars. Never noticed that the manual specifically says reverse...
08-13-2012, 04:54 AM | #6 |
More than meets the eye
Drives: 2SS RS M6 06 Jetta TDI 17 Civic EXL Join Date: Jul 2009
reverse
I park in reverse
08-13-2012, 05:07 AM | #7 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
Park in first when I back into a spot, reverse when I pull head on into a spot.
I never park in neutral. The parking brake is not nearly as strong as your engine compression in first gear or reverse. |
08-13-2012, 05:14 AM | #8 |
Drives: Really Slow Join Date: Apr 2010
I've parked with the ebrake on and in 1st gear for 14 years.
08-13-2012, 05:18 AM | #9 |
ZLT!!! COTW (8/5/13)
Drives: 2011 IOM 1LT RS M6 Join Date: Mar 2012
^ this!
08-13-2012, 05:39 AM | #10 |
Just made me wonder why GM felt the need to be specific to "reverse". In other words, in the mind of GM, why would they make that distinction if it doesn't really matter, you know? Is there a reason?
Also, when parking on inclines it seems kind of counterintuitive to park in reverse when facing uphill, and vice versa. Nevertheless, I now find myself in the habit of parking in reverse now because of GMs specific directive and my own ignorance as to how it all works.
08-13-2012, 05:57 AM | #11 | |
08-13-2012, 06:00 AM | #12 | |
MUPPETS |
08-13-2012, 06:17 AM | #13 |
I'm an Engineer
I park in park.
08-13-2012, 06:22 AM | #14 |
Tags |
parking, parking brake, parking procedure, reverse |
