Old 08-09-2012, 06:38 PM   #1
SnoopyAce7
(ʘ‿ʘ)
SnoopyAce7's Avatar
Drives: The one with a roof rack
Quick review of the ZL1 in Forza 4 + tune setup
I just bought the ZL1 from the August carpack and it won me $200k in the S class World Championship.
I will post my upgrades and tune settings below. First off, wow. This thing drives so much better than the SS. Although it still feels like driving a boat at times, it is a much more planted boat than the 2010 SS model. The S class Championship pitted the ZL1 against the Ferrari 599 GTO, Lexus LFA, GT-R, Lambo Reventon, Mclaren MP4-12C, and some others--but the ZL1 still won. My main goal with using the ZL1 against these exotic supercars was to reduce as much weight as possible and THEN add a little bit of power, to achieve a similar power-to-weight ratio that those supercars already have. The ZL1 weighs more than the SS, so weight reduction is PRIORITY.
So here is what I did:
Upgraded to [S/700] class.
ENGINE & POWER
Intake: Race
Fuel Sys: Stock
Ignition: Stock
Exhaust: Race
Camshaft: Stock
Valves: Stock
Displacement: Race
Pistons: Race
Supercharger: Stock
Intercooler: Stock
Flywheel: Stock
PLATFORM & HANDLING
Brakes: Race
Springs & Dampers: Race
Front & Rear Anti-Roll Bars: Race
Chasis: Race
Weight Reduction: Race
DRIVETRAIN
Clutch: Sport
Transmission: Stock
Driveline: Stock
Differential: Race
TIRES & RIMS
Tire Compound: Race
Front Tire Width: 295/35R20
Rear Tire Width: 345/30R20
Wheel: ATS Classic (or your choice)
AERO
None
CONVERSION
None
Tuning:
Tires: 30PSI Front, 30 PSI Rear
Gearing: Stock
Camber: -0.5 Front, -0.5 Rear
Toe: 0 Front, 0 Rear
Front Caster: 4.0
Anti-Roll Bars: 29.23 Front, 23.50 Rear
Springs: 828.0 Front, 812.1 Rear
Ride Height: 5.5 Front, 5.8 Rear
Rebound: 8.7 Front, 8.5 Rear
Bump: 6.6 Front, 6.5 Rear
Aero: n/a
Braking Balance: 60% Front
Braking Pressure: 150%
Differential Accel: 75%
Differential Decel: 75%
The race difficulty settings:
ABS: On
Steering: Normal
Stability: Off
Traction: On
Shifting: Manual w/ clutch (or just manual)
Sugg. Line: Off
Damage/Tire/Fuel: Simulation
Rewind: Off
Opponent Difficulty: Hard (Professional will win you more cash)
Opponent Upgrades: Yes
Class Restriction: Limited
Payout=+120% Earnings
Specs:
60 MPH Lateral G's: 1.14
120 MPH Lateral G's: 1.15
(And that's without aero kits)
Top Speed: 207 MPH
It is a great car in the game. And for anybody who is in the Camaro5 club on Forza, I will share the car in the garage so you can try it out.
Name:  ZL1 LeMans.jpg
SnoopyAce7 is offline   Reply With Quote
Old 08-09-2012, 06:58 PM   #2
LoneStar
LoneStar's Avatar
Drives: 2011 IOM Camaro
Wow, I didn't know you could customize so much in that game! May be time for me to grab a 360...
LoneStar is offline   Reply With Quote
Old 08-09-2012, 09:49 PM   #3
SnoopyAce7
(ʘ‿ʘ)
SnoopyAce7's Avatar
Yeah it's a lot, I know. You can literally end up spending hours test and tuning one car...
Old 08-10-2012, 07:32 PM   #4
DayBreaker
DayBreaker's Avatar
Drives: 2004 impala SS
I'm going to try this out in a little bit.
DayBreaker is offline   Reply With Quote
Old 08-10-2012, 07:43 PM   #5
TheCaptain
N7 Spectre
TheCaptain's Avatar
Drives: 14 ATS Performance 3.6L AWD
Send a message via MSN to TheCaptain
Just got my Ashen Grey Metallic ZL1 today on Forza. Wow it is such an improvement over the SS! It flies!
TheCaptain is offline   Reply With Quote
Old 08-10-2012, 07:54 PM   #6
az2ss
HMFIC
az2ss's Avatar
Drives: 2016 1SS
do you have to purchase this car with xbox points or is it in the actual game?
az2ss is offline   Reply With Quote
Old 08-11-2012, 09:51 PM   #7
MJanowich
Door ding magnet
MJanowich's Avatar
Drives: 2010 Black 2SS/RS
az2ss, you need to buy Forza Motorsport 4 and then you have to spend Microsoft Points to either buy the August Playseat car pack, or buy the ZL1 individually from the car points, which still costs MS points, but less than the full pack.
Snoppyace, I'm assuming you're not running aero because you were racing on Le Sarthe and didn't want the drag.
Try these settings out and see how you like it. It's all from memory right now.
Tuning:
Tires: 28.5 PSI Front, 28.5 PSI Rear
Camber: -1.0 Front, -0.9 Rear
Front Caster: 6.0
Anti-Roll Bars: 23.5 Front, 22.5 Rear
Springs: 650 Front, 650 Rear
Ride Height: as low as it will go
Rebound: 8 Front, 7.8 Rear
Bump: 4 Front, 3.9 Rear
Aero: adjustable front/rear
Braking Balance: 54% Front
Braking Pressure: 88%
Differential Accel: 70%
Differential Decel: 50%
Your ARB settings are going to cause it to understeer way too much on long sweeping turns. The car does much better with a neutral ARB, Spring and Damper setup, with less rear damper to keep the rear end from swinging out on fast left/right switches.
I could probably go softer on the springs for better tire compliance on bumpy roads and hitting curbs, but it does ok with that at 650. Plus, I like Infineon and that track can cause soft sprung cars to bottom out a lot.
One big change you should think about is the brake pressure. With it that high, you are basically turning your brakes into an on/off switch. ABS is going to be on all the time and that's going to make your braking less efficient than if you made it lower and finessed the brake to minimize ABS.
On Suzuka East, which is one of my main tuning tracks, I posted a 53.189 laptime which is #2296 on the leaderboard. I'm a decent driver and I could probably drop it into the 52 second range if I really tried.
"When you're racing, it's life. Anything that happens before or after is just waiting."
MJanowich is offline   Reply With Quote
Old 08-12-2012, 03:53 PM   #8
SnoopyAce7
(ʘ‿ʘ)
SnoopyAce7's Avatar
Tuning:
Front Caster: 6.0
Awesome. I will give this a go. Only reason I didn't put on the aero is because it put me over the S700 limit. I'm sure it'll be great in R3 with the aero.
As for the brakes, it's just a habit for me... It's so hard for me to finess the brake with the controller :/ But I understand what you mean and I don't doubt it. Good pointers man.
Old 08-13-2012, 12:30 AM   #9
DayBreaker
DayBreaker's Avatar
I finally got around to trying this setup. I must say my zl1 whips pretty hard now. I like this setup.
Old 08-13-2012, 09:23 PM   #10
MJanowich
Door ding magnet
MJanowich's Avatar
Snoopy, if the aero puts it into R3, start with the clutch and then start taking off engine bits to keep it in S class. I prefer max handling over a little more power for my Forza cars.
The Performance Index formula in Forza 4 seems to reward having aero because it lowers the top speed number a significant amount, which opens up more PI for handling upgrades. Since most tracks don't really have long enough straights to come close to top speed, it really doesn't penalize you for running aero for just about everything.
It would be interesting to do a comparison of aero vs. no aero on Circuit de la Sarthe to see which one is faster. That's the only track where I'd say no aero has a shot.
Let me know how it's handling for you and if you think it's got too much over/understeer in any particular part of a corner.
Old 08-26-2012, 08:55 PM   #11
ChevyCamaroZL1
ChevyCamaroZL1's Avatar
Drives: 2007 Silver Chevrolet Impala LT
Send a message via Yahoo to ChevyCamaroZL1
its in a car pack for forza 4 it cost 560 microsoft points. trust me its worth it
ChevyCamaroZL1 is offline   Reply With Quote
Old 08-26-2012, 08:57 PM   #12
ChevyCamaroZL1
anyone have a good grip toon for R3 class for the zl1 and i cant find a good drag tune in the storefront
Old 11-20-2017, 02:33 PM   #13
THE FOG
Jake Thomas
THE FOG's Avatar
Drives: 2012 ZL1
Hey,
I know this thread is super old but is it still possible to share cars on Forza 4? I want to get the ZL1 but the marketplace is shut down!!!!!
THE FOG is offline   Reply With Quote
forza 4, gaming, racing, xbox 360
