06-05-2012, 08:29 PM | #1 |
Just installed hand polished/ported RX IM
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
06-05-2012, 08:36 PM | #2 |
Now to take it for a spin....
Seems smoother
06-05-2012, 08:41 PM | #3 |
Drives: 2011 LS Join Date: Oct 2010
Very nice. Welcome to the club. Looking forward to your butt synonym results.
06-05-2012, 08:45 PM | #4 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
MY EYES !!
Nice work, you have more patience than me. |
06-05-2012, 08:46 PM | #5 |
Did you take any more pictures of what the actual porting work looks like? I'd like to see them if you did.
Thanks, Chad |
06-05-2012, 08:57 PM | #6 |
Cedar Creek Woodshop
Sexy!
2014 Black 2SS/RS 1LE
06-05-2012, 09:12 PM | #7 | ||
Vent seriously even a caveman can do this mod. The key is having that essential wratcheting 13mm box wrench. The trickiest part is pre-lining up the rear IM bolt. Everything else is stoooopid easy. It took me only 2 hrs and I stopped to talk to my neighbors for about 20 minutes. I got started at 6:30pm and had all the tools put away by 8:35pm. You can DO It. Quote:
So far so so good. I put about 15 miles on it. I'm sure as the ECU dials the new airflow in its going to get a bit better. I also cleaned my air filter so I'm sure that is contributing to some of this improvement.
06-05-2012, 09:54 PM | #8 |
I was wondering about the exhaust sound, as you know I loved your sound. Glad improved rather than the other. Mine really seems to run the rpm range much faster. It feels I am pushing when I am not.
06-05-2012, 10:06 PM | #9 |
Looks nice! How did you like polishing that thing? Sucks don't it?
06-05-2012, 10:20 PM | #10 |
Drives: White M6 1LT RS Join Date: Mar 2010
It takes a while for the ECM to get used to this.. I saw a performance boost after I cleared my codes with Trifecta and the gains kept getting better as the miles went by.. Now about 50 miles later WOW!!! What a fun car to drive.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
06-06-2012, 12:03 AM | #11 |
Idk ask Tracy at RX. They're the ones who did it.
06-06-2012, 12:09 AM | #12 |
That's what I'm figuring. So you think I should re flash the ECU or just let it learn? I've put about 30 miles on it and what I was noticing after 30 miles in 85 degree weather with about 50% humidity was the 1st-2nd gear shift chirp has a bit more bite. When my car was stock, it would have never chirped anything in those conditions.
06-06-2012, 12:26 AM | #13 |
it's mind bottling..
Drives: SGM Join Date: Apr 2011
how much is the beauty ?
06-06-2012, 02:09 AM | #14 | |
