Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 4th Generation Camaros
Old 05-27-2012, 11:11 PM   #1
73camarolt
73camarolt's Avatar
Drives: 2002 Camaro SS
Car won't start help!!
So I'm at a loss. Today I drove my car multiple times. Came home and decided to put it on a small hydraulic lift to adjust my exhaust, it hanging low. So I'm getting ready to pull off the lift to go hang with some friends. I get it, all dash lights come on, including the security light. Now it won't start. I did not touch anything on my car other then my exhaust. It doesn't even attempt to turn over. Don't really know where to look next.
2002 Camaro SS- BTR Stage 3, 799 Heads, Bolt on's Tuned by John at Broadview Automotive.. 420hp and 400tq
73camarolt is offline   Reply With Quote
Old 05-27-2012, 11:13 PM   #2
IROCanSS
Drives: 89 IROC 350
Sounds like something with the PASSkey. The chip in your key. Try another key if you have two sets.
IROCanSS is offline   Reply With Quote
Old 05-27-2012, 11:48 PM   #3
73camarolt
73camarolt's Avatar
Yep tried it. Nothing. Pulled battery nothing. Checked all fuses nothing. I'm just lost. I didn't think adjusting a exhaust would shut my whole car down lol
Old 05-28-2012, 04:57 PM   #4
helmincamaro
Official Lounge BAMF
helmincamaro's Avatar
Drives: '97 Camaro
Send a message via AIM to helmincamaro Send a message via Yahoo to helmincamaro
Turn the ignition on for a few minutes, light should go out (3-5 minute reset time). If it doesn't, the chip is bad in your key.... if both keys don't work, its probably the sensor in the ignition. You can either get a new ignition ($$$) or a pair of $0.20 resistors from radio shack and hard wire in a "chip" and just bypass the one in the key. I did it, never had a problem since.
Originally Posted by BowtieBelle View Post
I so didn't want to see poor dead white mouse butthole
helmincamaro is offline   Reply With Quote
Old 05-28-2012, 05:19 PM   #5
IROCanSS
Drives: 89 IROC 350
He's right, you just need to find out what resistor you need. I think there are 13 different ones. There should be a number on your key.
Stupid question...
Is the car stick? Did you knock off the clutch sensor and the car doesn't know the clutch is depressed?
Old 05-28-2012, 05:21 PM   #6
IROCanSS
Drives: 89 IROC 350
I guess same could be the case with auto. Bad neutral safety switch... or you accidentally unplugged it.
Old 05-28-2012, 06:07 PM   #7
73camarolt
73camarolt's Avatar
Yep this was the problem. Both keys didnt work. Did that this morning and seems fine. Thanks for the help.
Stupid question...
Yes the car is a stick. This was honestly my first thought. I was thinking maybe when it put it on the lift it knocked the sensor loose. But after looking it over everything seemed fine. But the car is back and running. I was just happy it happened inside my garage and not when i was in Ocean city last weekend.
Old 05-28-2012, 07:05 PM   #8
IROCanSS
Drives: 89 IROC 350
Good deal!
Old 03-12-2013, 05:42 PM   #9
TopFuelTim
Drives: 2002
How can I do a bypass with Radio Shack resistors?
My daughter has a 2002 Camaro V6 automatic, and it didn't start (no action at all).
How do you do the bypass with the Radio Shack resistors?
I kept fiddling with the car, and held the key in the start position while moving the console gear selector. All of a sudden, out of the blue, it started. Told her to bring it back to my place and I will try to figure it out.
Thanks,
Tim Glover
TopFuelTim is offline   Reply With Quote
