05-21-2012, 02:25 PM | #1 |
Drives: Black Camaro 2SS/RS 1LE Join Date: Jun 2011
How to unplug the stock gas pedal to install the ZL1 pedal?
I was able to reach up in and unbolt the 3 bolts to remove the whole gas pedal unit, but I can't figure out what to pull, pop, or pry to get the plug to "leave" the stock pedal!!! I see a black piece that might need to be pryed up over the little sharp piece sticking up......I don't know and I'm hot & sweaty and mad as F%%K right now!!!!
05-21-2012, 02:51 PM | #2 |
Drives: 62 Chevy & 2021 1SS/1LE manual Join Date: Aug 2010
im not by my car right now but i took my pedal out to install a wider pedal for track. i dont remember any problems at all unpluging the connector. i had it in and out twice during the fitup. your probably being to gental with it. now dont break it and blame me but it should just unplug i think.
how different is the new pedal you have. do you have pics of it? |
05-21-2012, 02:55 PM | #3 |
OK I'll give it a better tug. But isn't there a plastic flap that keeps the plug from pulling out from the pedal unit? Not that there's anything that would make it do that. I'm installing the ZL1 pedals that I bought from GM Parts House. No pictures of mine, but others have posted pics of their pedals.
05-21-2012, 03:40 PM | #4 |
I got it! Your advice did help JOHNSONROD. I was gentle, but I used a small screw driver to pry (although it almost popped) it out. The plug slid into the ZL1 unit and it was in all the way when I heard a slight "click" noise.
How tight should the bolts be? I've really torqed them tight and I don't want to strip one of them. |
05-21-2012, 03:45 PM | #5 |
Drives: 2021 1LE Join Date: Jul 2011
Not too tight at all... I went about a quarter turn past hand tight with a quarter inch drive.
05-21-2012, 04:04 PM | #6 |
...so should I maybe let them off a tiny bit?
05-21-2012, 04:20 PM | #7 |
They were not very tight at all when I undid them to do the install. They are there just to keep the peddle in position they aren't under any load at all.
05-21-2012, 06:53 PM | #8 |
Ya I noticed that too. Its such an tight, awkward spot and I thought I'd have a fight on my hands to turn the bolts loose. I was surprised how loose they were. I guess I never really paid attention, but the accelerator pedal looks lower/closer to the floor than it did before.
Did you the ZL1 gas pedal is just an "SS" gas pedal with the aluminum cover crimped over it ? No wonder it was a plug and play mod. I will try and tackle the brake and clutch pedals tomorrow. I like the look of the new pedals |
05-21-2012, 10:19 PM | #9 |
Use a little soap on the covers... I started from the bottom and worked around to the top... a bit of a pain but they do fit.
05-21-2012, 11:15 PM | #10 |
Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
i put my covers in the oven for 10mins on 200 and i started from the top left corner and worked it around
Email: rdurso1@yahoo.com |
05-22-2012, 09:09 AM | #11 |
The smaller pedals are on my to do list today. I think putting a mirror on the floor so I can see what I'm doing will help things go smooth. Thank you tramtwo & camaro2lt for the suggestions on how to make the job easier.
When you removed the stock accelerator and gas pedal, did it come off scary easy? |
05-22-2012, 01:01 PM | #12 |
The Dude Abides
Drives: Black 2SS M6 Join Date: Apr 2010
When I swapped mine out for the ZL1 pedals I was actually quite surprised how easy the bolts were to loosen up as well . Nice mod though for sure
2010 Black 2SS/LS3/M6 Kooks 1 7/8 Ceramic Coated Headers, Borla ATAK CB , JRE Tune , Halltech Yellow Jacket CAI ,VMax Ported TB, PFADT Coilovers,Forgestar CF5's Textured Gunmetal w/Nitto Invo's 275/315 ,Hurst Billet Plus 2 Shifter AAC P13W Plasma LEDw/DRL Harness ,30% Tinting,
07-14-2012, 11:26 PM | #13 |
Drives: 2010 Camaro 2SS L99 white and red Join Date: Feb 2012
Hi guys, I put in the ZL1 pedals on my L99 earlier today. The gas pedal was pretty easy, but the brake cover was a total different story. I finaly got it in but it took me about 30 minutes. I drove the car around and I could tell a big difference in better throttle responce and how the car picks up speed faster now without having to step on it as much. I love it!
03-23-2013, 08:49 AM | #14 | |
Founder - Michigan FBody
Drives: 1994 Camaro LT1, 2012 Camaro 2SS/RS Join Date: Jun 2008
Better throttle response by swapping the pedals? Seriously?
2012 Camaro 2SS/RS L99 - "Zooma"
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed "Gone But Not Forgotten" 2016 Camaro 1LT A8 - "Elmo" 2014 Camaro 1LT M6 - "Cherry Bomb" 2012 Camaro 1LS M6 - "Clifford" Michigan FBody Association http://www.mifbody.com/ |
