05-16-2012, 12:28 PM | #1 |
Drives: 2010, 2LT, RS, 6M, ABM (#1893) SOLD Join Date: Mar 2011
Barton Shifter Installed, V6
Installation went pretty well, just jacked the front up in the driveway, with a couple jack stands of course, and went by the instructions provided. (mostly!)
the one thing i did NOT do, was loosen the cross member bolts. there was plenty of room to do the job. another note; don't forget to disconnect the centering springs before attempting to push the OEM shifter out, DOH!!!!! IIRC they took an 8mm allen head to remove the anchor bolts. i did not reinstall the springs. initial reaction is very good, will need to drive it some more to get a good feel for it, especially since i installed a pistol grip shift handle at the same time. |
05-17-2012, 12:48 AM | #2 |
Drives: Really Slow Join Date: Apr 2010
awesome
05-17-2012, 06:50 AM | #3 |
pistolgripcopo1
Drives: 2010 SS Camaro Carbon fiber gray Join Date: Mar 2012
pistolgrip not with that shifter.
05-19-2012, 08:48 AM | #4 |
Drives: Camaro 1SS/1LE Join Date: Sep 2011
Do you think that reinstalling the springs would make a difference?
05-19-2012, 09:53 AM | #5 |
it feels pretty solid without them, installing them might make it feel a bit more rigid, but i am liking it so far. not sure why the V6 has them and the V8 not??
05-19-2012, 06:55 PM | #6 |
one drawback i discovered this morning!!!
51 deg, shifter was cold!! can't imagine what it will be like when it gets really cold this winter!!! i'll have to get a leather covered shift ball for winter!!! |
05-19-2012, 07:00 PM | #7 |
Drives: 2010 Camaro LS M6 Inferno Orange Join Date: May 2010
You will not want to touch the aluminum on a hot summer day either.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers Find me on Facebook: http://www.facebook.com/gahammerle |
Tags |
barton, pistol grip, shifter |
