02-27-2012, 11:50 PM | #1 |
Why cant I see
My Gauges seem to be hiding behind the steering wheel no matter how I sit or how I adjust the seat.
I am 6'2 and unless I raise the wheel to highest position (not comfortable by any means), the top of the wheel blocks the speedo. I can see the rpm gauge from about 3500+ which is ok. So far I have had to rely on the lcd gauge tp determine my speed. Anyone else have this issue? Other than that this beast is a blast |
02-27-2012, 11:51 PM | #2 |
Weird, I'm the same height and have no problems. Perhaps you are sitting too close or your seat height needs to be lowered.
02-28-2012, 12:03 AM | #3 |
I have tried different seat heights and same thing. For me I am most comfortable with the seat in the lowest position (not a ton of headroom). I am pretty far back with the wheel fully extended. I will have to try some more positions but I feel like I have tried everything. Seems like no matter how I sit the top of wheel is blocking the speedo
02-28-2012, 12:09 AM | #4 |
All blackkk
Drives: 2010 2SS/RS LS3 Join Date: Oct 2011
No way do I have any issues, around 6'1 with a very tall torso and pretty big
Drivin it like I stole it.
02-28-2012, 12:10 AM | #5 |
Drives: 2011 RJT Camaro LT2 RS auto shift Join Date: Dec 2011
I am 5ft 101/2 in. I have my seat at the lowest and the steering set at the highest and closest to the dash. I can see the speedometer and tach good. Have you rasied the steering wheel?
Caddy
02-28-2012, 12:16 AM | #6 |
Thanks for the input. If I move the wheel up real high i can see the gauges well but I do not like having the wheel up high. Sounds like I need to try some more adjustments.
02-28-2012, 12:23 AM | #7 |
Drives: 2013 Cyber Gray Metallic Chevy Volt Join Date: Dec 2011
Same but I just use the computer.
02-28-2012, 12:24 AM | #8 |
Drives: 2011 CGM 1SS L99 Join Date: May 2011
Im about 6 ft. and have the same problem as you. My seat is all the way down and steering wheel is at its lowest. Most comfortable position for me and i can't see the gauges either. The only thing that works is ducking down to see which is a minor PITA.
02-28-2012, 12:29 AM | #9 |
Glad I am not the only one! fortunately i can see the upper end of the rpm gauge. The speedo is pretty much useless the way I have it now. Thankfully the computer has been working well but it is cool to see the analog speedo if possible. I am still going to try some other configs.
02-28-2012, 12:51 AM | #10 |
Switchin' n Twitchin'
Drives: 2011 Camaro Join Date: Nov 2010
I don't know if this helps, but the wheel is telescoping as well as tilt...
I am not childish, you're just being a poopy head!
02-28-2012, 12:56 AM | #11 |
Drives: 2010 Camaro 1LT/RS M6 Join Date: Nov 2007
I have the tilt adjusted slightly higher than I normally would so that I have a clear view. Try adjusting the telescoping closer to the dash like FL1CK suggested. That might help too.
Trifecta tune, Vararam Intake, VMAX throttle body and manifold insulator, RxPerformance Catch Can, , MRT v1.0 and Louvers, Barton shifter, BMR strut tower brace, RED dome light and Plasma LED DRL's, fieldgoal00's Halo 1 harness, hood spears/side stripes, rain guards, custom bowtie, Team LLT badges, headlight and foglight covers, taillight and side marker covers, backup light covers, WeatherTech floormats
02-28-2012, 05:36 AM | #12 |
Formerly Lil'BlueCoupe
Drives: '13 2LT/RS Vert, Summit White Join Date: Jul 2009
There is gauges up there?
I have never used the analog speedometer, I just usually have the center DIC set on the speedo, I have also heard a rumor that these things have a HUD option. All kidding aside if I wanted to I can also hook up the ol' trusti Nuvi navigator and just set it on speedometer, heck it is more accurate than the one in the car anyways.
02-28-2012, 05:45 AM | #13 |
Orange Camaros Rule!
Drives: 2010 1SS LS3 RS IOM Join Date: Feb 2010
Drive by sense of smell.
Mary - Orange Camaros Rule! |
02-28-2012, 05:47 AM | #14 |
Talk about learning new stuff! I too can't see worth beans on any of the dials, so I just rely on the HUD. In fact, while I did know that I could tilt the wheel up or down, I didn't know there was a telescopic feature associated as well!
Gonna have to give that a try; is it regulated by the same lever as the tilt positioning? Otherwise, I'll have to partake of a time-honored acronym (RTFM).
