Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 10-09-2011, 09:51 AM   #1
scruffyluv
CB5thGEN
Drives: 2013 2SS/RS BRM 1LE, 05 Trailblazer
anyone else have a slow leak in their tires?
Been noticing for the past couple of months now that my right read tire has a slow leak. No.. there is nothing it in and I havent run over anything. We put air back in and two-three weeks later its low again. And now my front tires are starting to do the same thing. Cant afford to buy new tires this time of year. Anyone else have this issue?
scruffyluv is offline   Reply With Quote
Old 10-09-2011, 10:18 AM   #2
CrazyDan
Drives: 2011 SS
This is normal atleast for my car getting continental tires this time around
CrazyDan is offline   Reply With Quote
Old 10-09-2011, 10:30 AM   #3
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
That isn't normal for it to leak that much. Take it to the dealer. You may have a bad valve stem or slow leak around the bead. Either problem can be fixed pretty easily.
Normally, I sometimes need to put air in my tires when the weather gets cold going into fall. A warm tire will have more pressure than a cold tire. So when the weather gets cold, I may need to put a little in. But every 2 or 3 weeks means there is a leak somewhere IMHO.
Darth_Emma is offline   Reply With Quote
Old 10-09-2011, 10:46 AM   #4
scruffyluv
CB5thGEN
my light comes on after about 20 mins of driving, after the tires warm up.... yesterday it came on as I pulled out of the driveway!
Old 10-09-2011, 10:54 AM   #5
Bomber
Byron4
Bomber's Avatar
Drives: SS RJT
I just got my car a week ago and I had to put air in every other day, then found out I wasn't putting in enough air. I then took it to the dealer and they aired it up to the specs. I only drove it once since Thursday but when I checked the pressure on the TPMS it showed all the tires went down 1 PSI each. The dealer told me that here in Colorado that the tires can fluctuate 3-5 PSI or even more because the weather can be 20 in the morning and 70 by afternoon and back to 20/30 by night. If it keeps going down I am taking it back to the dealer to make them find the leak.
Bomber is offline   Reply With Quote
Old 10-09-2011, 11:05 AM   #6
1WILDSScmrg
1WILDSScmrg's Avatar
Drives: 2010 Camaro SS inferno orange
mine do the same. i put air in my back left every 3 days or so. been like that for 2 years now.
1WILDSScmrg is offline   Reply With Quote
Old 10-09-2011, 03:16 PM   #7
Darth_Emma
Darth_Emma's Avatar
That issue sounds like your TPMS sensors may not paired properly. I had some sensors on some after-market wheels that didn't work with my car. The light came on after 20 mins of driving. Have your dealer repair your sensors or you can do it yourself using the method described in your owner's manual.
Old 10-09-2011, 03:43 PM   #8
VR Code R6P
Drives: 2011 Race Red GT500 w/ SVT Perf Pkg
I recently had a tire leak so slow, they could not find it the first two times I took it in, even though they dismounted it and visually examined as well. Third time around they found a very small nail just barely poking through to the inside. It has been fine since they patched it.
IMO, if your tire goes down within a few weeks, it has a leak somewhere. Good luck.
VR Code R6P is offline   Reply With Quote
Old 10-09-2011, 04:05 PM   #9
Mightygrasshopper
Drives: 2012 45th anniversary edition 'vert
Hey guys I took mine to the dealer a few weeks back. There's a bulletin on this. Apparently there is dirt that collects between the rim and rubbers that results in leaking. I was putting air in every 3 weeks or so. Not normal and I was using separate tire pressure reader to verify the low air.
MightyGrasshopper
www.mightygrasshopper.com
Into health, wellness and fitness? Check out my site for natural health product reviews, health articles and industry news.
Want to get into summer time shape? I'm a former fatty who's lost the weight - "Train With Me" for FREE - sexy abs in 16 weeks! Just follow along!
Mightygrasshopper is offline   Reply With Quote
Old 10-09-2011, 04:30 PM   #10
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Link to TSB please?
ihaveacamaro is offline   Reply With Quote
Old 10-09-2011, 05:46 PM   #11
Kahdir
Kahdir's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
Not normal... only time my tires lose pressure (+1 psi) is when i have something metal in the tread
Just replaced my second rear tire...
Kahdir is offline   Reply With Quote
Old 10-09-2011, 09:21 PM   #12
Tom0662
Drives: 1998 Camaro SS
Trunk Monkey pranks.
Tom0662 is offline   Reply With Quote
Old 10-09-2011, 09:32 PM   #13
Sidd218
GM Loyal
Sidd218's Avatar
Drives: 2006 Impala SS
Mine does that too!
I never hit anything, butt 1 day Im leaving for work, and the rear tire is flat, I put the dummie on and the dealer replaced it cause its still under warranty
2011 2LT RS
Sidd218 is offline   Reply With Quote
Old 10-09-2011, 10:26 PM   #14
AieaboyHI
Drives: 2011 IBM 1LT RS
My LR loses about 6-8 PSI over the course of a month. All the other tires are ok.
AieaboyHI is offline   Reply With Quote
Question about mixing tires Sean_W Wheels and Tires Talk Sponsored by The Tire Rack 2 03-26-2011 02:36 PM
All season tires on RS??? iyam_lorne Wheels and Tires Talk Sponsored by The Tire Rack 6 10-07-2010 09:25 AM
Tires... flat spots jrcase 5th Gen Camaro SS LS LT General Discussions 27 03-02-2010 09:03 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Help with selling a car: tires Teddydog General Automotive + Other Cars Discussion 2 08-03-2009 01:28 AM
