Old 10-02-2011, 04:20 PM   #1
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
Computer help plz.
Trying to dual boot xp pro n win2k pro.
Installed xp pro to a different drive, fresh install not an upgrade.
Well it still screwed with my 2k install.
Was able to put back my system file so it would boot but once in 2k it says pagefile is off n explains how to turn it back on but the computer wont start enough to change it.
Tried a backup of 2k folder, this page file seting must be elsewhere. Any clue how to get it turned back on? Safe mode is no go....
2ndgenz28 is offline   Reply With Quote
Old 10-02-2011, 05:01 PM   #2
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
I'm guessing the drive letter was changed (not by you) during install. See if the following kb helps:
http://support.microsoft.com/kb/249321
EDIT: you could also try to fix the master boot record, but not sure if you need to remove the other drive for it to rebuild the boot record to assign the correct drive letter again to your 2k drive
Iwantone2 is offline   Reply With Quote
Old 10-02-2011, 06:54 PM   #3
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Neither of those, n dunno why i dual booted xp home for a bit but didnt want to commit since its limited. But it went fine. Its clear xp pro messed with my 2k files but dunno where to find the file with those settings to turn back on page file
Old 10-03-2011, 11:37 AM   #4
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Well u were half right but its goofy. Win2k is on d, spare storage ntfs drive was h, and where xp was installed. But xp keep chaging h to g. No reason win2k should even care.......
Old 10-03-2011, 11:51 AM   #5
gieselho
Drives: black type suzuki
gieselho is offline   Reply With Quote
Old 10-03-2011, 12:57 PM   #6
Havok
Drives: 2010 IBM 2LT RS
Why not do a virtual machine on your computer, and why are you dual booting two windows os's?
Havok is offline   Reply With Quote
Old 10-03-2011, 10:23 PM   #7
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
back up sort of, installed new drives in july so had sort of fresh copy of win2k I could just dump back, just back up what changed in the mean time.
was a PITA tried every back way possiable, a usb to ide adapter would of make it tons easier.
now just wipe the new drive blank, copy this to that, add back what has changed, and won't be putting back xp pro any time soon. [less I get a hotswap sata drive]
Fuse pull to reset computer faninc Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 18 11-19-2010 06:36 AM
Stock computer limits MechEng Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 09-12-2010 01:47 PM
Camaro Computer GearHeadPeter 5th Gen Camaro SS LS LT General Discussions 2 09-10-2010 03:22 PM
OT - Need Computer Advice Mblock66 Off-topic Discussions 29 08-20-2010 03:29 PM
Camaro Computer hacks? 2Muchmark 5th Gen Camaro SS LS LT General Discussions 17 02-06-2010 04:04 PM
