dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 09-29-2011, 07:05 PM   #1
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Mod the LSA or Sell It And Replace with Supercharged LS7 ???
Ladies and Gents,
Here is where I am struggling and I will need to make a decision fairly soon. I am currently considering two choices and I would like your opinions please along with any supporting information to back your stance:
Turn the LSA into a 417 Stroker with GT-9 or GT-11 cam, forged pistons, 2300 maggie, 10/14 rib pulley upgrade cranking about 750 hp.
OR
Sell the stock 580 HP LSA engine for about $12K and replace with an LS7 block, LS9 heads, forged pistons, GT-9 cam, 10/14 rib pulley upgrade, headers, cranking about 775 HP.
So what do you guys say???
BiggFoot is offline   Reply With Quote
Old 09-29-2011, 07:18 PM   #2
91Z28350
Drives: 2012 GT500 SVTPP 2010 Traverse LTZ
LS7 is a great motor, but if you are going to go with a 427, I have heard the RHS block has thicker cylinder walls and holds up to boost better. There is a reason why GM went with the 6.2 in the ZR1!
One more point, myself, I like the whipple, great whine and from what I have read and seen, the 2.9L Whipple seems to make = or more HP at lower boost and lower IAT, for about the same cost.
91Z28350 is offline   Reply With Quote
Old 09-29-2011, 07:38 PM   #3
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
LS7 block doesn't like boost...very thin cylinder walls to manage that 427ci volume...
Old 09-29-2011, 07:44 PM   #4
IOMZL1
IOMZL1's Avatar
Drives: 2015 Z/28 | 2017 Viper ACR Extreme
This. And the first post too.
IOMZL1 is offline   Reply With Quote
Old 09-29-2011, 07:45 PM   #5
Mr. Wyndham
Wouldn't the first option be a little less expensive, too?
Old 09-29-2011, 07:53 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
LS7 block is relatively expensive. Stroke LSA and call it a day, after your cam ans SC. How much power anyways? Maybe you could get by with rods and pistons on LSA. Same heads as LS9...
'20 ZL1 Black "Fury"
Old 09-29-2011, 07:59 PM   #7
91Z28350
My understanding also is the LSA block has additional reinforcement in the block over the LS3/LS9 block, though I do not know that for fact, I seem to remember reading it in the description of the LSA motor. If you are going for increased boost, forge the LSA, get a larger twin screw blower or TT and have at it!
Old 09-29-2011, 09:02 PM   #8
GM4lyfe
A GM nut-swinger!
GM4lyfe's Avatar
Drives: A Car
All Al 6.2's should be the same. After the LS9 came out the LS3 got updated to the new casting.
2004 GTO Quicksilver
2009 G8 Liquid Red
2005 CTS-V Black Raven
GM4lyfe is offline   Reply With Quote
Old 09-29-2011, 09:09 PM   #9
GM4lyfe
A GM nut-swinger!
GM4lyfe's Avatar
Drives: A Car
Originally Posted by BiggFoot View Post
Ladies and Gents,
OR
A cheaper option:
Pulley down the stock s/c
Forge pistons, rods
Cam
Tune
Headers
See where that will put ya.
Stock s/c not good enough go with the LS9 s/c. They do it for the CTS-V.
So far what has been offered to the LSA/LS9 is s/c aftermarket inlets and larger heat exchangers net great results.
2009 G8 Liquid Red
Old 09-29-2011, 09:09 PM   #10
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
You can get that much horsepower out of the LSA without spending as much money.
Old 09-29-2011, 09:11 PM   #11
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
+1
GEEo is offline   Reply With Quote
Old 09-29-2011, 11:41 PM   #12
payne.jeremy82
payne.jeremy82's Avatar
Drives: 2002 Lifted Trailblazer
Lingenfelter is where im going 700+hp at the crank Lingenfelter is the choice for me
payne.jeremy82 is offline   Reply With Quote
Old 09-30-2011, 12:38 AM   #13
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
There are better options than the LS7 if you want to swap in a supercharged engine.
Originally Posted by payne.jeremy82 View Post
http://www.lingenfelter.com/engine-p...charged-engine-
This is where im going 700+hp at the crank Lingenfelter is the choice for me
I just lost a little respect for Lingenfelter after looking at that URL (link is broken by the way). Someone over there needs to be told that the LS3/L99/LSA/LS9 engines are not 378 cubic inches, because they're not exactly 6.2L ... they're 6.162L, which works out to 376 cubes. I thought they'd be better than that.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 09-30-2011, 12:47 AM   #14
a_Username
a_Username's Avatar
Drives: 2010 2SS Camaro
Apparently they listened to ya... I just got "page not found."
a_Username is offline   Reply With Quote
