Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 09-26-2011, 08:57 PM   #1
steeleshark2
steeleshark2's Avatar
Drives: 2010 Transformer 1SS Camaro
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles
GM OBD2 Module Trouble Code Comprehensive List
P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
P0011 "A" Camshaft Position - Timing Over-Advanced (Bank 1)
P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
P0014 "B" Camshaft Position - Timing Over-Advanced (Bank 1)
P0015 "B" Camshaft Position - Timing Over-Retarded (Bank 1)
P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
P0021 "A" Camshaft Position - Timing Over-Advanced (Bank 2)
P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 "B" Camshaft Position - Actuator Circuit (Bank 2)
P0024 "B" Camshaft Position - Timing Over-Advanced (Bank 2)
P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2)
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
P0100 Mass or Volume Air Flow Circuit
P0101 Mass or Volume Air Flow Circuit Range/Performance
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit
P0111 Intake Air Temperature Circuit Range/Performance
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit
P0116 Engine Coolant Temperature Circuit Range/Performance
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0127 Intake Air Temperature Too High
P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
P0130 O2 Sensor Circuit (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit (Bank 1 Sensor 3)
P0150 O2 Sensor Circuit (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit (Bank 2 Sensor 3)
P0168 Fuel Temperature Too High P0170 Fuel Trim (Bank 1)
P0171 System too Lean (Bank 1) P0172 System too Rich (Bank 1)
P0173 Fuel Trim (Bank 2) P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2) P0176 Fuel Composition Sensor Circuit
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor "A" Circuit
P0181 Fuel Temperature Sensor "A" Circuit Range/Performance
P0182 Fuel Temperature Sensor "A" Circuit Low Input
P0183 Fuel Temperature Sensor "A" Circuit High Input
P0184 Fuel Temperature Sensor "A" Circuit Intermittent
P0185 Fuel Temperature Sensor "B" Circuit
P0186 Fuel Temperature Sensor "B" Circuit Range/Performance
P0187 Fuel Temperature Sensor "B" Circuit Low Input
P0188 Fuel Temperature Sensor "B" Circuit High Input
P0189 Fuel Temperature Sensor "B" Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Circuit
P0196 Engine Oil Temperature Sensor Circuit Range/Performance
P0197 Engine Oil Temperature Sensor Circuit Low
P0198 Engine Oil Temperature Sensor Circuit High
P0199 Engine Oil Temperature Sensor Circuit Intermittent
P0200 Injector Circuit P0201 Cylinder 1 - Injector Circuit
P0202 Cylinder 2 - Injector Circuit
P0203 Cylinder 3 - Injector Circuit
P0204 Cylinder 4 - Injector Circuit
P0205 Cylinder 5 - Injector Circuit
P0206 Cylinder 6 - Injector Circuit
P0207 Cylinder 7 - Injector Circuit
P0208 Cylinder 8 - Injector Circuit
P0209 Cylinder 9 - Injector Circuit
P0210 Cylinder 10 - Injector Circuit
P0211 Cylinder 11 - Injector Circuit
P0212 Cylinder 12 - Injector Circuit
P0213 Cold Start Injector 1
P0214 Cold Start Injector 2
P0215 Engine Shutoff Solenoid
P0216 Injection Timing Control Circuit
P0217 Engine Coolant Over Temperature Condition
P0218 Transmission Fluid Over Temperature Condition
P0219 Engine Over speed Condition
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit
P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance
P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch "B" Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch "C" Circuit
P0226 Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance
P0227 Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch "C" Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch "C" Circuit Intermittent
P0230 Fuel Pump Primary Circuit
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Turbo/Super Charger Over boost Condition
P0235 Turbo/Super Charger Boost Sensor "A" Circuit
P0236 Turbo/Super Charger Boost Sensor "A" Circuit Range/Performance
P0237 Turbo/Super Charger Boost Sensor "A" Circuit Low
P0238 Turbo/Super Charger Boost Sensor "A" Circuit High
P0239 Turbo/Super Charger Boost Sensor "B" Circuit
P0240 Turbo/Super Charger Boost Sensor "B" Circuit Range/Performance
P0241 Turbo/Super Charger Boost Sensor "B" Circuit Low
P0242 Turbo/Super Charger Boost Sensor "B" Circuit High
P0243 Turbo/Super Charger Wastegate Solenoid "A"
P0244 Turbo/Super Charger Wastegate Solenoid "A" Range/Performance
P0245 Turbo/Super Charger Wastegate Solenoid "A" Low
P0246 Turbo/Super Charger Wastegate Solenoid "A" High
P0247 Turbo/Super Charger Wastegate Solenoid "B"
P0248 Turbo/Super Charger Wastegate Solenoid "B" Range/Performance
P0249 Turbo/Super Charger Wastegate Solenoid "B" Low
P0250 Turbo/Super Charger Wastegate Solenoid "B" High
P0251 Injection Pump Fuel Metering Control "A" (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Balance
P0298 Engine Oil Over Temperature
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0313 Misfire Detected With Low Fuel
P0314 Single Cylinder Misfire (cylinder not specified)
P0320 Ignition/Distributor Engine Speed Input Circuit
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Input Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Input Intermittent (Bank 2)
P0335 Crankshaft Position Sensor "A" Circuit
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0337 Crankshaft Position Sensor "A" Circuit Low Input
P0338 Crankshaft Position Sensor "A" Circuit High Input
P0339 Crankshaft Position Sensor "A" Circuit Intermittent
P0340 Camshaft Position Sensor Circuit
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit
P0351 Ignition Coil "A" Primary/Secondary Circuit
P0352 Ignition Coil "B" Primary/Secondary Circuit
P0353 Ignition Coil "C" Primary/Secondary Circuit
P0354 Ignition Coil "D" Primary/Secondary Circuit
P0355 Ignition Coil "E" Primary/Secondary Circuit
P0356 Ignition Coil "F" Primary/Secondary Circuit
P0357 Ignition Coil "G" Primary/Secondary Circuit
P0358 Ignition Coil "H" Primary/Secondary Circuit
P0359 Ignition Coil "I" Primary/Secondary Circuit
P0360 Ignition Coil "J" Primary/Secondary Circuit
P0361 Ignition Coil "K" Primary/Secondary Circuit
P0362 Ignition Coil "L" Primary/Secondary Circuit
P0370 Timing Reference High Resolution Signal "A"
P0371 Timing Reference High Resolution Signal "A" Too Many Pulses
P0372 Timing Reference High Resolution Signal "A" Too Few Pulses
P0373 Timing Reference High Resolution Signal "A" Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal "A" No Pulses
P0375 Timing Reference High Resolution Signal "B"
P0376 Timing Reference High Resolution Signal "B" Too Many Pulses
P0377 Timing Reference High Resolution Signal "B" Too Few Pulses
P0378 Timing Reference High Resolution Signal "B" Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal "B" No Pulses
P0380 Glow Plug /Heater Circuit "A"
P0381 Glow Plug /Heater Indicator Circuit
P0382 Glow Plug /Heater Circuit "B"
P0385 Crankshaft Position Sensor "B" Circuit
P0386 Crankshaft Position Sensor "B" Circuit Range/Performance
P0387 Crankshaft Position Sensor "B" Circuit Low Input
P0388 Crankshaft Position Sensor "B" Circuit High Input
P0389 Crankshaft Position Sensor "B" Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit
P0404 EGR Open Valve Pintle Error
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 EGR Sensor Signal Low
P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low
P0406 Exhaust Gas Recirculation Sensor "A" Circuit High
P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low
P0408 Exhaust Gas Recirculation Sensor "B" Circuit High
P0410 Secondary Air Injection System
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve "A" Circuit
P0413 Secondary Air Injection System Switching Valve "A" Circuit Open
P0414 Secondary Air Injection System Switching Valve "A" Circuit Shorted
P0415 Secondary Air Injection System Switching Valve "B" Circuit
P0416 Secondary Air Injection System Switching Valve "B" Circuit Open
P0417 Secondary Air Injection System Switching Valve "B" Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit
P0419 Secondary Air Injection System Relay "B" Circuit
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0425 Catalyst Temperature Sensor (Bank 1)
P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)
P0427 Catalyst Temperature Sensor Low Input (Bank 1)
P0428 Catalyst Temperature Sensor High Input (Bank 1)
P0429 Catalyst Heater Control Circuit (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0435 Catalyst Temperature Sensor (Bank 2)
P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)
P0437 Catalyst Temperature Sensor Low Input (Bank 2)
P0438 Catalyst Temperature Sensor High Input (Bank 2)
P0439 Catalyst Heater Control Circuit (Bank 2)
P0440 Evaporative Emission Control System
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit
P0450 Evaporative Emission Control System Pressure Sensor
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0456 Evaporative Emission Control System Leak Detected (very small leak)
P0460 Fuel Level Sensor Circuit
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit
P0481 Cooling Fan 2 Control Circuit
P0482 Cooling Fan 3 Control Circuit
P0483 Cooling Fan Rationality Check
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit
P0491 Secondary Air Injection System (bank 1)
P0492 Secondary Air Injection System (bank 2)
P0500 Vehicle Speed Sensor
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Circuit Low Input
P0503 Vehicle Speed Sensor Intermittent / Erratic / High
P0505 Idle Control System
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch
P0512 Starter Request Circuit
P0520 Engine Oil Pressure Sensor/Switch Circuit
P0521 Engine Oil Pressure Sensor/Switch Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Low Voltage
P0523 Engine Oil Pressure Sensor/Switch High Voltage
P0524 Engine Oil Pressure Too Low
P0530 A/C Refrigerant Pressure Sensor Circuit
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 A/C Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control On Signal
P0566 Cruise Control Off Signal
P0567 Cruise Control Resume Signal
P0568 Cruise Control Set Signal
P0569 Cruise Control Coast Signal
P0570 Cruise Control Accel Signal
P0571 Cruise Control / Brake Switch "A" Circuit
P0572 Cruise Control / Brake Switch "A" Circuit Low
P0573 Cruise Control / Brake Switch "A" Circuit High
P0574 Cruise Control System - Vehicle Speed Too High
P0575 Reserved for Cruise Codes
P0576 Reserved for Cruise Codes
P0577 Reserved for Cruise Codes
P0578 Reserved for Cruise Codes
P0579 Reserved for Cruise Codes
P0580 Reserved for Cruise Codes
P0600 Serial Communication Link
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 ECM/PCM Processor
P0608 Control Module VSS Output "A"
P0609 Control Module VSS Output "B"
P0615 Starter Relay Circuit
P0616 Starter Relay Circuit Low
P0617 Starter Relay Circuit High
P0620 Generator Control Circuit
P0621 Generator "L" Terminal Control Circuit
P0622 Generator "F" Terminal Control Circuit
P0630 VIN Not Programmed or Mismatch - ECM/PCM
P0631 VIN Not Programmed or Mismatch - TCM
P0645 A/C Clutch Relay Circuit
P0650 Malfunction Indicator Lamp (MIL) Control Circuit
P0654 Engine RPM Output Circuit
P0655 Engine Hot Lamp Output Control Circuit
P0656 Fuel Level Output Circuit
P0700 Transmission Control System (will show up as PCM code, but is all TCM Related)
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch "B" Circuit
P0704 Clutch Switch Input Circuit
P0705 Transmission Range Sensor Circuit (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch "B" Circuit Low
P0720 Output Speed Sensor Circuit
P0721 Output Speed Sensor Circuit Range/Performance
P0722 Output Speed Sensor Circuit No Signal
P0723 Output Speed Sensor Circuit Intermittent
P0724 Torque Converter/Brake Switch "B" Circuit High
P0725 Engine Speed Input Circuit
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0737 TCM Engine Speed Output Circuit
P0738 TCM Engine Speed Output Circuit Low
P0739 TCM Engine Speed Output Circuit High
P0740 Torque Converter Clutch Circuit
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid "A"
P0746 Pressure Control Solenoid "A" Performance or Stuck Off
P0747 Pressure Control Solenoid "A" Stuck On
P0748 Pressure Control Solenoid "A" Electrical
P0749 Pressure Control Solenoid "A" Intermittent
P0750 Shift Solenoid "A"
P0751 Shift Solenoid "A" Performance or Stuck Off
P0752 Shift Solenoid "A" Stuck On
P0753 Shift Solenoid "A" Electrical
P0754 Shift Solenoid "A" Intermittent
P0755 Shift Solenoid "B"
P0756 Shift Solenoid "B" Performance or Stuck Off
P0757 Shift Solenoid "B" Stuck On
P0758 Shift Solenoid "B" Electrical
P0759 Shift Solenoid "B" Intermittent
P0760 Shift Solenoid "C"
P0761 Shift Solenoid "C" Performance or Stuck Off
P0762 Shift Solenoid "C" Stuck On
P0763 Shift Solenoid "C" Electrical
P0764 Shift Solenoid "C" Intermittent
P0765 Shift Solenoid "D"
P0766 Shift Solenoid "D" Performance or Stuck Off
P0767 Shift Solenoid "D" Stuck On
P0768 Shift Solenoid "D" Electrical
P0769 Shift Solenoid "D" Intermittent
P0770 Shift Solenoid "E"
P0771 Shift Solenoid "E" Performance or Stuck Off
P0772 Shift Solenoid "E" Stuck On
P0773 Shift Solenoid "E" Electrical
P0774 Shift Solenoid "E" Intermittent
P0775 Pressure Control Solenoid "B"
P0776 Pressure Control Solenoid "B" Performance or Stuck Off
P0777 Pressure Control Solenoid "B" Stuck On
P0778 Pressure Control Solenoid "B" Electrical
P0779 Pressure Control Solenoid "B" Intermittent
P0780 Shift P0781 1-2 Shift P0782 2-3 Shift
P0783 3-4 Shift
P0784 4-5 Shift
P0785 Shift/Timing Solenoid
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit
P0791 Intermediate Shaft Speed Sensor Circuit
P0792 Intermediate Shaft Speed Sensor Circuit Range/Performance
P0793 Intermediate Shaft Speed Sensor Circuit No Signal
P0794 Intermediate Shaft Speed Sensor Circuit Intermittent
P0795 Pressure Control Solenoid "C"
P0796 Pressure Control Solenoid "C" Performance or Stuck Off
P0797 Pressure Control Solenoid "C" Stuck On
P0798 Pressure Control Solenoid "C" Electrical
P0799 Pressure Control Solenoid "C" Intermittent
P0801 Reverse Inhibit Control Circuit
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit
P0805 Clutch Position Sensor Circuit
P0806 Clutch Position Sensor Circuit Range/Performance
P0807 Clutch Position Sensor Circuit Low
P0808 Clutch Position Sensor Circuit High
P0809 Clutch Position Sensor Circuit Intermittent
P0810 Clutch Position Control Error
P0811 Excessive Clutch Slippage
P0812 Reverse Input Circuit
P0813 Reverse Output Circuit
P0814 Transmission Range Display Circuit
P0815 Upshift Switch Circuit
P0816 Downshift Switch Circuit
P0817 Starter Disable Circuit
P0820 Gear Lever X-Y Position Sensor Circuit
P0821 Gear Lever X Position Circuit
P0822 Gear Lever Y Position Circuit
P0823 Gear Lever X Position Circuit Intermittent
P0824 Gear Lever Y Position Circuit Intermittent
P0825 Gear Lever Push-Pull Switch (Shift Anticipate)
P0830 Clutch Pedal Switch "A" Circuit
P0831 Clutch Pedal Switch "A" Circuit Low
P0832 Clutch Pedal Switch "A" Circuit High
P0833 Clutch Pedal Switch "B" Circuit
P0834 Clutch Pedal Switch "B" Circuit Low
P0835 Clutch Pedal Switch "B" Circuit High
P0840 Trans Pressure Switch Solenoid C Circuit
P0841 Trans Pressure Switch Solenoid C Circuit Stuck Open
P0842 Trans Pressure Switch Solenoid C Circuit Stuck Closed
P0843 Trans Pressure Switch Solenoid C Circuit High
P0845 Trans Pressure Switch Solenoid D Circuit
P0846 Trans Pressure Switch Solenoid D Circuit Stuck Open
P0847 Trans Pressure Switch Solenoid D Circuit Stuck Closed
P0848 Trans Pressure Switch Solenoid D Circuit High
P1101 Induction Air Measurement - Cross-check Out of Range
P1105 Secondary Vacuum Sensor Circuit
P1106 MAP Sensor Signal Intermittent High
P1107 MAP Sensor Signal Intermittent Low
P1108 MAP to BARO Correlation
P1109 Secondary Port Throttle System
P1110 Engine High Intake Air Temperature Condition
P1111 Intake Air Temperature Circuit Intermittent High
P1112 Intake Air Temperature Circuit Intermittent Low
P1114 Engine Coolant Temperature - Circuit Low Input Intermittent
P1115 Engine Coolant Temperature - Circuit High Input intermittent
P1116 Engine Coolant Temperature Signal Unstable or Intermittent
P1117 Engine Coolant Temperature Signal Out-Of-Range Low
P1118 Engine Coolant Temperature Signal Out-Of-Range High
P1119 Engine Coolant Temperature Signal Out-Of-Range with Transmission Temperature
P1120 Throttle Position Sensor "A" Circuit
P1121 Throttle Position Circuit Signal Intermittent High
P1122 Throttle Position Circuit Signal Intermittent Low
P1125 Multiple Throttle/Pedal Position Sensor
P1127 Open Loop CO Adjust Circuit
P1130 Oxygen Sensor Low Signal Variance (Bank 1 - Sensor 1)
P1131 Oxygen Sensor Low Signal Variance (Bank 1 - Sensor 2)
P1132 Oxygen Sensor Low Signal Variance (Bank 2 - Sensor 1)
P1133 Oxygen Sensor System - Too Few O2S R/L and L/R Switches . (Bank 1 - Sensor 1)
P1134 Oxygen Sensor Circuit - Transition Switch Time Ratio (Bank 1 - Sensor 1)
P1135 Oxygen Sensor Circuit - Mean Voltage Level Lean (Bank 1 - Sensor 1)
P1136 Oxygen Sensor Circuit - Mean Voltage Level Rich (Bank 1 - Sensor 1)
P1137 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 1 - Sensor 2)
P1138 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 1 - Sensor 2)
P1139 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 1 - Sensor 2)
P1140 Oxygen Sensor Circuit - Transition Switch Time Ratio (Bank 1 - Sensor 2)
P1141 Oxygen Sensor Circuit - Mean Voltage Level Lean (Bank 1 - Sensor 2)
P1142 Oxygen Sensor Circuit - Mean Voltage Level Rich (Bank 1 - Sensor 2)
P1143 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 1 - Sensor 3)
P1144 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 1 - Sensor 3)
P1145 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 1 - Sensor 3)
P1153 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 2 - Sensor 1)
P1154 Oxygen Sensor Circuit - Transition Switch Time Ratio (Bank 2 - Sensor 1)
P1155 Oxygen Sensor Circuit - Mean Voltage Level Lean (Bank 2 - Sensor 1)
P1156 Oxygen Sensor Circuit - Mean Voltage Level Rich (Bank 2 - Sensor 1)
P1157 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 2 - Sensor 2)
P1158 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 2 - Sensor 2)
P1159 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 2 - Sensor 2)
P1163 Oxygen Sensor System Monitor - Lean System or Low Voltage. (Bank 2 - Sensor 3)
P1164 Oxygen Sensor System Monitor - Rich System or High Voltage. (Bank 2 - Sensor 3)
P1165 Oxygen Sensor System - Too Few O2S R/L and L/R Switches. (Bank 2 - Sensor 3)
P1166 Oxygen Sensor System - Low Voltage During Power Enrichment (Bank 1 - Sensor 1)
P1167 Oxygen Sensor System - High Voltage During Decel Fuel Cut Off (Bank 1 - Sensor 1)
P1168 Oxygen Sensor System - Low Voltage During Power Enrichment (Bank 2 - Sensor 1)
P1169 Oxygen Sensor System - High Voltage During Decel Fuel Cut Off (Bank 2 - Sensor 1)
P1170 Bank to Bank Fuel Trim Offset
P1171 Primary Fuel Pump Insufficient / No Fuel Flow
P1172 Secondary Fuel Pump Insufficient / No Fuel Flow
P1173 Limitation of Injection Quantity
P1180 Engine High Fuel Temperature Condition
P1190 Engine Vacuum Leak
P1191 Intake Air Duct Air Leak
P1195 Engine Low Oil Pressure Condition
P1200 Injector Circuit
P1201 Secondary Mass Air Flow Range/Performance
P1202 Secondary Mass or Volume Air Flow Circuit Low Input
P1203 Secondary Mass or Volume Air Flow Circuit High Input
P1211 Mass Air Flow Circuit Intermittent High
P1212 Mass Air Flow Circuit Intermittent Low
P1214 Injection Pump Timing Offset Error
P1215 GFD Indication
P1216 Fuel Solenoid Response Time Too Short
P1217 Fuel Solenoid Response Time Too Long
P1218 Injection Pump Calibration Resistor Error
P1219 Throttle Position Sensor Reference Voltage Error
P1220 Throttle Position Sensor "B" Circuit
P1221 Throttle Position Sensor "A/B" Range/Performance
P1222 Injector Circuit Intermittent - Cylinder 1
P1225 Injector Circuit Intermittent - Cylinder 2
P1228 Injector Circuit Intermittent - Cylinder 3
P1231 Injector Circuit Intermittent - Cylinder 4
P1234 Injector Circuit Intermittent - Cylinder 5
P1237 Injector Circuit Intermittent - Cylinder 6
P1240 Injector Circuit Intermittent - Cylinder 7
P1243 Injector Circuit Intermittent - Cylinder 8
P1245 Intake Plenum Switchover Valve Circuit
P1246 Intake Resonance Switchover Valve Circuit
P1257 Supercharger - Overboost
P1258 Engine Coolant Over - Temperature Protection
P1260 Fuel Pump Speed Control Circuit
P1270 Accelerator Pedal Position Sensor A/D Converter Error
P1271 Accelerator Pedal Position Sensors 1 & 2 Correlation Error
P1272 Accelerator Pedal Position Sensors 2 & 3 Correlation Error
P1273 Accelerator Pedal Position Sensors 1 & 3 Correlation Error
P1274 Injectors Wired Incorrectly
P1275 Accelerator Pedal Position Sensor 1 Circuit
P1276 Accelerator Pedal Position Sensor 1 Circuit Performance
P1277 Accelerator Pedal Position Sensor 1 Circuit Low Voltage
P1278 Accelerator Pedal Position Sensor 1 Circuit High Voltage
P1279 Accelerator Pedal Position Sensor 1 Circuit Intermittent
P1280 Accelerator Pedal Position Sensor 2 Circuit
P1281 Accelerator Pedal Position Sensor 2 Circuit Performance
P1282 Accelerator Pedal Position Sensor 2 Circuit Low Voltage
P1283 Accelerator Pedal Position Sensor 2 Circuit High Voltage
P1284 Accelerator Pedal Position Sensor 2 Circuit Intermittent
P1285 Accelerator Pedal Position Sensor 3 Circuit
P1286 Accelerator Pedal Position Sensor 3 Circuit Performance
P1287 Accelerator Pedal Position Sensor 3 Circuit Low Voltage
P1288 Accelerator Pedal Position Sensor 3 Circuit High Voltage
P1289 Accelerator Pedal Position Sensor 3 Circuit Intermittent
P1310 Ignition Coil Primary/Secondary Current Sense System
P1311 Ignition Coil "A" Primary/Secondary Circuit
P1312 Ignition Coil "B" Primary/Secondary Circuit
P1313 Ignition Coil "C" Primary/Secondary Circuit
P1314 Ignition Coil "D" Primary/Secondary Circuit
P1315 Ignition Coil "E" Primary/Secondary Circuit
P1316 Ignition Coil "F" Primary/Secondary Circuit
P1317 Ignition Coil "G" Primary/Secondary Circuit
P1318 Ignition Coil "H" Primary/Secondary Circuit
P1320 Distributor Signal Interrupt
P1321 DIS Fault Line
P1322 DIS EST (Extra or Missing)
P1323 Loss of High Resolution RPM Information
P1324 Crank RPM Too Low
P1326 Combustion Quality Circuit
P1336 Crankshaft Position System Variation Not Learned
P1340 Ignition System Cylinder Identifier
P1345 Crankshaft/Camshaft Correlation Error
P1350 Bypass Line Monitor
P1351 EST Output High or Pulses Detected when Grounded - Cylinder 1
P1352 EST Output High or Pulses Detected when Grounded - Cylinder 2
P1353 EST Output High or Pulses Detected when Grounded - Cylinder 3
P1354 EST Output High or Pulses Detected when Grounded - Cylinder 4
P1355 EST Output High or Pulses Detected when Grounded - Cylinder 5
P1356 EST Output High or Pulses Detected when Grounded - Cylinder 6
P1357 EST Output High or Pulses Detected when Grounded - Cylinder 7
P1358 EST Output High or Pulses Detected when Grounded - Cylinder 8
P1359 Ignition Control Circuit Group A (cylinders N, N, N, N )
P1360 Ignition Control Circuit Group B (cylinders N, N, N, N )
P1361 EST Not Toggling After Enabled - Cylinder 1
P1362 EST Not Toggling After Enabled - Cylinder 2
P1363 EST Not Toggling After Enabled - Cylinder 3
P1364 EST Not Toggling After Enabled - Cylinder 4
P1365 EST Not Toggling After Enabled - Cylinder 5
P1366 EST Not Toggling After Enabled - Cylinder 6
P1367 EST Not Toggling After Enabled - Cylinder 7
P1368 EST Not Toggling After Enabled - Cylinder 8
P1370 Too Many Low Resolution Pulses
P1371 Too Few Low Resolution Pulses
P1372 Crankshaft Position Sensor Circuits Performance
P1374 Crank to Low Resolution Correlation
P1375 No Crank Sensor A or B
P1376 Reference Low Voltage Out of Range
P1377 CAM To Reference Correlation
P1380 ABS Preventing Rough Road/Misfire Diagnostic
P1381 Serial Communication Preventing Rough Road/Misfire Diagnostic
P1382 ABS Control Module Performance (Used for 1997 Model Year only)
P1390 Wheel Speed Sensor "A" / G-Sensor Circuit
P1391 Wheel Speed Sensor "A" / G-Sensor Circuit Range/Performance
P1392 Wheel Speed Sensor "A" / G-Sensor Circuit Low Input
P1393 Wheel Speed Sensor "A" / G-Sensor Circuit High Input
P1394 Wheel Speed Sensor "A" / G-Sensor Circuit Intermittent
P1395 Wheel Speed Sensor "B" / G-Sensor Circuit
P1396 Wheel Speed Sensor "B" / G-Sensor Circuit Range/Performance
P1397 Wheel Speed Sensor "B" / G-Sensor Circuit Low Input
P1398 Wheel Speed Sensor "B" / G-Sensor Circuit High Input
P1399 Wheel Speed Sensor "B" / G-Sensor Circuit Intermittent
P1403 Exhaust Gas Recirculation Solenoid Low
P1404 EGR Closed Valve Pintle Error
P1404 Exhaust Gas Recirculation System - Closed Valve Pintle Error
P1405 Exhaust Gas Recirculation Solenoid High
P1406 EGR Pintle Position Error
P1406 Exhaust Gas Recirculation System Pintle Position Error
P1407 P1408 Exhaust Gas Recirculation Vacuum System
P1409 Exhaust Gas Recirculation Vacuum System Leak/Low Supply
P1410 Exhaust Gas Recirculation Vacuum System Restriction
P1415 Secondary Air Injection - Bank 1
P1416 Secondary Air Injection - Bank 2
P1420 Intake Air Low Pressure Switch Circuit Low Voltage
P1421 Intake Air Low Pressure Switch Circuit High Voltage
P1422 Intake Air High Pressure Switch Circuit Low Voltage
P1423 Intake Air High Pressure Switch Circuit High Voltage
P1431 Fuel Level Sensor Circuit Range/Performance (Secondary Tank)
P1432 Fuel Level Sensor Circuit Low Input (Secondary Tank)
P1433 Fuel Level Sensor Circuit High Input (Secondary Tank)
P1441 Evaporative Emission Control System Continuous Open Purge Flow
P1442 Purge Solenoid Diagnostic Vacuum Switch
P1443 Evaporative Emission Control System Purge Control Valve 2 Circuit
P1445 Fuel Heated Catalyst System Bank 1
P1450 Catalyst Heater Diagnostic
P1451 Catalyst Heater Diagnostic
P1452 Catalyst Heater Diagnostic
P1453 Catalyst Heater Diagnostic
P1454 Catalyst Heater Diagnostic
P1455 Catalyst Heater Diagnostic
P1456 Catalyst Heater Diagnostic
P1457 Catalyst Heater Diagnostic
P1458 Catalyst Heater Diagnostic
P1459 Catalyst Heater Diagnostic
P1483 Engine Cooling System Performance
P1501 Vehicle Speed Sensor Intermittent
P1504 Aux Vehicle Speed Output Circuit
P1505 Starter Relay Circuit
P1506 Starter Relay Circuit Low
P1507 Starter Relay Circuit High
P1508 Idle Control System Low/Closed
P1509 Idle Control System High/Open
P1510 Throttle Control System - In Limitation
P1511 Throttle Control System - Backup System Performance
P1512 Throttle Control System - Minimum Throttle Position
P1513 EBTCM to PCM Drag Reduction Request Input Circuit
P1514 Throttle Actuator Control (TAC) System MAF Correlation Error
P1515 Command vs. Actual Throttle Position Correlation (PCM) Error
P1516 Command vs. Actual Throttle Position Correlation (TAC Module) Error
P1517 Throttle Actuator Control (TAC) Module Processor
P1518 PCM to TAC Module Serial Data Circuit
P1519 Throttle Actuator Control (TAC) Module
P1520 Park/Neutral Discrete Error
P1521 P/N to D/R at High Throttle Angle
P1522 P/N to D/R at High RPM
P1523 Throttle Actuator Control Return Performance
P1524 Throttle Position Sensor Out of Adjustment
P1525 Throttle Body Service Required
P1526 TPS Learn Not Done After Reprogramming
P1527 Transaxle Range/Pressure Switch Comparison
P1528 Governor
P1529 Heated Windshield Request
P1530 Throttle Control System - Amplifier Adjustment
P1531 A/C Temperature Sensor Circuit
P1532 A/C Low Side Temperature Sensor Low Input
P1533 A/C Low Side Temperature Sensor High Input
P1534 A/C High Side Temperature Sensor Low Input
P1535 A/C High Side Temperature Sensor High Input
P1536 A/C Coolant Over Temperature
P1537 Very Low Refrigerant Pressure
P1538 A/C Request Shorted High
P1539 High Side Pressure Switch or A/C Relay Shorted
P1540 A/C High Pressure Condition
P1541 A/C High Side Over Temperature
P1542 A/C High Discharge Temperature/Pressure
P1543 Low Refrigerant Condition
P1544 Very Low Refrigerant Condition
P1545 A/C High Pressure Switch or A/C Clutch Relay Circuit
P1546 A/C Clutch Status Circuit Open
P1547 A/C System Performance Degraded
P1548 A/C "Mode" Circuit Low
P1549 A/C "Mode" Circuit High
P1554 Stepper Motor Cruise
P1555 Electronic Variable Orifice Output
P1558 Cruise Control - Servo Indicates Low
P1559 Cruise Control - Power Management Mode
P1560 Cruise Control - Transmission not in Drive
P1561 Cruise Control - Vent Solenoid Failure
P1562 Cruise Control - Vacuum Solenoid Failure
P1563 Cruise Control - Vehicle Speed and Set Speed Difference Too High
P1564 Cruise Control - Vehicle Acceleration Too High
P1565 Cruise Control - Servo Position Sensor Failure
P1566 Cruise Control - Engine RPM Too High
P1567 Cruise Control - Auto Brake Control Disengage
P1568 Cruise Control Servo Stroke Greater than Commanded in Cruise
P1569 Cruise Control Servo Stroke High While not in Cruise Control
P1570 Traction Control Active While in Cruise
P1571 Traction Control PWM Link
P1572 Traction Control Active Too Long
P1573 Loss of ABS Serial Data
P1574 Brake Pedal Position Switch
P1575 Additional Brake Input Diagnostic
P1576 Shorted Brake Booster Vacuum Sensor Circuit
P1577 Open Brake Booster Vacuum Sensor Circuit
P1578 Brake Booster Vacuum Too Low
P1579 High Throttle Angle on P/N to D/R Transition
P1580 Cruise Control Move Circuit – Low
P1581 Cruise Control Move Circuit - High
P1582 Cruise Control Direction Circuit - Low
P1583 Cruise Control Direction Circuit - High
P1584 Cruise Control Disabled
P1585 Cruise Inhibit Control Circuit
P1586 Brake Switch Circuit Number 3
P1599 Engine Stall Detected
P1601 Serial Communication with Device 1 (PCM, Powertrain Control Module)
P1602 Serial Communication with Device 2 (ABS, Antilock Brake System)
P1603 Serial Communication with Device 3 (SIR, Supplemental Inflatable Restraint)
P1604 Serial Communication with Device 4 (IPC, Instrument Panel Cluster)
P1605 Serial Communication with Device 5 (HVAC, Heating Ventilation and Air Conditioning)
P1606 Serial Communication with Device 6 (E&C BUSS, Entertainment and Comfort)
P1607 Serial Communication with Device 7 (MRD, Magnetic Rotation Device)
P1608 Serial Communication with Device 8 (CCM, Central Control Module)
P1609 Serial Communication with Device 9 (TCS, Traction Control System)
P1610 Serial Communication with Device 10 (PZM, Platform Zone Module)
P1611 Serial Communication with Device 11 (CVRTD, Continuously Variable Real Time Dampening)
P1612 Serial Communication with Device 12 (IPM, Instrument Panel Module)
P1613 Serial Communication with Device 13 (DIM, Driver Information Module)
P1614 Serial Communication with Device 14 (RIM, Radio Interface Module)
P1615 Serial Communication with Device 15 (VTD, Vehicle Theft Deterrent)
P1617 Engine Oil Level Switch Circuit
P1618 Serial Peripheral Interface (SPI) PCM Internal Communication Error
P1619 Oil Change - Input
P1620 Low Coolant Circuit
P1621 Total EEPROM Failure
P1622 Cylinder Select Error (OBD1 was code 41)
P1623 Transmission Temp Pull-up Resistor
P1624 Customer Snapshot Requested
P1625 PCM System Reset
P1626 Anti-Theft Failure
P1627 A/D Failure
P1628 Engine Coolant Temperature Pull-Up Resistor Failed
P1629 Anti-Theft Device - Cranking Signal
P1630 PCM in Theft Learn Mode
P1631 Anti-Theft Device - PCM/IPC Password Error
P1632 Anti-Theft Device - Fuel Disabled
P1633 PCM Ignition Input "A"
P1634 PCM Ignition Input "B"
P1635 5 Volt Reference "A" Low
P1636 PCM Stack Overrun
P1637 Generator "L" Terminal Control Circuit
P1638 Generator "F" Terminal Control Circuit
P1639 5 Volt Reference "B" Low
P1640 Add on heater, Circuit (Circuit 1)
P1641 Add on heater, Circuit (Circuit 2)
P1642 QDM / ODM "A" - Output 2
P1643 Wait to Start Lamp Control Circuit
P1644 QDM / ODM "A" - Output 4
P1645 QDM / ODM "A" - Output 5
P1646 5Volt Reference "C" Circuit
P1647 QDM / ODM "A" - Output 7
P1648 Anti-Theft Device - Wrong Security Code
P1649 Anti-Theft Device - No Key/Security Code Programmed
P1650 QDM / ODM "B"
P1651 QDM / ODM "B" - Output 1
P1652 Chassis Pitch Status Control Circuit
P1653 Engine Oil Level "Low" Lamp Control Circuit
P1654 Service Throttle Soon Lamp Control Circuit
P1656 Second Gear Start Lamp Control Circuit
P1657 QDM / ODM "B" - Output 7
P1659 Engine Over speed Lamp Control Circuit
P1660 High Idle Lamp Control Circuit
P1661 Check Gages Lamp Control Circuit
P1662 Cruise Control Lamp Control Circuit
P1663 Engine Oil Life/Change Lamp Control Circuit
P1664 Service Vehicle Soon Lamp Control Circuit
P1665 Engine Oil Pressure Gage Output Circuit
P1666 Engine Shutdown Alarm Control Circuit
P1667 QDM / ODM "C" - Output 7
P1670 QDM / ODM "D"
P1671 QDM / ODM "D" - Output 1
P1672 QDM / ODM "D" - Output 2
P1673 QDM / ODM "D" - Output 3
P1674 QDM / ODM "D" - Output 4
P1675 QDM / ODM "D" - Output 5
P1676 QDM / ODM "D" - Output 6
P1677 QDM / ODM "D" - Output 7
P1680 Control Module Performance - APP system
P1681 Control Module Performance - TP system
P1682 Control Module Performance - Ignition Circuit
P1689 Delivered Torque Output Circuit
P1690 ECM Loop Overrun
P1691 Coolant Gage Circuit - Low
P1692 Coolant Gage Circuit - High
P1693 Tachometer Circuit - Low
P1694 Tachometer Circuit - High
P1695 Remote Keyless Entry Circuit - Low
P1696 Remote Keyless Entry Circuit - High
P1697 PZM Disabled Fuel
P1698 Class II Down Disabled Fuel
P1699 In Fail Enable Mode
P1701 Pressure Switch "C" Circuit
P1702 Pressure Switch "C" Stuck Open / Performance
P1703 Pressure Switch "C" Circuit Low / Stuck Closed
P1704 Pressure Switch "C" Circuit High
P1705 Pressure Switch "D" Circuit
P1706 Pressure Switch "D" Stuck Open / Performance
P1707 Pressure Switch "D" Circuit Low / Stuck Closed
P1708 Pressure Switch "D" Circuit High
P1709 Pressure Switch "E" Circuit
P1710 Pressure Switch "E" Stuck Open / Performance
P1711 Pressure Switch "E" Circuit Low / Stuck Closed
P1712 Pressure Switch "E" Circuit High
P1713 Pressure Switch "Reverse" Circuit
P1714 Pressure Switch "Reverse" Stuck Open / Performance
P1715 Pressure Switch "Reverse" Circuit Low / Stuck Closed
P1716 Pressure Switch "Reverse" Circuit High
P1717 Incorrect 6th Gear Ratio
P1718 Incorrect Neutral Gear Ratio
P1720 Solenoid "A" Controlled Clutch Not Engaged
P1721 Solenoid "B" Controlled Clutch Not Engaged
P1722 Manual Selector Valve Controlled Clutch Not Engaged
P1723 Solenoid "A" Controlled Clutch Engaged
P1724 Solenoid "B" Controlled Clutch Engaged
P1725 Manual Selector Valve Controlled Clutch Not Engaged
P1730 Retarder Circuit P1731 Retarder Circuit Low
P1732 Retarder Circuit High
P1733 Retarder Temperature Sensor Low
P1734 Retarder Temperature Sensor High
P1735 Retarder Over Temperature
P1736 Service Brake Input "ON" With VSS Indicated
P1737 Kick Down Circuit
P1740 NSBU Mode "A" Circuit
P1741 NSBU Mode "A" Circuit Low
P1742 NSBU Mode "A" Circuit High
P1743 NSBU Mode "B" Circuit
P1744 NSBU Mode "B" Circuit Low
P1745 NSBU Mode "B" Circuit High
P1746 NSBU Mode "P" Circuit
P1747 NSBU Mode "P" Circuit Low
P1748 NSBU Mode "P" Circuit High
P1749 NSBU Park/Neutral Switch Compare
P1760 TCM Supply Voltage
P1780 MIL Requested By TCM
P1781 TCM MIL Request Control Circuit
P1782 MIL Requested By TCM - Data Invalid
P1785 Shift Lock Solenoid Circuit - Low Voltage
P1786 Shift Lock Solenoid Circuit - High Voltage
P1790 TCM Checksum Error
P1791 TCM Loop Error
P1792 TCM Reprogrammable Memory Error
P1793 TCM Stack Overrun
P1800 Transmission Power Relay Control Circuit
P1801 Performance Selector Switch (MLP) Failure
P1804 Ground Control Relay
P1810 Pressure Switch Manifold
P1811 Maximum Adapt and Long Shift
P1813 Torque Control
P1814 Torque Converter Overstressed
P1815 Transmission Range Switch Start in Wrong Range
P1816 Transmission Range Switch P/N W/Drive Ratio
P1817 Transmission Range Switch Rev W/Drive Ratio
P1818 Transmission Range Switch Drive W/Rev Ratio
P1820 Transmission Range Internal Mode Switch "A" Circuit Low
P1821 Internal Mode Switch Mode "B" Circuit Low
P1822 Internal Mode Switch Mode "A" Circuit High Voltage
P1823 Internal Mode Switch Mode "P" Circuit Low Voltage
P1824 Internal Mode Switch Mode "P" Circuit High Voltage
P1825 Internal Mode Switch Illegal Range
P1826 Serial Communication - DKI Failure
P1827 Serial Communication - DKP Short to Ground
P1828 Serial Communication - DKP Shorted High
P1829 Serial Communication - TI Signal Line Open
P1831 Pressure Control/Shift Lock Solenoids Power Control Circuit - Low Voltage
P1832 Pressure Control/Shift Lock Solenoids Power Control Circuit - High Voltage
P1833 TCC/Shift Solenoid Power Control Circuit - Low Voltage
P1834 TCC/Shift Solenoid Power Control Circuit - High Voltage
P1835 Kick-Down Switch
P1836 Kick-Down Switch - Failed Open
P1837 Kick-Down Switch - Failed Short
P1842 1-2 Shift Solenoid Circuit - Low Voltage
P1843 1-2 Shift Solenoid Circuit - High Voltage
P1844 TCS Torque Reduction Request Circuit
P1845 Torque Limiter
P1846 2-3 Shift Solenoid Circuit - Low Voltage
P1847 2-3 Shift Solenoid Circuit - High Voltage
P1850 Brake Band Apply Solenoid
P1851 Brake Band Apply Solenoid Range/Performance
P1852 Brake Band Apply Solenoid Low
P1853 Brake Band Apply Solenoid High
P1857 3-2 Solenoid Circuit Low Voltage
P1858 3-2 Solenoid Circuit High Voltage
P1860 Torque Converter Clutch PWM Solenoid Circuit
P1862 TCC Enable Solenoid Circuit Low Voltage
P1863 TCC Enable Solenoid Circuit High Voltage
P1864 Shift Solenoid 4-5 Circuit Low Voltage
P1865 Shift Solenoid 4-5 Circuit High Voltage
P1868 Transmission Fluid Life
P1870 Transmission Component Slipping
P1873 Torque Converter Stator Temperature Switch Circuit Low
P1874 Torque Converter Stator Temperature Switch Circuit High
P1875 4 Wheel Drive Lo Switch Circuit
P1887 Torque Clutch Converter Release Switch Circuit
P1890 P1891 Throttle Position Sensor PWM Signal Low Input
P1892 Throttle Position Sensor PWM Signal High Input
P1893 Engine Torque Signal Low Input
P1894 Engine Torque Signal High Input
P1895 TCM to ECM Torque Reduction Circuit
P1896 Transmission Downshift Switch Circuit
P1897 Transmission Upshift Switch Circuit
P1898 Manual Shift Mode Switch Circuit
steeleshark2 is offline   Reply With Quote
Old 09-26-2011, 09:40 PM   #2
steeleshark2
MODS,please make this a sticky!!
Old 09-26-2011, 10:46 PM   #3
Parag
Drives: 2010 camaro 2SS LS3
Parag is offline   Reply With Quote
Old 09-26-2011, 10:49 PM   #4
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Awesome!
Where did you pull that information from?
Old 09-26-2011, 11:03 PM   #5
steeleshark2
Originally Posted by Dragoneye View Post
Awesome!
Tried to find something since I had seen a few requests. It took some time but I found this one site with it in PDF. Had to reformat it to show correctly on here.
westersgarage.eidnet.org/OBD2%20Trouble%20Codes.pdf
It contains PCM - TCM - BCM - DDM - IPC - EBCM (ABS) - CANBUS Messaging. I still have to reformat the rest but all the pcodes are done and posted.
Old 09-27-2011, 08:18 AM   #6
wirebender
wirebender's Avatar
Drives: 2017 ZL1, A10, White, sunroof, nav
WOW! Thanx for your work! I'm sure alot of members will appreciate this and benefit from it.
wirebender is offline   Reply With Quote
Old 01-06-2012, 05:49 PM   #7
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
how do you know what dtc is. I have a livernois calibrator and on dtc it just say DTC RAW ,1,0,19,0 what are these
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 03-15-2013, 09:03 PM   #8
Pecospete
Drives: 2013 Inferno Orange
Thank you!
Thanks for the codes!
Pecospete is offline   Reply With Quote
Old 01-09-2015, 04:11 PM   #9
gomezcorp
CWOARMY
gomezcorp's Avatar
Drives: 2022 ZL1 1LE
P0121 TB Sensor
So I swapped out the stock 95mm TB and bolted on a BBK 102mmTB, now I can't get rid of the Error Code P0121 ! Anyone experience this? I can clear it with my DiabloSport "inTune" tuner, but the error code comes back. I do not feel any performance change with the engine light on, but it is still on! any thoughts/ideas? Thanks
(2011 Camaro 2SS L99, CAI, Borla ATAK CatBack)
gomezcorp is offline   Reply With Quote
Old 01-08-2020, 01:35 PM   #10
xXSharkfhinXx
xXSharkfhinXx's Avatar
Drives: 2015 2SS RS
could a P0171 and P0174 be from not properly covering the filter on the factory CAI allowing excess air in ? or is the MAF bad ?
Darkness
xXSharkfhinXx is offline   Reply With Quote
Old 04-08-2020, 10:45 PM   #11
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
Please note that all these codes are not valid for these cars
Mouse330 is offline   Reply With Quote
Old 04-08-2020, 10:49 PM   #12
Mouse330
Mouse330's Avatar
No it would not
Bank 1 and 2 lean
It could be a MAF or a vacuum leak that’s affecting both banks....etc after the MAF
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 03:42 PM
Diablosport Predator *In Stock* $369 Shipped BMC Performance V8 Bolt-Ons & Tunes 36 11-16-2009 12:53 PM
GM January Sales Down 48.8%... FenwickHockey65 General Automotive + Other Cars Discussion 13 02-05-2009 10:26 PM
GM DECEMBER SALES DOWN 31%, BETTER THAN LAST MONTH FenwickHockey65 General Automotive + Other Cars Discussion 18 01-07-2009 01:09 AM
Twinned Vehicles: Same Cars, Different Brands TRIXXTERR General Automotive + Other Cars Discussion 31 10-02-2008 06:33 PM
