dave@hennessey
Old 03-25-2009, 09:26 PM   #1
The Boat
His seafaringness
The Boat's Avatar
Drives: yugo
LSA crate engine?
can the LSA be ordered as a crate engine? It would be nice to swap out for that then sell my LS3 bc it would be able to handle higher boost probably!
The Boat is offline   Reply With Quote
Old 03-25-2009, 09:35 PM   #2
THE EVIL TW1N
Drives: 2003 Cobra Convertible
it does not have forged pistons. I'd be worried about turning up the boost at all in that thing.
THE EVIL TW1N is offline   Reply With Quote
Old 03-25-2009, 09:51 PM   #3
NewCar
NewCar's Avatar
Drives: hand me down pickup
Dealership Markup?
Hey, If you just ordered from a dealer... did you pay a premium for early ordering. I went to a dealer two days ago and he said he wasn't selling anything for less than 10 thousand dollars over sticker. He says I won't be able to get one for sticker price for a year maybe, "Until the 'New' wears off." Did you have to put up with this crap too?
This GMPP catalog says the LSA is the engine for the Z-28, not the LS9, but both use the 6.2L engine block same as the LS3, except I think the LS9 is cast differently by process. So if you want, instead of selling your whole LS3 you could modify it with new forged internals, cam (which your swapping anyway you say) and maybe check to see if you will need new heads, then add the supercharger. If your not going to boost it up to 600HP like the LS9, then you may get away with using the same block and see if its cheaper than the whole new engine. but if your going to get a whole new engine anyway, the LS9 is more powerful, very similar, and the LSA has a wimpy camshaft with low lift, to provide "Cadillac's signature quietness and refinement." It's all up to you if you have the money, but you may not have to swap the entire engine. Make sure you have a buyer for the old engine first. Don't get the LS7 if your going to Boost it, though, Chevy tried and the walls were too thin to hold the pressure, due to the larger bore, so that's why they went with the 6.2L instead of 7.0L. There's a ton of GMPP engines available, and some may not be street legal.
NewCar is offline   Reply With Quote
Old 03-25-2009, 09:55 PM   #4
NewCar
NewCar's Avatar
LSA Hypereutectic aluminum vs. LS9 forgesd aluminum.
LS9 made with specially cast Block will hold up to more boost.
Old 03-25-2009, 11:15 PM   #5
THE EVIL TW1N
those dynographs on the pics are retarded.
Old 03-25-2009, 11:43 PM   #6
HeavyRightFooT
Drives: Z51 C6 LS3 Vette
Nice ... any price on these engines ?
08 C6 z51 headers/vararam/tune/420-410/ccw sp550 19+20/Pzerro Nero 275-30-19F 305-30-20R --- to be traded for a Z28 ?
HeavyRightFooT is offline   Reply With Quote
Old 03-26-2009, 06:46 AM   #7
ADM PERFORMANCE
Drives: Anything I want
List price on the lsa is 20k
ADM PERFORMANCE is offline   Reply With Quote
Old 03-26-2009, 10:25 AM   #8
JJ#48Racing
Drives: 1998 Camaro SS
The torque line is way off. It's almost like it's backwards.
JJ#48Racing is offline   Reply With Quote
Old 03-26-2009, 11:53 AM   #9
THE EVIL TW1N
I think whoever made those graphs had no idea what they were really supposed to look like. It was probably some graphic designer who only had a dynograph with only the hp graphed out and completely guessed what the tq would look like. I would be PISSED if I bought an LS9 and found out it only made 200 odd tq at 4000 rpm LOL with that tq at 6600 rpm, the car would be at about 755 hp!
Old 03-26-2009, 12:51 PM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Aren't the LSA and LS9 blocks the same save for larger bolt holes in the LS9? I could've swore that was the biggest change. I know they both have the piston squirters, but I thought all newer 6.2L blocks from '08 and up are cast the same with the same heat treatment, with the one exception being that one element from the LS9...
I think I'd like to see if one could get a couple more pounds of safe boost out of that LSA. I'm sure those hyper' pistons are better suited to boost than the stock LS3s, but I'm sure one couldn't go to radical.
'20 ZL1 Black "Fury"
Old 03-26-2009, 12:55 PM   #11
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
I would build a heads/cam car before I wasted my money on the LSA. You can easily meet that 550hp range with heads/cam...Now add exhaust and intake, and you will have more flywheel HP than the LSA.
ZZcamaro is offline   Reply With Quote
Old 03-26-2009, 02:30 PM   #12
THE EVIL TW1N
I'm sure it can take a couple more #'s, but I would be disappointed if I bought an LSA and was limited to only 550 rwhp.
Old 03-26-2009, 02:43 PM   #13
Mythic
Mythic's Avatar
Drives: '03 Monte Carlo SS
I think the torque curves are probably accurate.
1) Im fairly certain GM reviewed the listing prior to publication, especially for 2 high profile engines.
2) they closely match each other at the low end
3) its basically an LS3 block + goodies, however the LS3 is 10.7:1 compression, the LS9 and LSA are both 9.1:1 compression
at low revs the S/C isn't pushing that much air in
LS9-SAE it looks steeper because the torque side values are half the HP values
Mythic is offline   Reply With Quote
Old 03-26-2009, 03:07 PM   #14
THE EVIL TW1N
You shouldn't post about things you don't know.
Do you know how a roots/screw-type blower works??? Boost is made basically off idle. MY CAR makes WAY more tq than that at the same RPM and it does not have anywhere near 638 hp, let alone 550+ like the LSA.
Not only that, do you know how hp is even calculated??? (TQ / 5250) X RPM = HP.
600 tq @ 6600 (as they have in the pic) equates to over 750 hp! Do you see 750 hp on that graph??
Those graphs are OBVIOUSLY errors.
Get your LS9 Crate Engine for only $21K Caliman93230 Forced Induction - V8 7 02-21-2009 10:46 AM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 04:35 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 06:16 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 04:00 PM
