Old 05-24-2011, 03:56 PM   #1
Gigachip
Runs on Starbucks
Gigachip's Avatar
Drives: 2012 SVT Raptor
Send a message via AIM to Gigachip
water cooling units
what would everyone recommend? I've found some online in previous searches but I'm curious what everyone uses.
Gigachip is offline   Reply With Quote
Old 05-29-2011, 04:56 AM   #2
Tom0662
Drives: 1998 Camaro SS
I built my current system about 1 1/2 years ago and decided I wanted to try water cooling. Gave the Corsair H50 a try, very impressed with it so far. Easy install. House is currently about 75 F inside and cpu running approx. 95 F/ 34 C. Winter time can knock of about 10-15 degrees.
http://www.corsair.com/cooling/hydro...pu-cooler.html
Tom0662 is offline   Reply With Quote
Old 05-29-2011, 09:26 AM   #3
Hemlawk
AwesomeBillDawesonville
Hemlawk's Avatar
Drives: CGM 2SS/RS =)
Im scared of watercool and my PC stays cool with my Coolermaster HAF case.
Besides I dont overclock, so I really dont need it...
Order placed on 1/13/11 - Purchased 2/22/11 2SS/RS CGM
Hemlawk is offline   Reply With Quote
Old 05-29-2011, 12:23 PM   #4
Ruin
...soon
Ruin's Avatar
Drives: 1969 Corvette & 2010 Mazda 3
Something I wrote a few years ago. I had to do a lot of reading and research before I started WCing. It's kinda lengthy, but there are some additional links and info at the end.
Hope it helps!
Ruin is offline   Reply With Quote
Old 05-29-2011, 01:28 PM   #5
Tom0662
Same here, no overclocking. I used the HAF 932 case. I used to be afraid of watercooling too. The thing I liked about the Corsair H50 was that t is all self contained. Not saying that it couldnt leak eventually, but a good majority of reviews etc, no one has had a problem.
I forgot to mention above that those temps are idle temps. I used an app called prime95 to test the system after I built it and never got temps over 140F/58C, so I would say it cools well. In
Old 05-29-2011, 01:32 PM   #6
Tom0662
Hope it helps!
Ah, Ghost Recon fan, love Tom Clancy games. Still play the Vegas and Vegas 2, (the dang machine gun loop will drive me insane unless I am hostingthen toture the other guy). and Ghost Recon Advanced Warfighter 2.
Excellant writeup also.
Old 05-29-2011, 11:52 PM   #7
Ruin
...soon
Ruin's Avatar
Thank you. I've been a staffer over at GR.net for close to a decade now (8 years I think). Have done lots of write-ups over there. The original Ghost Recon and Rainbow Six games were, bar none, the greatest shooters ever made.
Old 05-30-2011, 12:41 AM   #8
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
Problem is a cooler CPU is just 1 small part of the puzzle, best to control the temp of the air going into the case. As its real hard to get below air temp, so control it in stead.
2ndgenz28 is offline   Reply With Quote
Old 05-30-2011, 12:56 AM   #9
GbrilliantQ
¡ʇuɐıןןıɹq
GbrilliantQ's Avatar
Drives: 2011 Camaro IOM 2SS/RS
My first water cooled rig used a Koolance Exo kit. That was 2004. I have moved on to custom loops now.
What case are you using, cpu. Do you want to watercool your cpu, gpu southbridge...northbridge? Memory hdds?
The Corsair H50 is nice a kit for first timers. Or do you want to go custom. The first two pix are my first rig QX9650 @ 4.2ghz, 4gb ddr2 and an Asus Rampage Formula motherboard. I have upgraded to a i7 920 @ 4.8ghz, 6gb ddr3, Foxconn Bloodrage and 2 4870x2's
I'm selling it though. =/ I spend more time in my Camaro since I've gotten it.
GbrilliantQ is offline   Reply With Quote
Old 05-30-2011, 11:44 AM   #10
Ruin
...soon
Ruin's Avatar
I'd say it has more to do with heat displacement. Water can absolutely cool your CPU lower than air temp because it moves so much more heat off of it. A good loop though will solve heating problems for core parts (CPU, GPU, NB, SB, and RAM). But you also need to couple it with good fans too. Get the air moving in from the front and ejecting from the back. Keep the side on the case! Also try to keep the rad outside the case too. That was the one thing I never got to do with mine. Also cable management helps promote better airflow and heat distribution.
Old 05-30-2011, 02:20 PM   #11
Gigachip
Runs on Starbucks
Gigachip's Avatar
well, I'm looking into doing the whole pc, or at least majority like HDD, RAM, Cards, and cant think of other stuff possibilites. I did buy the H50 yesterday though, would I be able to run that with another cooling unit?.
Old 05-30-2011, 02:39 PM   #12
Ruin
...soon
Ruin's Avatar
You mean the Corsair H50?
If you want to WC most of your components, go custom. Build your own setup. You can pick the right cooling block for your individual components, read reviews, and get quality stuff. Building the system is pretty easy... and rewarding.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 06:53 PM
2010 Camaro color and model popularity as of Mar 06, 2010 (from spasticsquirrel) TAP101 5th Gen Camaro SS LS LT General Discussions 47 08-01-2011 05:17 PM
Neighbor's Water Running TOMS1SS Off-topic Discussions 20 03-21-2011 04:06 PM
Car Washing.................... Angelo@Autopia Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 03-08-2010 06:48 PM
How to dry your Black Camaro without water spots gzartman Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 55 10-27-2009 03:46 AM
