Old 02-13-2009, 03:34 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
DSL sucks. Anyone know why?
I have DSL at my business and at home. I don't have a choice at the office, our building doesn't have cable run to it. But at home, I had DSL years ago and it would always go out when it rained. Switched to cable and for 3 years and other than a couple weeks after hurricane Ivan and Katrina I have never had a problem.
I went back to DSL at home to 'Bundle' my services and back to the same problem.
At home AND at the office, any time it rains the service goes out. Anyone know why this could be?
I use Yahoo Music to pipe through the office for clients to enjoy and when it goes out it really pisses me off.
Old 02-13-2009, 04:32 PM   #2
69 Hugger
69 Hugger's Avatar
Drives: 69 Convertible Camaro
I had the same problem with the rain thing but cable dude came out and switched out the three way I had installed in the shop and it's fine now, the signal was low too.
69 Hugger is offline   Reply With Quote
Old 02-13-2009, 06:10 PM   #3
lordfriday2
Proud Owner!
Drives: 2010 Camaro SS RS
Send a message via AIM to lordfriday2
bad phone lines... water gets on line and itll mess the signal up... or you have an alarm system that isnt filtered...or you have a bad filter on the dslam outside your house...thats the box that brings the phone lines into your house...it could also be interfearence from the modem being near power cables for the computer... theres a few reasons
lordfriday2 is offline   Reply With Quote
Old 02-13-2009, 06:51 PM   #4
ddennis
#3736
Drives: 1978 Z28, 2003 & 2007 Z71,
Yep all those will do it. Cable rules and is faster too. Can you get phone from your cable provider.
ddennis is offline   Reply With Quote
Old 02-13-2009, 07:01 PM   #5
LS3SSRS
LS3SSRS's Avatar
Drives: 2010 IBM SS/RS
yea i work for a phone company and install phones/dsl/tv all day everyday. The main problem i come across is usually something in the house(alarm is a big one) Call your service provider and tell them you want a 'POTS splitter' installed at the main panel at your house. What this does is takes the phone line/dsl signal coming into your house and splits the data from the voice. So with this splitter it will bypass your inside wiring and dedicate 1 jack in your place for internet/modem only. So really the modem will have a straight path outside and will increase the signal to noise ratio(SNR) Also yes, it does depend on the type of wiring into your place. Is it buried or aerial? Buried cables have waaayy less problems then aerial cables. It also depends on the speed of service you requested, how far you are from the office, noise on the line(in db's ideally less than 26), what type of internet port it is....ex: alcatel, stinger, 2+, nokia, dslam(the box that brings the lines into your house is called a NIB~network interface box~). I personally will never go with cable internet, the speeds vary depending on how many users in your area are using the internet as well. Cable is shared, DSL is dedicated.
**sold** 2010 2SS/RS, 6spd manual, imperial blue metallic w/black leather
Blacked out tail/signal lights, 5% rear tint, 20% sides, Dynomax Bullet mufflers, Barton short throw shifter, Clear Image offroad downpipes
LS3SSRS is offline   Reply With Quote
Old 02-13-2009, 07:10 PM   #6
r0cketdr
r0cketdr's Avatar
Drives: RJT 2SS/RS
The splitter was the solution for me. We had the same problem, except the DSL would go out any time, not just when it rained. We got one dedicated jack and haven't had a single signal dropout since.
edit: this also removes any requirement for filters on the other phones, alarm, etc. If you've got more than one computer, you can set up a wireless network .. that, however, is a whole 'nother issue with DSL.
r0cketdr is offline   Reply With Quote
Old 02-13-2009, 10:18 PM   #7
manimsoblack
manimsoblack's Avatar
Drives: 04 Pontiac Grand Am, 08 Ninja 650r
fios or bust people
Originally Posted by Kyle2k View Post
You take a shit on everything fun and good on this forum.
manimsoblack is offline   Reply With Quote
Old 02-14-2009, 12:07 AM   #8
PQ
Booooosted.
PQ's Avatar
ok the best I can explain is the house is arial. It actiualy does go out sometimes even if it isn't raining. At the office it is on a different line as the alarm system and at the house the alarm system isn't monitored. I appreciate the info and I will try some of the things you guys mentioned. I didn't know that cable shared bandwidth from other users. So DSL is actually better if it's working properly?
Old 02-14-2009, 12:12 AM   #9
ArcAngel
ArcAngel's Avatar
Drives: 07 Black Cobalt SS/SC
Send a message via AIM to ArcAngel
Without a doubt FIOS slays cable and dsl etc etc its retarded fast!
Through HIM you believe in GOD, who raised HIM from the dead and Glorified him..
ArcAngel is offline   Reply With Quote
Old 02-14-2009, 12:17 AM   #10
PQ
Booooosted.
PQ's Avatar
I don't beleive fios is available here in lower Alabama. I'm geudsing fios is fiber optic?
Old 02-14-2009, 04:02 AM   #11
manimsoblack
Originally Posted by irpq11 View Post
I don't believe fios is available here in lower Alabama. I'm guessing fios is fiber optic?
You guessed right.
http://www22.verizon.com/FiOSForHome...ess_entry.aspx Check Availability
At my old place i had a 20/5 connection for $60/mnth No amount of downloading/streaming/gaming on our 3 comps that used the connection could slow it down, and i tried. I actually sustained a 5.7MB/s download from the Apple site.
Old 02-14-2009, 04:53 AM   #12
2KZ28_For_Now
SS Shotgun Ride?!??! :-)
2KZ28_For_Now's Avatar
Drives: 2000 Z28
FIOS or bust pretty much sums it up.
Cant get it. Living with 6 mbit cable. it's way better than DSL.
The current order of digital supremecy:
1 Private Super Line (custom routes and devoted fiber, straight from the NOC)
2 FIOS
3 Cable
4 DSL
5 AirCards
6 SmartPhones
7 Dial-Up
8 Hotel "Internet" L O F'in L
LT LS RS SS LS3 **LSA-Z28 (Skip the body kit)**
2KZ28_For_Now is offline   Reply With Quote
Old 02-14-2009, 06:56 AM   #13
manimsoblack
I have a "dumbphone" that's rated at the same speed at my parents cable...
Old 02-14-2009, 09:22 AM   #14
PQ
Booooosted.
PQ's Avatar
Nope, no FiOS in my area. I think I'm gonna go back to cable at home. No choice at the office.
Another question. As I stated allready I stream music from the internet through the office and private salon rooms so there are no commercials and I can change the genre depending on who may be coming in.
I'm using Yahoo and paying for it. Is there a better place to stream music from?
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 11:00 AM
THIS REALLY SUCKS!!!! bigralph 5th Gen Camaro SS LS LT General Discussions 62 10-10-2008 06:53 PM
That sucks... Silverado General Automotive + Other Cars Discussion 7 11-01-2007 07:24 PM
