03-02-2011, 06:39 PM | #1 |
Drives: 2010 AquaBlue 2SS/RS Join Date: Sep 2009
Can ZR1 OS be used in FI Camaro
It seems to me that the ZR1 OS uses the MAF signal in conjuction with the 2+ bar MAP senser. This would seem to be the best way to tune with the MAF reading air flow and the MAP using boost readings.The Camaro sees boost with a 2+bar Map but seems to me not to do any more than log that number. This must be a better OS than SD for a street car.
03-02-2011, 07:16 PM | #2 |
Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
i bet they use the ctsv ecm
415ci stroker, TVS 2300 Magnacharger, cnc heads, cam, yank ss3200 converter, Kooks long tubes, Bwoody true cold air kit, ZL1 Pump, magnaflow 3" cat-back, lowering springs,BMR control arms and tie rod bars, 3.73 gears, diff mounts, RX can, ADM fuel controller
03-02-2011, 09:15 PM | #3 |
Drives: 2006 Z06 Join Date: Oct 2010
The ZR1 uses an E67... The Camaro uses an E38. You can easily do a 2.5bar setup using both the MAF and the GMVE coefficients. You just have to relabel your zone boundaries and spend some time dialing in the GMVE with a third party program. If you want to change commanded fueling based on boost up to 180kPa MAP... Then just use the IVT fueling table. Once you trip PE, it'll go to open loop and use the richer of the two... PE, or the final EQ ratio from the open loop tables.
All you have to do is put a ZR1 MAP sensor in... Part number is 12592525. Last edited by DSX; 03-03-2011 at 07:49 AM. |
03-02-2011, 09:55 PM | #4 |
Right now I'am using a Ford map senser that came with E-Force but does read boost on the E-38. Thanks for the imput DSX ,I will look at that.
03-02-2011, 10:03 PM | #5 |
Drives: 2010 Camaro Join Date: Feb 2010
Jannetty just installed the ZR1 Map sensor in my car this week.
03-02-2011, 10:10 PM | #6 |
I'm going to Ted as soon as the weather breaks. Maybe he can hook me up.
03-02-2011, 10:16 PM | #7 |
03-03-2011, 08:23 PM | #8 |
I was hoping that a tuning GURU would have written the OS from the ZR1 to the format of the E-38 to be used with HPT like the SD systems out there.
03-03-2011, 08:38 PM | #9 |
03-03-2011, 08:39 PM | #10 |
hpt does have a 2.5bar o/s(and you can keep your maf) for the camaro, i have it, lots of added functions and a real VE table, and full cooling fan control
03-03-2011, 08:57 PM | #11 |
03-03-2011, 09:10 PM | #12 |
do you use hptuners for tuning?,, if you do , its just a o/s upgrade$100 - 2.5 bar (255 kPa) max MAP sensor support (calibration capability for GM 0-5V linear MAP sensors) - Rescaled MAF High Freq table supports up to 15400 Hz with 300 Hz resolution, also supports airflow up to 1024 g/sec - New VE tables with 33 x 33 cell resolution each and configurable MAP and RPM axes (choose your own resolution) - Charge Temperature based VE multiplier table, configurable axis - TPS based VE multiplier table, 33 x 17 cells with configurable TPS and RPM axes - MAP referenced Boost Enrich table - Boost Enrich MAP threshold and hysteresis value - Both MAF and Speed Density mode supported - Boost based fuel cut, selectable MAP threshold cuts fuel to all cylinders when exceeded - Rescaled fan temperature axis 163-250F (73-121C), stock is 192-250F (89-121C) http://www.hptuners.com/forum/showth...ght=e38+2.5bar
03-04-2011, 04:50 AM | #13 |
I do use HPT. I have seen this , but thought it was not available for 5th gen. Thanks Camaro1
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
CAMARO WIKI | Tran | Wiki | 66 | 04-22-2024 11:41 AM |
Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 10:06 AM |
GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
Answeres to questions I have stumbled on | dieseldave24v | 5th Gen Camaro SS LS LT General Discussions | 13 | 02-23-2009 06:56 PM |
