Old 02-06-2009, 12:58 PM   #1
bigralph
bigralph's Avatar
Drives: 2001 v6 Camaro
Obama Climate Change Advisers Holdren and Lubchenco Are Told Global Warming Is Over
Obama Climate Change Advisers Holdren and Lubchenco Are Told Global Warming Is Over Time to Prepare the US for the New Cold Era
http://www.spaceandscience.net/id16.html
The Space and Science Research Center (SSRC), today releases a letter mailed on January 1, 2009 to President-elect Barrack Obama’s nominated science adviser Dr. John Holdren and nominated NOAA administrator Dr. Jane Lubchenco clearly stating that “…global warming is over; a new cold climate has arrived.”
In this letter, SSRC Director John Casey calls on Dr. Holdren to immediately reverse course on global warming programs and start preparing the country for the next climate change. Since the early 2007 discovery of the solar cycles that according to Casey drive our climate over a period of about 200 years, he and later the SSRC have been on a mission to get the word out to government leaders and media representatives in order to prepare the US for the coming bitter cold era.
In explaining the reason for this first press release of 2009, Mr. Casey says,” There can no longer be any doubt that the Sun has entered an historic period of dramatically reduced activity which will bring us many long years of deep cold weather. This was predicted by me and a few other scientists around the globe but of course we were not taken seriously because of the politics of global warming and the refusal of many media outlets to print or telecast alternatives to the now discredited man made global warming concept. According to national and international sources that monitor the Sun, what is happening on and in the Sun is nothing short of record setting, astounding, and at the same time worrisome. The solar wind is at its lowest level in fifty years. The surface movement on the Sun has slowed to record rates and according to NASA’s previous announcements is ‘off the bottom of the charts.’ Most telling is the current prolonged lack of sunspots between the normal 11 year solar cycles 23 and 24 which is about to set a one hundred year record for time without sunspots. NASA also has long since forecast that cycle 25 will be ‘one of the weakest in centuries.” All of these events in combination leave little doubt that a ‘solar hibernation’ lasting several decades delivering the coldest weather in over two centuries has in fact arrived.”
In its last press release of 2008, the SSRC had warned President-elect Obama in its sternest language to date, of the coming cold and genuine apprehension about climate change campaign promises and recent appointments. The release expressed that such actions in support of anthropogenic global warming would create a punitive and restrictive atmosphere for scientists who oppose the belief that greenhouse gas emissions were the primary agents of climate change and that the ill-effects of the new cold weather without government assistance and preparation, would lead to a ‘worst case scenario’ for the American people.
Director Casey repeated his long standing position on the next climate change with the comment, “The longer we delay the necessary nation-wide preparations for the coming cold era the more difficult it will be. If the extremist rhetoric of man made climate change advocacy takes hold in the Obama administration which at this point is at fever pitch, then the stage will be set for the new cold climate to catch us completely off guard and unprepared. This will cause many Americans to suffer needlessly.”
He added further, “The Earth has been in a long term cooling trend technically for eleven years. The significant drop in global temperatures that also occurred between January 2007 and much of 2008 should have been enough for most observers to finally accept that global warming is over, except that this information was intentionally not passed on to the American people. Also and unfortunately, the Presidential campaign where both major parties continued to beat the drum of global warming and man made climate change only helped to cement in the flawed concept that mankind was more powerful and had more influence on the Earth’s climate than the Sun itself. This unbelievable idea has been pushed heavily by the United Nations Intergovernmental Panel on Climate Change (IPCC). This and the previous press release are intended to be no nonsense, to the point pleadings for some sanity in our government and the main stream media that have failed to accept the new climate reality. Specifically, it was the Sun and not man that caused the past twenty years of peak heating and it is the same Sun that through a dramatic decline in its activity will now bring us decades of extreme cold climate.”
In a closing statement Casey reiterated, “The global warming of the past decades was caused by the Sun. It is now over. It will not return based upon the SSRC’s research, for at least thirty years. It will then return only because the Sun’s repeating cycles of activity are scheduled to pick up again at that time. We should not waste another minute, another penny in controlling something that simply does not exist, namely man made climate change and global warming. It is essential for the welfare of all Americans if not the world, that in light of these new and startling changes in the Earth’s temperature and the profound changes in the Sun, that the next administration initiate a top-down review and redirection of climate change policy as soon as President Obama takes office.” Letter to Dr. Holdren Press Release SSRC 1-2008 Press Release SSRC 2-2008 Press Release SSRC 3-2008 Press Release SSRC 4-2008 Press Release SSRC 5-2008
bigralph is offline
Old 02-06-2009, 01:00 PM   #2
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
the church of global warming will not accept this heresy and the people responsible for this letter will be burned at the stake.
headpunter is offline
Old 02-06-2009, 01:04 PM   #3
bigralph
bigralph's Avatar
NO!!!!!!! don't burned me at the stake
bigralph is offline
Old 02-06-2009, 01:04 PM   #4
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
No Political discussion allowed.
If this gets off topic, it goes away.
GTAHVIT is offline
Old 02-06-2009, 01:35 PM   #5
Keedy
Should have waited...
Keedy's Avatar
Drives: 2004 Mazda RX8
This seems like a reputable source:
http://www.spaceandscience.net/index.html
o.O
Wait. no its not. Who the %@!$ is John L. Casey? other than, from what i can tell, he holds an undergraduate degree in math and physics?... Thats it?
Scientist? All he's got is an official (or officious, depending on perspective) sounding name for a company, from which he launches his self-written press releases in the hopes that someone might actually fund his projects... aka "3rd grade science experiments".
I might as well open up a company called "The National Official Organization for the Betterment of Health and Humanity" and release monthly press statements to health organizations describing the natural benefits for females to go nude.
Keedy is offline
Old 02-06-2009, 01:42 PM   #6
Sizzox
Most Known Unknown
Sizzox's Avatar
Drives: 08 Vette
Send a message via AIM to Sizzox
Camro to the rescue. With the exhaust to create the green house effect to heat up this planet.
Originally Posted by camaro_corvette View Post
I would kill for a gale banks diesel powered camaro. I would have so much torque and power that whenever I go to parades I would be physically able to throw torque out the window like candy for the kids.
Sizzox is offline
Old 02-06-2009, 01:50 PM   #7
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
This just means we all need to do our part and burn as much fossil fuel as possible..
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline
Old 02-06-2009, 01:51 PM   #8
djinva
Bow Tie Fan
djinva's Avatar
Drives: 16 Camaro 2SS
We will have to try to reverse this cooling trend. Ride the hell out of them Camaros boys!
16 Camaro 2SS 6M
60 Impala LS power
22 2500 HD Duramax
14 Caprice PPV 6.0
Instagram: dj_sarv
djinva is offline
Old 02-06-2009, 01:58 PM   #9
Georgie
Georgie's Avatar
Drives: Camaro... soon
hahahahaa by decree of algore
Georgie is offline
Old 02-06-2009, 02:02 PM   #10
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
They did actually. They've renamed their church to - The Church of Climate Change. Then, after someone comes out and says we've had 3 years of the same average temperature, they'll change their name to The Church of Average Temperature. It's a never ending loop to acknowledge their existence....
"BBOMG - More than just a car show.... It's an experience!"
Hylton is offline
Old 02-06-2009, 03:43 PM   #11
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
You don't think they will let go of that cash cow do you?
PQ is offline
Old 02-06-2009, 04:27 PM   #12
Rodrunner
Senior Member
Rodrunner's Avatar
Drives: 2010 SS/RS, '06 350Z
Finally, more and more scientists are coming forward to expose the GW fraud. Climate Change, as it is now being called, is evidently **** attempt to stay "credible". Just hope no one thinks we can stop the cold anymore than we could the heat. Coincidently, the Stimulus Bill does include $6 billion to weatherize modest-income homes. Not a result of this letter I'm sure, just a "leveling of the playing field", to put it non-politically.
2SS/RS - Black/Black - CGM Rally Stripes - Auto - VIN 10171
Rodrunner is offline
Old 02-06-2009, 05:06 PM   #13
Hylton
Hylton's Avatar
Now here's someone who get's what this whole thing is really about. The far right screw us with Wall street, the far left screw us with this.
Hylton is offline
Old 02-06-2009, 05:22 PM   #14
69 Hugger
69 Hugger's Avatar
Drives: 69 Convertible Camaro
Has Al Gore got the memo,
69 Hugger is offline
