#1 | ||
Prince of Zamunda
Drives: XW30 Join Date: May 2010
FoMoCo:Correction customers, its a single piston not two.
Whoops:
http://blogs.insideline.com/roadtest...-calipers.html Quote:
Gunning for Sixth
Drives: '03 ZR2 Blazer Join Date: Sep 2008
Guess Ford put the Mustang on a diet.
One Piston.. One Ford.. ommmmmmmm
There is one on each side, so there are two, right?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Doesn't even look like a Brembo caliper.
That's your basic cast iron made in China piece of crap caliper on 99% of the cars out there. |
Prince of Zamunda
They didn't call the rear's brembo's just the fronts...
Thanks, that explains it. They should call it - Front Brembo Brakes. If I bought a Brembo Brake Package, I'd assume it was all 4 corners. But then again it is Ford, expect mediocrity.
#7 |
#8 |
I'd rather have wheel weights than not having rear brembo brakes.
#9 | |
Camaro➎ moderator
You are comparing quality control issues to flat out lieing to all your customers. |
#10 | |
N7 Spectre
Drives: 14 ATS Performance 3.6L AWD Join Date: Jul 2008
#11 | |
I'd bet Ford had originally planned on all 4 Brembos. The car might be easier to change than the marketing literature. Probably determined the rears weren't needed, and pitched them for cost savings. |
#12 | |
Camaro➎ moderator
#13 |
#14 | |
Camaro➎ moderator
They did change them 3/4 of the way on the 2010 from flat weights to some roller skate looking ones. |
| Thread | Thread Starter | Forum | Replies | Last Post |
| How To Wire Dual Halos On Single Switch | kismyss | Camaro DIY & HOW-TO instructions & discussions | 54 | 05-06-2014 11:18 AM |
| Fastlane’s single turbo system | jude | Forced Induction - V8 | 175 | 09-10-2010 07:30 AM |
| Has anyone used a single DIN radio with the Metra Kit yet? Any photos? | 55Designs | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 13 | 05-11-2010 11:45 PM |
| Anyone have a single rally stripe?? | Maro99 | Cosmetics and Lighting Modification Discussions | 9 | 12-08-2009 03:56 PM |
| Answeres to questions I have stumbled on | dieseldave24v | 5th Gen Camaro SS LS LT General Discussions | 13 | 02-23-2009 06:56 PM |
