Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 12-14-2010, 10:40 PM   #1
The_Blur
Moderator
The_Blur's Avatar
Drives: 2018 Harley-Davidson Street Bob
Send a message via AIM to The_Blur
LLT Engine Internals Build
The LLT-powered Camaros have hit several bumps in the road to high-performance. From vendors backing out of projects to tuning woes, we are not where we want to be on the forced induction front.
It will happen eventually.
In the meantime, we should compile some build options. I am not familiar enough with the engine internals of the LLT to do this alone, so let's get together and help a few members build up their LLT powerplants.
Please contribute any aftermarket parts that will help our forced induction guys build their engines.
RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
Operation Demon//Buy at Invoice//RACECARWEAR
RESPECT ALL CARS. LOVE YOUR OWN.
warn 145:159 ban
The_Blur is offline   Reply With Quote
Old 12-15-2010, 12:00 AM   #2
noisemker
noisemker's Avatar
Drives: RY 2LT/RS
Airaid Intake And Solo CatBack Solo Highflow Cats
noisemker is offline   Reply With Quote
Old 12-15-2010, 04:45 AM   #3
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
subscribed
rtcat600man is offline   Reply With Quote
Old 12-15-2010, 06:14 AM   #4
bmwdon
I refuse to go smurfy
bmwdon's Avatar
Drives: 2009 Challenger SRT8, 2010 Camaro
Looks to be around $1k for a engine pulled from a traverse/arcadia/cts, getting one of those to a reputable engine performance shop to tear down and learn specs on it would be the best bet for finding out if there are any kind of real options already in place (rods/pistons) and if anybody has the ability to create a crank as a stroker....if the block has enough wall to handle a reasonable bore. So would a LLT community shop be willing to take that 1K hit, or could you find enough members to chip in on a purchase like that? My guess is no, it kinda sucked absorbing the $$ for a used set of heads on my own to try something nobody else has done....might gain squat, might make nice gains....if I do, then I'm sure I'll be able to sell my stock heads to somebody, otherwise, its money out the window I'll never get back. nervous!!
-Bill...the Camaro was my wifes, now she's got a minivan
Challenger- 2009 Dodge Challenger SRT8 Procharger D1 Supercharger: 10.895 @ 126.720 MPH
bmwdon is offline   Reply With Quote
Old 12-15-2010, 10:54 AM   #5
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
I have heard the stock engine internals are good for 650 HP. This was from supposedly a GM engineer. I have read elsewere that the LLT already has a forged crank, sinctered rods and beefy main journals. That said...
The torque rating for the tranny seems to be the limiting factor at some 430 ftlbs. The torque management system will help soften the shifts and reduce shock loads to some extent but, for the strip, that's not such a good thing. For my intended use, road course stuff, it should be OK.
We'll have to keep an eye on the diffy as well. The guys running NO2 and DRs will give us a pretty good read on that. Any of you guys looked at your axle seals lately?
Beauwulf is offline   Reply With Quote
Old 12-15-2010, 11:38 AM   #6
Demon Hunter
Demon Hunter's Avatar
Drives: 2010 Black Camaro LT
Subscribing to this one....
Demon Hunter is offline   Reply With Quote
Old 12-15-2010, 01:19 PM   #7
rtcat600man
GM HIGH-TECH performance Feb. 2009 edition. yes on the crank, rods and journals.
Tried to upload the article, but not having luck.
Old 12-15-2010, 02:16 PM   #8
The_Blur
Moderator
The_Blur's Avatar
When you get that loaded, I'll post it to the Wiki.
warn 145:159 ban
Old 12-15-2010, 02:19 PM   #9
Edge.128
Edge.128's Avatar
Drives: 2010 Camaro LS
hopefully some info comes our way in time. suscribed.
2010 Summit White Camaro LS / M6
MRT V2.0
Edge.128 is offline   Reply With Quote
Old 12-15-2010, 02:29 PM   #10
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
MATERIALS
Block: Sand cast aluminum (319) with cast in iron bore liners
Cylinder head: Cast aluminum ( 319 semi permanent mold )
Intake manifold: Aluminum ( 319 Upper, and Lower )
Exhaust manifold: High-silicon moly cast iron
Main bearing caps: Sintered steel ( CU infiltrated )
Crankshaft: Forged steel ( 1038 V )
Camshaft: Cast nodular iron
Connecting rods: Sinter forged steel
Additional features:
Four-cam continuously variable cam phasing
Internal exhaust gas recirculation ( EGR )
Pressure-actuated piston cooling jets
Torque-based engine management system
Secondary throat cut inlet ports
Direct injection fuel system
High-pressure, engine-driven fuel pump with stainless steel fuel rails
Internal front cover damper plates
Cartridge style oil filter
Extended life spark plugs
Extended life coolant
Extended life accessory drive belts
7.7mm IT chain system for all HFV6 applications
Coil-on-plug ignition
Structural cast-aluminum oil pan with steel baffles
5W30 GF4 Mineral Oil
Synthetic Oil for Cadillac applications
Old 12-15-2010, 02:43 PM   #11
The_Blur
Moderator
The_Blur's Avatar
Originally Posted by Milk 1027 View Post
MATERIALS
This is great information, but I'm also seeking some aftermarket options. Those of us wanting cams and all the other goodies upgraded need to know that we have some options. The OEM build is great, but we want more.
warn 145:159 ban
Old 12-15-2010, 02:43 PM   #12
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
Just letting you know what you have to work with. It's a start
Old 12-15-2010, 04:41 PM   #13
rhd
dirtbag
rhd's Avatar
Drives: 2010 camaro LS
as of right now there isnt much, anything you would want you would have to have it custom made.....i have been looking at some custom cams(a big maybe) and a custom intakemanifold. but still its nice to see a thread about something other than intakes and exhaust!
rhd is offline   Reply With Quote
Old 12-15-2010, 04:43 PM   #14
SDCamaro10
SDCamaro10's Avatar
Drives: 2010 Camaro 1LT RJT
I doubt we'll be seeing anything reasonable for cams anytime soon since we have 4 cams. would likely be too expensive.
SDCamaro10 is offline   Reply With Quote
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW camarojoe Dealer Camaros for Sale 2 05-24-2010 05:58 PM
LLT engine specifications Tran Wiki 2 03-29-2010 10:06 AM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 01:56 PM
L99 engine specifications Tran Wiki 0 10-19-2008 11:40 AM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 06:16 PM
